查看: 1060|回复: 0
[求助]:AcDbHatch求助
发表于 2006-4-5 19:59:07 | 显示全部楼层 |阅读模式
Acad::ErrorStatus acqHatch2()
    AcDbHatch* pHatch = new AcDbHatch();
    // Set hatch plane
    AcGeVector3d normal(0.0, 0.0, 1.0);
    pHatch->setNormal(normal);
    pHatch->setElevation(0.0);
    // Set hatch pattern to ANSI31 predefined type
    pHatch->setPattern(AcDbHatch::kPreDefined, "ANSI31");
    // Set Associativity
    pHatch->setAssociative(Adesk::kTrue);
    // Construct database AcDbLines
    AcGePoint3d vertexPts[4];
    AcDbObjectId lineId, cirId, hatchId;
    AcDbObjectIdArray dbObjIds,dbObjId2;
    AcDbLine *line;
    vertexPts[0].set(2.0, 2.0, 0.0);
    vertexPts[1].set(20.0, 2.0, 0.0);
    vertexPts[2].set(20.0, 20.0, 0.0);
    vertexPts[3].set(2.0, 8.0, 0.0);
    int b;
    CreateLine(vertexPts[0],vertexPts[1],lineId);
    dbObjIds.append(lineId);
    CreateLine(vertexPts[1],vertexPts[2],lineId);
    CreateLine(vertexPts[2],vertexPts[3],lineId);
    CreateLine(vertexPts[3],vertexPts[0],lineId);
    b = dbObjIds.append(lineId);
    // Append an external rectangular loop to hatch boundary
   pHatch->appendLoop(AcDbHatch::kExternal, dbObjIds);
   b = pHatch->numLoops();
    // Create a AcDbCircle and post it to database
    AcGePoint3d cenPt(5.0, 5.0, 0.0);
    AcDbCircle *circle = new AcDbCircle(cenPt,normal,2);
    AcDbBlockTable *pBlockTbale;
    Acad::ErrorStatus es = acdbHostApplicationServices()->workingDatabase()
        ->getSymbolTable(pBlockTbale, AcDb::kForRead);
    if (es != Acad::eOk)
        //delete pLine;
        return es;
    AcDbBlockTableRecord  *pBlockTbaleRecord;
    pBlockTbale->getAt(ACDB_MODEL_SPACE, pBlockTbaleRecord, AcDb::kForWrite);
    pBlockTbale->close();
    es = pBlockTbaleRecord->appendAcDbEntity(cirId, circle);
    dbObjIds.setLogicalLength(0);
    b = dbObjIds.append(cirId);
    b = dbObjIds.length();
    // Append an internal loop (circle) to hatch boundary
   //在调用这里的时候,返回错误, 想问问为什么?
    if(Acad::eOk!=pHatch->appendLoop(AcDbHatch::kDefault ,dbObjIds))
        AfxMessageBox("加入错误");
        return Acad::eOk;
    // Elaborate hatch lines
    pHatch->evaluateHatch();
    // Get all associative source boundary object Ids for later use.
    pHatch->getAssocObjIds(dbObjIds);
    // Post hatch entity to database
    //pHatch->postToDb(pHatch, hatchId);
    pBlockTbaleRecord->appendAcDbEntity(hatchId, pHatch);
    pBlockTbaleRecord->close();
    circle->close();
    // Attach hatchId to all source boundary objects for notification.
    AcDbEntity *pEnt;
    int numObjs = dbObjIds.length();
    //Acad::ErrorStatus es;
    for (int i = 0; i < numObjs; i++)
        es = acdbOpenAcDbEntity(pEnt, dbObjIds, AcDb::kForWrite);
        if (es == Acad::eOk)
            pEnt->addPersistentReactor(hatchId);
            pEnt->close();
    return eOk;
GMT+8, 2026-11-22 10:04 , Processed in 0.243014 second(s), 10 queries , Gzip On, File On.
