查看: 1597|回复: 1
[ARX程序]:请教:关于填充闭合区域
发表于 2006-5-30 10:53:52 | 显示全部楼层 |阅读模式
我用下面的代码实现任何形状的封闭区域的填充,主要是搜索要填充的区域,然后用polyline生成boundary!代码可以执行,就是填充完后将对polyline进行编辑的时候,autocad 就会出错!各位大侠帮忙看看出什么问题了,谢谢!
//搜索一不铸孔封闭区域并涂黑
void HzBzkFbAreaSearch()
        AcDbObjectId   oldLayerId = acdbCurDwg()->clayer();
        HzDefineLayer();
        g_bDefineLayer = TRUE;
        setCurLayer(g_strLayer_Core);
        AcDbObjectId objId,Id,subId;
        AcDbObjectIdArray dbObjIds;
        AcDbBlockTable *pBlockTable;
        AcDbBlockTableRecord *pBlockTableRecord;
        if( SearchClosedBoundary( objId ) )
//searchclosedBoundary搜索封闭区域并用多义线覆盖边界,同时返回多义线的Id这个函数绝对没问题
                AcDbEntity *pEnt ;
                if( acdbOpenAcDbEntity( pEnt, objId, AcDb::kForRead ) != Acad:: eOk )
                        acutPrintf("\nOpen it error");
                        acdbCurDwg()->setClayer(oldLayerId);
                        return;
                if( pEnt->isA() == AcDbPolyline::desc() )
                        AcDbPolyline *p = (AcDbPolyline* )pEnt;
                        if( p->isClosed() == Adesk::kFalse )
                                pEnt->close();
                                acutPrintf("\nNot closed zone");
                                return;
           dbObjIds.append(objId);
           AcDbHatch* pHatch = new AcDbHatch();
           pHatch->setNormal(AcGeVector3d(0.0,0.0,1.0));
           pHatch->setElevation(0.0);
           pHatch->setAssociative(Adesk::kFalse);
           pHatch->setPatternScale(5);
           pHatch->setPattern(AcDbHatch::kPreDefined,"SOLID");
           pHatch->setHatchStyle(AcDbHatch::kNormal);
           pHatch->appendLoop(AcDbHatch::kExternal,dbObjIds);
           pHatch->evaluateHatch();
           pHatch->setColorIndex(1);
           acdbHostApplicationServices()->workingDatabase()//查找并以只读模式
               ->getSymbolTable(pBlockTable, AcDb::kForRead);//打开图块表
           pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord,
                 AcDb::kForWrite);//查找并以写模式打开图块表记录(模型空间)
           pBlockTable->close();//关闭图块表
           pBlockTableRecord->appendAcDbEntity(Id, pHatch);//添加实体返回ID
          pBlockTableRecord->close();//关闭图块表记录
           pHatch->close();//关闭实体
                else
                        acutPrintf("\nNot find it ");
                        pEnt->close();
                        DeleteEntity( objId );
                        return;
发表于 2019-9-25 19:36:35 | 显示全部楼层
你好,SearchClosedBoundary这个函数代码能分享一下么?谢谢了
GMT+8, 2026-11-22 09:54 , Processed in 0.434489 second(s), 12 queries , Gzip On, File On.
