查看: 840|回复: 1
[LISP程序]:推荐-弹簧程序
发表于 2006-3-15 22:20:55 | 显示全部楼层 |阅读模式
(defun c:3dth(/)
  (setq p1(getpoint "请指定螺旋线基点:"))
  (setq r(getreal "请输入弹簧平均半径:"))
  (setq d0(getreal "请输入弹簧丝直径:"))
  (setq disp(getreal "请输入弹簧节距:"))
  (setq n0(getint "请输入弹簧工作圈数:"))
  (setq n(getint "请输入每圈细化段数(16/20/24/28/32/36/40/48/52/56/60/100):"))
  (setq n1(* 1.25 n))                   ;支撑圈细化段数
  (setq n1(fix n1))
  (setq n2(* n0 n))                     ;工作圈细化段数
  (setq delta(/ (* 2.0 pi) n))          ;单位转角
  (setq j(/ disp n))                    ;工作圈轴向位移量
  (setq j0(/ d0 n))                     ;支撑圈轴向位移量
  (setq bb(caddr p1))
  (setq ang 0)
  (setq jj 0)
  (command "ucs" "o" p1)
  (setq pt1(list r 0 0))
  (command "3dpoly" pt1)
  (repeat n1                            ;绘制下支撑圈
    (setq jj(+ jj 1))
    (setq ang(+ delta ang))
    (setq pt(list (* r (cos ang)) (* r (sin ang)) (* j0 jj)))
    (command pt)
  (setq p2(list 0 0 (* j0 jj)))
  (setq g1(* j0 jj))                    ;下支撑圈高度
  (setq jj 0)
  (repeat n2                            ;绘制工作圈
    (setq jj(+ jj 1))
    (setq pt(list (* r (cos ang)) (* r (sin ang)) (+ g1 (* j jj))))
    (command pt)
  (setq p3(list 0 0 (* j jj)))
  (setq g2(* j jj))                     ;工作圈高度
  (setq jj 0)
  (repeat n1                            ;绘制上支撑圈
    (setq jj(+ jj 1))
    (setq pt(list (* r (cos ang)) (* r (sin ang)) (+ g1 g2 (* j0 jj))))
    (command pt)
  (setq g3(* j0 jj))                    ;上支撑圈高度
  (command "")
  (setq e1(entlast))
  (command "ucs" "x" "")                ;拉伸弹簧
  (command "circle" pt1 (/ d0 2))
  (setq e2(entlast))
  (command "extrude" e2 "" "p" e1)
  (setq e3(entlast))
  (setq pt2(list r (/ d0 4) 0))         ;磨平
  (setq py(+ g1 g2 g3 (- 0 (/ d0 4))))
  (setq pt3(list (- 0 r) py 0))
  (command "slice" e3 "" "zx" pt2 pt3)
  (command "slice" e3 "" "zx" pt3 pt2)
  (command "ucs" "w")
;;;---------end----------弹簧程序结束!
发表于 2006-3-16 14:34:05 | 显示全部楼层
Thank!
GMT+8, 2026-11-7 01:47 , Processed in 0.489163 second(s), 34 queries , Gzip On.
