查看: 1143|回复: 5
[编程申请]:再次请教大师们图层处理的问题!
发表于 2006-3-26 10:28:13 | 显示全部楼层 |阅读模式
;改成黄色--------------------------------------------------------- 2
(defun c:2(/ ent)
  (setq ent (ssget))
  (command "change" ent "" "p" "c" "2" "")
;改成绿色--------------------------------------------------------- 4
(defun c:4(/ ent)
  (setq ent (ssget))
  (command "change" ent "" "p" "c" "3" "")
;改成青色--------------------------------------------------------- 1
(defun c:1(/ ent)
  (setq ent (ssget))
  (command "change" ent "" "p" "c" "4" "")
;改成紫色--------------------------------------------------------- 3
(defun c:3(/ ent)
  (setq ent (ssget))
  (command "change" ent "" "p" "c" "6" "")
;改成灰色--------------------------------------------------------- 5
(defun c:5(/ ent)
  (setq ent (ssget))
  (command "change" ent "" "p" "c" "251" "")
________________________________________________
请大家看一下上一段程序,有没有什么问题,但怎么没次加载后都显示有错误!
能不能麻烦如何可以实现快速换图层...比如按11就可以直接切到1图层,22的话可直接切到2图层?
已领礼包: 2个
发表于 2006-3-26 11:22:15 | 显示全部楼层
你自己耐心找找,论坛上有很多这样的帖子.
发表于 2006-3-26 11:49:48 | 显示全部楼层
[PHP]
;;;******图层切换******
(DEFUN C:11() (setvar "clayer" "图层1"))        ;切换到图层1
(DEFUN C:22() (setvar "clayer" "图层2"))        ;切换到图层2
(DEFUN C:33() (setvar "clayer" "图层3"))        ;切换到图层3
(DEFUN C:44() (setvar "clayer" "图层4"))        ;切换到图层4
(DEFUN C:55() (setvar "clayer" "图层5"))        ;切换到图层5
[/PHP]
发表于 2006-3-26 15:57:21 | 显示全部楼层
  1. [FONT=courier new];;改成红色--------------------------------------------------------- 2
  2. (defun c:1 (/ ent)
  3.   (if (setq ent (ssget))
  4.     (command "chprop" ent "" "c" "1" "")
  5.   )
  6.   (princ)
  7. )
  8. ;;改成黄色--------------------------------------------------------- 2
  9. (defun c:2 (/ ent)
  10.   (if (setq ent (ssget))
  11.     (command "chprop" ent "" "c" "2" "")
  12.   )
  13.   (princ)
  14. )
  15. ;;改成绿色--------------------------------------------------------- 3
  16. (defun c:3 (/ ent)
  17.   (if (setq ent (ssget))
  18.     (command "chprop" ent "" "c" "3" "")
  19.   )
  20.   (princ)
  21. )
  22. ;;改成青色--------------------------------------------------------- 4
  23. (defun c:4 (/ ent)
  24.   (if (setq ent (ssget))
  25.     (command "chprop" ent "" "c" "4" "")
  26.   )
  27.   (princ)
  28. )
  29. ;;改成粉色--------------------------------------------------------- 4
  30. (defun c:5 (/ ent)
  31.   (if (setq ent (ssget))
  32.     (command "chprop" ent "" "c" "5" "")
  33.   )
  34.   (princ)
  35. )
  36. ;;改成紫色--------------------------------------------------------- 6
  37. (defun c:6 (/ ent)
  38.   (if (setq ent (ssget))
  39.     (command "chprop" ent "" "c" "6" "")
  40.   )
  41.   (princ)
  42. )
  43. ;;改成灰色--------------------------------------------------------- 7
  44. (defun c:7 (/ ent)
  45.   (if (setq ent (ssget))
  46.     (command "chprop" ent "" "c" "7" "")
  47.   )
  48.   (princ)
  49. )[/FONT]
发表于 2006-3-26 21:49:14 | 显示全部楼层
(defun c:5(/ ent)
(setq ent (ssget))
最后少了一个括号
 楼主| 发表于 2006-3-27 08:39:51 | 显示全部楼层
谢谢大家的帮忙...自动换层和直接改层的问题已经处理好了...非常感谢大家!!!
GMT+8, 2026-11-7 01:44 , Processed in 0.457508 second(s), 42 queries , Gzip On.
