查看: 2566|回复: 11
[原创]:ADT2004和AutoCAD2004界面上一点小的区别
发表于 2003-5-12 22:46:16 | 显示全部楼层 |阅读模式
单击右下角的小箭头可以发现,ADT不能定制最底下的状态栏显示哪些项目。
发表于 2003-5-13 23:53:52 | 显示全部楼层
是啊~~~这次ADT好象不完全把所有ACAD 2004的东东都放出来,他有自己的一套~~~
发表于 2003-6-10 12:41:31 | 显示全部楼层
不好用
发表于 2003-6-26 23:48:35 | 显示全部楼层
BT下载 ADT2004
发表于 2003-6-27 20:46:31 | 显示全部楼层
gsxch兄,解压出来的文件怎么用?
发表于 2003-6-28 07:29:06 | 显示全部楼层
gsxch兄,解压出来的文件是什么东西,怎么用
发表于 2003-6-28 12:05:27 | 显示全部楼层
好東西 謝謝啦
发表于 2003-7-3 23:40:28 | 显示全部楼层
怎么?还不给我下摘啊 !!!?
郁闷……
发表于 2003-7-5 17:41:34 | 显示全部楼层
解压以后用什么方式打开啊?
 楼主| 发表于 2003-11-20 00:03:27 | 显示全部楼层
SP1修复了这个bug
Drawing Status Bar
You now have the ability to turn off the drawing status bar for each profile. The first time ADT2004 is run after the service pack is installed, a new registry key will be created:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R16.0\ACAD-204:nnn\Profiles\{Current Profile}\Preferences\AecStartup40
In the registry, "nnn" will be a three-digit number reflecting the language of the product installed, and {Current Profile} is the name of the profile that is used at startup.
This key will contain a value, ShowAecDrawingStatusBar. The default is 1, which displays the status bar for every open drawing. Setting this to zero will prevent the status bar from displaying for the next session. The value in the initial profile is used to determine the visibility of the Status bar for the entire session.
Note that there are two commands which are only available from the Drawing Menu on this status bar, "Publish to Architectural Studio..." (PublishtoArchStudio) and "Link to Autodesk VIZ Render..." (VizRender). In addition, the Display Configuration selection popup list will no longer appear (DisplayManagerConfigsSelection). Display Configurations can be changed using Format > Display Manager.
发表于 2003-11-25 22:20:55 | 显示全部楼层
哎,我眼铮铮的看着他不能下啊
发表于 2003-11-27 15:52:34 | 显示全部楼层
什么东西,下来看看!
GMT+8, 2026-11-22 08:54 , Processed in 0.552907 second(s), 30 queries , Gzip On, File On.
