查看: 2369|回复: 8
[文章]:ADT 2007 具体升级内容!
发表于 2006-4-2 01:00:54 | 显示全部楼层 |阅读模式
Architectural Desktop 2007
Designed specifically for architects and engineers involved in building design and construction, Architectural Desktop 2007 (ADT) is built on AutoCAD software and its intelligent objects mean that you can get productive right away.
Architectural Desktop 2007 brings you new features and functionality that focus on the following themes:
Documentation and Reporting Enhancements
Object Enhancements
Project Workflow Enhancements
Built on a new AutoCAD 2007 platform
In this release of Architectural Desktop, major focus has been placed on addressing the problems and challenges of space layout and reporting.
Additional improvements have been made to other aspects of the documentation process, including Dimensions, Scheduling, and 2D Sections/Elevations.
Space / Area / eSpace Unification
Until Architectural Desktop 2007, there existed several overlapping solutions for representing spatial arrangements in Architectural Desktop.  Confusion existed as to when to use the Space object vs. the Area/Area Group objects.  In an Autodesk Building Systems environment, the Engineering Space (eSpace) and Zone  (eZone) objects added a third challenge; this also did not offer the most optimal workflow between Architectural Desktop and Building Systems users.
In ADT 2007, these objects have been unified into one comprehensive solution.  Previous version objects (Areas, Area Groups, eSpaces, eZones) are automatically upgraded into the new Space and Zone
objects.
Name Definitions used by Areas & Area Groups are now provided through the new List Definition property set type.
Spaces may also be grouped into Zones across x-refs.
Space Auto-creation Enhancements
The Space Auto-Generate command will allow creation of spaces in a single click from an entire drawing or xref.
Space Bounding Object Interaction
Spaces in Architectural Desktop are now capable of being associative to the objects (walls, slabs, curtain walls, etc) which surround them. In previous  releases you would need to reselect the bounded objects to update the space.
In Architectural Desktop 2007 this is streamlined by a simple right-click Update command.
Freeform Volumetric Spaces
Spaces now have three shape types: 2D (Area), Extrusion, and Freeform allowing you to accurately report the volume, in addition to providing the required information used by the Standards-based Calculations.  Mass element editing and Boolean operations provide flexibible modelling capabilities for non-associative spaces.
Automated Wall Component Dimensioning
AEC Dimensions now provide the ability to automatically dimension to wall components, as defined by the wall style, based on:
Structural vs. Non-Structural
Center of wall or center of any component
Left/right of wall or any component
Associative Manual Dimensions
In past releases, manual dimension points for AEC Dimensions left AutoCAD point objects which caused confusion when deleting the dimension string but points remained. Now manual AEC Dimensions behave consistently with AutoCAD dimensions and are associative to objects, such as Multi-view blocks.  A + grip on the dimension chain allows you to quickly dimension to additional objects or points.
Schedule Table Title Override
Schedule tables in ADT 2007 now provide the ability to override the title specified on the style for each instance that uses that style.  In past releases separate schedule table styles would need to be created to address situations such as door schedules per floor (eg. First Floor Door Schedule; Second Floor Door Schedule).
Header Overrides
ADT 2007 also now provides the ability for individual column headers to have overridden formatting.
Schedule Table Formulae
Provide more powerful schedule tables by performing calculations directly in the schedule table column and include access to a quantity column in a formula column.
List Definition
Manual property definitions in Architectural Desktop provide ultimate flexibility in the non-graphical data that can be attached to objects and styles. One tedious and error-prone aspect of manual properties is repeated data entry.
ADT 2007 now provides a List Definition that allows you to pre-specify a list of properties that can be re-used in any manual property.
Property Visibility
In ADT 2007 you can control which properties appear in the Extended Data tab of the Properties Palette, including the ability to hide individual properties.
Anchor Property
ADT 2007 adds a new ‘Anchor Property Definition’ type to allow an object to retrieve data from the object it is anchored to.  For example, a door can retrieve the fire rating from the wall in which it is inserted (anchored) into.
Classification Enhancements
In previous releases, classifications could be applied to object styles. In ADT 2007 this functionality is extended to support classifications per object.  On the Extended Data tab of the Properties Palette any classification definitions that apply to the selected object will appear in the new “Classification” group.
Additionally, classification definitions now support a hierarchical organisation structure to allow industry standard classifications to be implemented.
2D Section/Elevation Linework from Model Display
Architectural Desktop’s 2D Section/Elevation object provides flexible functionality from which to create a section or elevation from the model.  This system, however, is optimised for objects that have Materials applied to them.  A common request from customers is to simply maintain the layer/color/linetype of the display properties assigned to the objects in lieu of using the Design Rule functionality.
ADT 2007 provides the ability to “Maintain layer, color, linetype properties from the Display Set used during generation.”
Object Enhancements
Multi-component Slabs
Consistent with walls, you can now define slabs and roof slabs with multiple components for more usable 2D sections.
Modifiers and Interferences
The slab/roof slab objects now support body modifiers and interference conditions consistent with walls. Interference conditions can also interact with objects across x-refs.
True Arc Edges
In past releases, slabs created from curved geometry resulted in dozens of faceted segments which could not be later edited as an arc. In ADT 2007 true arc edges are now available on slabs and roof slabs for easier editing and more accurate coordination.
Custom Stair from Linework
Stairs in ADT 2007 now offer an intuitive workflow when the full parametric capabilities of the stair object are not required.  Simply sketch a stair in plan using lines, polylines, and arcs and then convert to a stair by right-clicking any Stair Tool and applying it to the linework.
Custom Stair
Convert any stair object into a custom stair and then you can then edit treads and risers in place using familiar grip editing functionality.
Body Modifiers on Stairs
Stairs in ADT 2007 now provide the ability to add Body Modifiers similar to walls, slabs, and structural members.  Add, subtract, or replace a stringer, tread, landing, or riser with any 3D body.
Interference Conditions on Stairs
Similar to walls, slabs, roof slabs, and structural members, you can now also add interference conditions to stairs, including objects across x-refs.
Up/Down Display
ADT 2007 will now allow the independent representation of “down” and “above” cut plane display components.
Railing Customisation
Railing styles now provide the ability to assign unique profiles for first, last, and other fixed posts.  Railings now also allow you to have posts to be oriented perpendicular to the stair slope, with a trigger grip for first and last posts to allow these to vary from the interior posts.
Structural Member Body Modifiers
You can now add body modifiers, similar to walls, slabs, and roof slabs, to Architectural Desktop structural members to more accurately reflect your design conditions.
Use Custom Block Boolean operations on structural members styles (or object instances), to create single or repeating holes for castellated beams, etc.
Structural Member Interference Conditions
Similar to walls, slabs, roof slabs, and stairs, you can now also add Interference Conditions to structural members, including objects across x-refs. This functionality allows you to more accurately depict interacting conditions between, for example, the architectural objects and Autodesk Building Systems objects, such as duct work and piping.
Wall Interferences
In previous releases of Architectural Desktop, wall objects had the ability to depict interference conditions with objects, such as columns. In ADT 2007, along with slabs, roof slabs, stairs, and structural members, you can now create these relationships across x-refs.
Project Navigator Enhancements - Folder Customisation
A long-standing request is to allow the hard-coded folders used by Constructs, Elements, Views and Sheets to be customisable to user’s pre-existing folder structures.  ADT 2007 now provides the ability to configure custom folder paths for these items.
Project Navigator Enhancements - Mapped Drives
ADT 2007 provides additional support for mapped drives. In previous releases you could navigate to a mapped drive, but the Project Navigator would store a UNC path (\\computer\folder\...) to safeguard against server changes.  In ADT 2007, this check is no longer performed, and however a drive is navigated to in the Project setup dialog (mapped or UNC), this pathing option is honoured.
Click here for product details, brochure and pricing.
 楼主| 发表于 2006-4-2 01:02:30 | 显示全部楼层
翻译网页工具,翻译了下!有点不通,但大概意思明了了!:)
2007台式建筑
专为建筑师、工程师参与设计和施工建设,2007台式建筑(ADT)是建立在软件和智能物体AUTOCCAD意味着你可以马上生产.
2007台式建筑带来新的特点和功能大家,重点抓好以下几个主题:
文件和报告改进
反对提高
项目流程改善
建于2007年的新平台AUTOCCAD
文件和报告改进
这释放台式建筑,已被列入重点解决的问题和挑战,并提出空间布局.
进一步改善了其他方面的文件工作,包括规模、时间、2D科/Elevations.
空间/地区/统Espace
台式建筑,直到2007年,有若干重叠的办法是台式建筑空间安排.   在使用时存在着混乱的地区与空间物体/组物品地区.   欧特克体系的建设环境,航天工程和区(Espace)   (Ltd)对象增加了第三个挑战. 这也没有提供最佳的设计流程之间的桌面系统用户和建设.
ADT在2007年,这些物品都统一成一个全面的解决办法.   以前版本物体(区、地区团体、Espaces,Ezones)自动提升到新的空间和区
反对.
用名称定义区 & 组别现提供新的类型的财产清单定义.
区位也可分为十大跨越--refs.
太空自动创建增强
航天汽车制造指挥使创建一个点位在整个绘画或XREF.
空间互动式对象
现在台式建筑空间能够配合的物体(墙、地砖、玻璃等的)围攻. 前   发布你需要的reselect物体内更新的空间.
这是2007年的台式建筑的简单精简右翼指挥部最新资讯.
体积蜷位
现在有3位形状类型:2D(区)、压挤,让你蜷如实申报量,除了提供必要的资料用的标准计算.   内容编辑和集体行动提供flexibible模拟运算能力不配合位.
维墙组成自动化
非共体方面现在能够自动提供内容部分围墙,墙式所确定的基础上:
结构性与非结构性
中心或中心的任何部分墙
左/权或部分墙
手册内容联想
在过去的版本,手册内容要点共同体层面AUTOCCAD点离开物体时造成混乱的内容:串点,但仍然存在. 非共体方面的表现,现在人手方面,协会一直与AUTOCCAD用途等多座看法.   A+连锁控制的因素使你很快的物体或其他方面意见.
附表表标题凌驾
2007年计划表ADT现在能够提供具体的方式推翻标题为每次利用这一风格.   发布时间以往不同风格的表必须建立起处理情况表等,每门地板(如附表一楼大门; 二楼大门表).
组长压倒
ADT2007现在还提供个人专栏邀请赛有能力推翻格式.
附表表公式
提供更强大的演出安排表的时间计算表直接接触,其中包括一批栏栏栏的方式.
名单确定
人工建筑地产定义为终极台式弹性非图形数据可以附带物品和作风. 一个乏味、错误百出手册内容物业多次数据输入.
ADT提供了一个名单确定2007年让你预先指定的财产清单,可以再用人工任何财物.
可见财产
ADT在2007年就可以控制好数据将出现财产的调色盘财产,包括个人的能力,隐匿财产.
主要财产
ADT2007年新增 ‘ 主要财产的定义 ’ 允许类对象的数据检索对象,这是建立.   例如,可以检索防火门墙评级从它添加到(停靠).
分类汇
以往版本,可用于分类目的风格. ADT将在2007年支持这项功能是每个分类对象.   关于延长物业的调色盘任何费用数据分类定义适用于选定对象还会出现新 “ 分类 ” 组.
此外,分类分级管理架构定义支持目前的行业标准分类,以便实施.
第2D/高程模型从linework
台式建筑 ’ 中国第2D/高程为目标,建立灵活的功能从第一个层次或从模式.   这个系统,是最佳发挥用途,应用材料给他们.   共同的根本要求,是保持客户层/彩色/linetype的财产分配给显示对象而不是利用规则设计功能.
ADT能够提供2007 “ 保持层、颜色、linetype财产展示期间所使用的一代. ”
反对提高
多重砖
符合墙,你现在确定砖与砖、屋顶部分更可多节2D.
果和干扰
在平板/顶部物体现在支持符合条件的机构和干涉倒墙. 干扰条件下也能与物体在X光refs.
真正弧边缘
在过去的版本,从制造砖几何弯曲造成数十面部分不能作为一个弧形后编辑. ADT在2007年真正的优势,即日起在弧形砖、屋顶砖更容易、更准确的编辑协调工作.
从楼梯习惯linework
ADT提供了2007年在楼梯现在凭工作能力的参数,完全不需要对象数量.   计划在两地描绘了用线,polylines,然后把海弧的数量由右点击任何数量的工具,它采用linework.
两习惯
反对任何把楼梯台阶,成为习惯,就可以使用编辑留下了熟悉和掌握管道编辑功能.
身体倒在楼道
2007年在楼梯ADT现在加上身体能力提供了类似墙倒、砖、构件.   补充、减或更换毒刺,走,陆、建筑与身体的任何3D.
楼道干扰条件
类似墙壁砖、屋顶砖、构件,你现在还可以再加以干扰条件下楼梯,跨越对象包括X光refs.
上/下显示
ADT2007现在允许独立的代表性 “ 下跌 ” 以及 “ 以上 ” 切断机展示内容.
栏杆定制
现在能够提供栏杆风格独特书概况一、去年等固定岗位.   栏杆现在都还让你职位面向垂直升降的斜坡,引发了第一次也是最后一次为把握职位,让这些来自内地不同职位.
果机构成员结构
现在你可以增加身体倒类似墙、砖、屋顶砖、建筑构件桌上,以便更准确地反映出你的设计环境.
习惯使用行动运算构件整体风格(或下反对),建立单一或重复洞castellated束等
成员结构状况干扰
类似墙壁砖、屋顶砖、楼梯,你现在还可以再加以干扰条件下构件,对象包括各Xrefs. 这项功能让你更准确地描绘条件之间的互动,例如建筑物体和物体欧特克体系建设等工作,并用管道输送.
墙干扰
以前发布的台式建筑,墙上有能力把物体与物体干扰条件等栏目. ADT在2007年,随着砖、屋顶砖、楼梯、构件,你可以建立这种关系在X光refs.
加强工程领航-定制式
长期以来要求是让硬东西用密码文件夹、内容、观点、张应customisable用户 ’ 中国原有的结构式.   ADT2007现在能够提供这些项目的配置习惯式道路.
加强工程领航-规划建设
ADT2007年制定活动提供更多的支持. 你可以在公布前制定的航行动力,但商店的联合国军司令部将道路工程领航( \\计算机\文件\ )以防服务器变化.   ADT在2007年,这已不再进行检查,但驾驶的是,在项目设置导航对话(联合国军司令部和部署),选择途径荣幸.
发表于 2006-4-11 16:02:11 | 显示全部楼层
vssbbs@gmail.comvssbbs@gmail.com
发表于 2006-4-12 12:27:36 | 显示全部楼层
能介绍的详细点吗?比如建摸之类的!
发表于 2006-4-25 19:59:13 | 显示全部楼层
是电脑翻译的吧,有没有高手来翻译得地道一点?
发表于 2006-5-21 09:27:18 | 显示全部楼层
大概能理解,多谢
发表于 2006-5-22 23:53:15 | 显示全部楼层
请问各位仁兄,adt2007那里有的卖阿?
发表于 2006-5-26 09:25:40 | 显示全部楼层
恩,我也想学习!
发表于 2006-5-28 15:40:15 | 显示全部楼层
新的功能用起来有些部分跟SK的思考方向有点像
不过看来曲面的功能还是没有MAX或其他的软体强
GMT+8, 2026-11-22 08:49 , Processed in 0.420630 second(s), 27 queries , Gzip On, File On.
