查看: 888|回复: 1
[分享]:象3DMAX一样,可以随意放大缩小四个视窗的程序
发表于 2003-5-13 13:54:40 | 显示全部楼层 |阅读模式
我习惯在R14里建模,我一般喜欢用四个视窗,象3DMAX一样,有各个视点的,但R14的视窗不能象3DSMAX一样可以放大、缩小,很不方便。所以我用LISP编了个小程序可以,还是很方便,由于
我并不精通LISP,所以很多函数都不知道,是用最简单的函数写的,如果有谁编有更好的,希望拿来交流。
(defun paper ()
(setq po1 (list 75 100) po2 (list 591 100) po3 (list 591 440) po4 (list 75 440) po5 (list 333 270) po6 (list 70 95) po7 (list 595 450) (command "tilemode" 0)(princ)
(command "mview" "4" po1 po3 )(princ)
(command "zoom" "w" po6 po7)(princ)
(command "mspace")(princ)
(princ)
) ;第一次启动四视窗
(defun ucs ()
(command "ucs" "v") (princ)
) ;改变ucs为当前ucs
(defun all ()
(command "tilemode" 0) (command "pspace")(princ)
(setq po6 (list 95 95))
(setq po7 (list 570 450))
(command "mspace")
(princ)
) ;回到四视窗状态
(defun e ()
(setq po4 (list 100 440))
(setq po5 (list 333 270))
(command "zoom" "w" po5 po4)(princ)
(command "mspace")
(princ)
(ucs) (princ)
) ;放大第一视窗
(defun b ()
(setq po3 (list 566 440))
(command "zoom" "w" po5 po3)(princ)
(ucs) (princ)
) ;放大第二视窗
(defun c ()
(setq po1 (list 100 100))
(command "zoom" "w" po5 po1)(princ)
(ucs) (princ)
) ;放大第三视窗
(defun d ()
(setq po2 (list 566 100))
(command "zoom" "w" po5 po2)(princ)
(ucs) (princ)
) ;放大第四视窗
(defun tt (/ sst)
(setq sst(ssget))
(if (= h nil)
(setq S 300))
(princ "厚度<")
(princ S)
(princ ">")
(princ ":")
(setq h (getdist))
(if (= h nil)(setq h S))
(command "extrude" sst "" h 0)
(setq S h)
(setq ssl nil)
(gc)
(princ)
) ;把封闭的线框变为实体
(defun uu ()
(setq pu (getpoint "原点:"))
(command "ucs" "o" pu)
) ;平移ucs坐标原点
(defun c:uu () (uu))
(defun c:tt () (tt))
(defun c:aa () (all)(princ))
(defun c:vv () (ucs)(princ))
(defun c:pp () (paper)(princ))
(defun c:1 () (e)(princ))
(defun c:2 () (b)(princ))
(defun c:3 () (c)(princ))
(defun c:4 () (d)(princ))
已领礼包: 488个
发表于 2003-5-13 23:34:14 | 显示全部楼层
初始化?
找个滚轮缩放的程序回更好.
我一般不写成命令,定义几个快捷键会更好用,不用打命令了.(改acad.mnu,或autohook等)
建模的心得这里说的少的.其实用cad建模的人不少.
GMT+8, 2026-11-3 19:07 , Processed in 0.480427 second(s), 34 queries , Gzip On.
