查看: 1005|回复: 2
[LISP程序]:颜色转换工具
发表于 2003-5-15 14:37:52 | 显示全部楼层 |阅读模式
  1. (defun c:cc (/ ent dcl_id)
  2.   (setq        olderr        *error*
  3.         *error*        err
  4.   )
  5.   (setvar "CMDECHO" 0)
  6.   (if (not rescan)
  7.     (scan)
  8.   )
  9.   (setq lst lay_lst)
  10.   (if blk_lst
  11.     (foreach x blk_lst
  12.       (if (not (member x lst))
  13.         (setq lst (cons x lst))
  14.       )
  15.     )
  16.   )
  17.   (if ent_lst
  18.     (foreach x ent_lst
  19.       (if (not (member x lst))
  20.         (setq lst (cons x lst))
  21.       )
  22.     )
  23.   )
  24.   (setq str_lst nil)
  25.   (foreach x lst
  26.     (setq chk$ x)
  27.     (if        (member x lay_lst)
  28.       (setq chk$ (strcat chk$ " L"))
  29.     )
  30.     (if        (member x blk_lst)
  31.       (setq chk$ (strcat chk$ " B"))
  32.     )
  33.     (if        (member x ent_lst)
  34.       (setq chk$ (strcat chk$ " E"))
  35.     )
  36.     (setq str_lst (cons chk$ str_lst))
  37.   )
  38.   (setq str_lst (reverse str_lst))
  39.   (setq nlst nil)
  40.   (foreach x lst (setq nlst (cons (list x x) nlst)))
  41.   (setq nlst (reverse nlst))
  42.   (setq lst nlst)
  43.   (if lst
  44.     (progn
  45.       (if (> (setq dcl_id (load_dialog "cc.dcl")) 0)
  46.         (progn (setq LST_ID 0)
  47.                (setq oldcolor (car (nth LST_ID lst)))
  48.                (setq newcolor (cadr (nth LST_ID lst)))
  49.                (if (not (new_dialog "color" dcl_id))
  50.                  (exit)
  51.                )
  52.                (upd_lstbox "LST_BOX" lst)
  53.                (action_tile
  54.                  "LST_BOX"
  55.                  "(setq LST_ID (fix (atof $value))) (change_colors) "
  56.                )
  57.                (action_tile "new_col" "(get_color) (change_colors)")
  58.                (action_tile "accept" "(done_dialog 1)")
  59.                (action_tile "cancel" "(done_dialog)")
  60.                (action_tile "LOAD" "(load_colors)")
  61.                (action_tile "SAVE" "(save_colors)")
  62.                (change_colors)
  63.                (setq start (start_dialog))
  64.                (if (= start 1)
  65.                  (progn (setq rescan nil) (go_change))
  66.                  (setq rescan T)
  67.                )
  68.         )
  69.         (prompt "\nDialoogbox not found.")
  70.       )
  71.     )
  72.     (alert "No entities in drawing.")
  73.   )
  74.   (setq *error* olderr)
  75.   (princ)
  76. )
  77. (defun go_change (/ tel color1 color2 x ss _lst rst entl kleur nent)
  78.   (prompt "\nCHANGING COLORS")
  79.   (prompt "\nENTITIES...")
  80.   (command "_UNDO" "_G")
  81.   (foreach x lst
  82.     (if        (member (car x) ent_lst)
  83.       (progn (setq color1 (car x))
  84.              (setq color2 (cadr x))
  85.              (if (/= color1 color2)
  86.                (progn (prompt (strcat "\nChanging color "
  87.                                       color1               " to color "
  88.                                       color2               "."
  89.                                      )
  90.                       )
  91.                       (setq ss (cdr (assoc (fix (atof color1)) sslst)))
  92.                       (command "_CHPROP" ss "" "_COLOR" color2 "")
  93.                )
  94.              )
  95.       )
  96.     )
  97.   )
  98.   (princ "done")
  99.   (prompt "\nBLOCKS...")
  100.   (setq _lst lst)
  101.   (foreach x _lst
  102.     (setq color1 (car x))
  103.     (setq color2 (cadr x))
  104.     (if        (and (member color1 blk_lst) (/= color1 color2))
  105.       (progn
  106.         (setq rst 1)
  107.         (while (setq blk (tblnext "BLOCK" rst))
  108.           (setq rst nil)
  109.           (setq ent (dxf -2 blk))
  110.           (setq entl (entget ent))
  111.           (setq        kleur (dxf 62 entl)
  112.                 nent  ent
  113.           )
  114.           (if (and kleur (= kleur (fix (atof color1))))
  115.             (progn (setq entl (subst (cons 62 (fix (atof color2)))
  116.                                      (assoc 62 entl)
  117.                                      entl
  118.                               )
  119.                    )
  120.                    (entmod entl)
  121.             )
  122.           )
  123.           (while (setq nent (entnext nent))
  124.             (if        (/= "SEQEND" (dxf 0 (setq entl (entget nent))))
  125.               (progn (setq kleur (dxf 62 entl))
  126.                      (if (and kleur (= kleur (fix (atof color1))))
  127.                        (progn (setq entl (subst        (cons 62 (fix (atof color2)))
  128.                                                 (assoc 62 entl)
  129.                                                 entl
  130.                                          )
  131.                               )
  132.                               (entmod entl)
  133.                        )
  134.                      )
  135.               )
  136.             )
  137.           )
  138.         )
  139.       )
  140.     )
  141.   )
  142.   (princ "done")
  143.   (prompt "\nLAYERS...")
  144.   (foreach x lst
  145.     (setq color1 (car x))
  146.     (setq color2 (cadr x))
  147.     (setq rst T)
  148.     (if        (and (member color1 lay_lst) (/= color1 color2))
  149.       (while (setq l (tblnext "LAYER" rst))
  150.         (setq col    (rtos (dxf 62 l) 2 0)
  151.               $layer (dxf 2 l)
  152.               rst    nil
  153.         )
  154.         (if (= col color1)
  155.           (command "_LAYER" "_COLOR" (fix (atof color2)) $layer "")
  156.         )
  157.       )
  158.     )
  159.   )
  160.   (princ "done.")
  161.   (command "_regen")
  162.   (command "_UNDO" "_END")
  163.   (initget "")
  164.   (command "_REDRAW")
  165.   (princ)
  166. )
  167. (defun upd_lstbox (k$ lst /)
  168.   (if lst
  169.     (progn (start_list k$)
  170.            (foreach x str_lst (add_list x))
  171.            (end_list)
  172.     )
  173.     (progn (start_list k$) (add_list "") (end_list))
  174.   )
  175. )
  176. (defun draw_color (oldcolnr newcolnr /)
  177.   (start_image "old_col")
  178.   (fill_image
  179.     0
  180.     0
  181.     (dimx_tile "old_col")
  182.     (dimy_tile "old_col")
  183.     (fix (atof oldcolnr))
  184.   )
  185.   (end_image)
  186.   (start_image "new_col")
  187.   (fill_image
  188.     0
  189.     0
  190.     (dimx_tile "new_col")
  191.     (dimy_tile "new_col")
  192.     (fix (atof newcolnr))
  193.   )
  194.   (end_image)
  195.   (set_tile "newnum" "")
  196.   (set_tile "oldnum" "")
  197.   (set_tile "newnum" newcolnr)
  198.   (set_tile "oldnum" oldcolnr)
  199. )
  200. (defun change_colors ()
  201.   (setq oldcolor (car (nth LST_ID lst)))
  202.   (setq newcolor (cadr (nth LST_ID lst)))
  203.   (draw_color oldcolor newcolor)
  204. )
  205. (defun get_color (/)
  206.   (setq vnewcolor newcolor)
  207.   (setq newcolor (acad_colordlg (fix (atof vnewcolor))))
  208.   (if (not newcolor)
  209.     (setq newcolor vnewcolor)
  210.     (progn (setq newcolor (rtos newcolor 2 0))
  211.            (setq oldnr (assoc oldcolor lst))
  212.            (setq vnewcolor newcolor
  213.                  nlst           nil
  214.            )
  215.            (setq lst (subst (list oldcolor newcolor) oldnr lst))
  216.     )
  217.   )
  218. )
  219. (defun err (s)
  220.   (if (not (member s '("console break" "Function cancelled")))
  221.     (princ (strcat "\nError: " s))
  222.   )
  223.   (setq *error* olderr)
  224.   (command "_UNDO" "_END")
  225.   (command "_U")
  226.   (command "_redraw")
  227.   (princ)
  228. )
  229. (defun dxf (code elist) (cdr (assoc code elist)))
  230. (defun scan (/ rst l col)
  231.   (prompt "\nSCANNING DRAWING (This may take a while)")
  232.   (prompt "\nLAYERS...")
  233.   (setq        lay_lst        nil
  234.         rst T
  235.   )
  236.   (while (setq l (tblnext "LAYER" rst))
  237.     (setq col (dxf 62 l)
  238.           rst nil
  239.     )
  240.     (if        (not (member (rtos col 2 0) lay_lst))
  241.       (setq lay_lst (cons (rtos col 2 0) lay_lst))
  242.     )
  243.   )
  244.   (princ "done.")
  245.   (setq        sslst nil
  246.         ent_lst        nil
  247.         blk_lst        nil
  248.         lst nil
  249.         rst T
  250.   )
  251.   (prompt "\nBLOCKS...")
  252.   (while (setq blk (tblnext "BLOCK" rst))
  253.     (setq rst nil)
  254.     (setq nent (dxf -2 blk))
  255.     (while (setq nent (entnext nent))
  256.       (setq entl (entget nent))
  257.       (if (and (setq kleur (dxf 62 entl))
  258.                (/= kleur 0)
  259.                (/= (dxf 0 entl) "SEQEND")
  260.           )
  261.         (progn (setq kleur$ (rtos kleur 2 0))
  262.                (if (not (member kleur$ blk_lst))
  263.                  (setq blk_lst (cons kleur$ blk_lst))
  264.                )
  265.         )
  266.       )
  267.     )
  268.   )
  269.   (princ "done.")
  270.   (prompt "\nENTITY...")
  271.   (if (setq ent (entnext))
  272.     (progn (setq el (entget ent))
  273.            (setq col (dxf 62 el))
  274.            (if col
  275.              (progn (setq col$ (rtos col 2 0))
  276.                     (if        (not (member col$ ent_lst))
  277.                       (progn (setq ent_lst (cons col$ ent_lst))
  278.                              (setq sslst
  279.                                     (cons (cons col (ssget "x" (list (cons 62 col))))
  280.                                           sslst
  281.                                     )
  282.                              )
  283.                       )
  284.                     )
  285.              )
  286.            )
  287.            (setq nent ent)
  288.            (while (setq nent (entnext nent))
  289.              (setq el (entget nent))
  290.              (setq col (dxf 62 el))
  291.              (if col
  292.                (progn (setq col$ (rtos col 2 0))
  293.                       (if (not (member col$ ent_lst))
  294.                         (progn (setq ent_lst (cons col$ ent_lst))
  295.                                (setq sslst
  296.                                       (cons (cons col (ssget "x" (list (cons 62 col))))
  297.                                             sslst
  298.                                       )
  299.                                )
  300.                         )
  301.                       )
  302.                )
  303.              )
  304.            )
  305.            (princ "done.")
  306.     )
  307.     (setq ent_lst nil)
  308.   )
  309. )
  310. (prompt "Type CC to start.")
 楼主| 发表于 2003-5-15 14:39:15 | 显示全部楼层
对话框
  1. dcl_settings : default_dcl_settings { audit_level = 3 ; }
  2. color : dialog {
  3.    label = "COLOR-CONVERTER v1.1 (c) " ;
  4.    : row {
  5.       : column {
  6.          spacer_1 ;
  7.          : row {
  8.             : column {
  9.                children_alignment = centered ;
  10.                : text {
  11.                   key = "txt1" ;
  12.                   label = "OLD" ;
  13.                }
  14.                : image_button {
  15.                   color = black ;
  16.                   fixed_height = true ;
  17.                   fixed_width = true ;
  18.                   height = 4 ;
  19.                   key = "old_col" ;
  20.                   width = 10 ;
  21.                }
  22.                : text {
  23.                   key = "oldnum" ;
  24.                   label = "" ;
  25.                }
  26.             }
  27.             : list_box {
  28.               fixed_height = true ;
  29.               fixed_width = true ;
  30.               height = 6 ;
  31.               key = "LST_BOX" ;
  32.               label = "Colors:" ;
  33.               width = 12 ;
  34.             }
  35.             : column {
  36.                children_alignment = centered ;
  37.                : text {
  38.                   key = "txt2" ;
  39.                   label = "NEW" ;
  40.                }
  41.                : image_button {
  42.                   color = black ;
  43.                   fixed_height = true ;
  44.                   fixed_width = true ;
  45.                   height = 4 ;
  46.                   key = "new_col" ;
  47.                   width = 10 ;
  48.                }
  49.                : text {
  50.                   key = "newnum" ;
  51.                   label = "" ;
  52.                }
  53.             }
  54.          }
  55.          : row {
  56.          }
  57.       }
  58.    }
  59.    spacer_1 ;
  60.    ok_cancel ;
  61. }
  62.
已领礼包: 138个
发表于 2020-1-17 19:24:13 | 显示全部楼层
LAYERS...done.
BLOCKS...done.
ENTITY...done.
命令:
GMT+8, 2026-11-3 02:12 , Processed in 0.546231 second(s), 37 queries , Gzip On.
