查看: 790|回复: 0
[LISP函数]:如何将CAD每次算出的面积提取到excel文件里?
发表于 2006-4-25 10:10:37 | 显示全部楼层 |阅读模式
如何将CAD每次算出的面积提取到excel文件里?请教高手帮帮忙修改下面的lisp  ,不胜感激!
;面积计算
;haa.lsp(hatch area)
;version1.0 by huagqin
(defun *error* (msg0)
(prin1)
(defun c:haa()
(setq total 0)
(setq ss1 (ssget '((-4 . "<or")(0 . "polyline") (70 . 1) (-4 . "or>"))))
(if (= ss1 nil)
(progn (prompt "\n没有选中任何物体!!!")
(prin1))
(progn (do_haa))
(prin1)
(defun do_haa()
(setq n (sslength ss1))
(setq m 0)
(while (< m n)
(setq s1 (ssname ss1 m))
(command "area" "o" s1 )
(command save s1 to "E:\\1.txt")
(setq haa (getvar "area"))
(setq total (+ total haa))
(setq m (1+ m))
(setq total (rtos total 2 3))
(princ "\n 总面积为")
(princ total)
(princ)
GMT+8, 2026-11-22 08:32 , Processed in 0.333992 second(s), 10 queries , Gzip On, File On.
