查看: 1237|回复: 1
[转贴]:参数化螺栓螺母程序
发表于 2006-5-2 20:43:46 | 显示全部楼层 |阅读模式
从一个网站上看得这段程序,那位大侠能给我指导一下,怎么能在cad2006下运行!急用!开 始
参数分析
判断
螺 母
垫 片
螺 栓
结 束
  否
是
Private Sub canshu_Click()
End Sub
Private Sub CmdExit_Click()
Unload Me
End Sub
Private Sub CmdOk_Click()
'检查参数赋值情况
If TextX.Text = "" Or TextY.Text = "" Or TextZ.Text = "" Then
MsgBox "请在屏幕选起点!", vbExclamation, "警告"
Exit Sub
End If
'定义直线对象
Dim objLine01, ObjLine02, ObjLine03, ObjLine04, ObjLine05, ObjLine06, ObjLine07, ObjLine08, ObjLine09, ObjLine10, ObjLine11, ObjLine12, ObjLine13, ObjLine14, ObjLine15 As AcadLine
'定义数组变量,作为各顶点的坐标
Dim Pt01(2) As Double:Dim Pt02(2) As Double:Dim Pt03(2) As Double
Dim Pt04(2) As Double:Dim Pt05(2) As Double:Dim Pt06(2) As Double
Dim Pt07(2) As Double:Dim Pt08(2) As Double:Dim Pt09(2) As Double
Dim Pt10(2) As Double:Dim Pt11(2) As Double:Dim Pt12(2) As Double
Dim Pt13(2) As Double:Dim Pt14(2) As Double:Dim Pt15(2) As Double
Dim Pt16(2) As Double:Dim Pt17(2) As Double:Dim Pt18(2) As Double
Dim Pt19(2) As Double:Dim Pt20(2) As Double:Dim Pt21(2) As Double
Dim Pt22(2) As Double:Dim Pt23(2) As Double:Dim d, l, b As Double
Dim x, y, z As Variant
x = TextX: y = TextY: z = TextZ
'检查参数赋值情况
If TextZhiJ.Text = "" Or TextChangD.Text = "" Then
MsgBox "参数不能为空,请检查参数的输入.", vbExclamation, "警告"
Exit Sub
End If
d = TextZhiJ: l = TextChangD
If d = 5 Then
MsgBox "螺栓长度应为:GB5780 25~50; GB5781 10~40", vbExclamation, "警告"
b = 16
If l < 16 Or l > 50 Then
Exit Sub
End If
End If
If d = 6 Then
MsgBox "螺栓长度应为:GB5780 30~60; GB5781 12~50", vbExclamation, "警告"
b = 18
If l < 18 Or l > 60 Then
Exit Sub
End If
End If
If d = 8 Then
MsgBox "螺栓长度应为:GB5780 35~80; GB5781 16~65", vbExclamation, "警告"
b = 22
If l < 22 Or l > 80 Then
Exit Sub
End If
End If
If d = 10 Then
MsgBox "螺栓长度应为:GB5780 40~100; GB5781 20~80", vbExclamation, "警告"
b = 26
If l < 26 Or l > 100 Then
Exit Sub
End If
End If
If d = 12 Then
MsgBox "螺栓长度应为:GB5780 45~120; GB5781 25~100", vbExclamation, "警告"
b = 30
If l < 30 Or l > 120 Then
Exit Sub
End If
End If
If d = 16 Then
MsgBox "螺栓长度应为:GB5780 55~160; GB5781 35~100", vbExclamation, "警告"
b = 38
If l < 38 Or l > 160 Then
Exit Sub
End If
End If
If d = 20 Then
MsgBox "螺栓长度应为:GB5780 65~200; GB5781 40~100", vbExclamation, "警告"
b = 40
If l < 40 Or l > 200 Then
Exit Sub
End If
End If
If d = 24 Then
MsgBox "螺栓长度应为:GB5780 80~240; GB5781 50~100", vbExclamation, "警告"
b = 54
If l < 54 Or l > 240 Then
Exit Sub
End If
End If
If d = 30 Then
MsgBox "螺栓长度应为:GB5780 90~300; GB5781 60~100", vbExclamation, "警告"
b = 66
If l < 66 Or l > 300 Then
Exit Sub
End If
End If
If d = 36 Then
MsgBox "螺栓长度应为:GB5780 110~300; GB5781 70~100", vbExclamation, "警告"
b = 78
If l < 78 Or l > 300 Then
Exit Sub
End If
End If
If d = 42 Then
MsgBox "螺栓长度应为:GB5780 160~420; GB5781 80~420", vbExclamation, "警告"
b = 96
If l < 96 Or l > 420 Then
Exit Sub
End If
End If
If d = 48 Then
MsgBox "螺栓长度应为:GB5780 180~480; GB5781 90~480", vbExclamation, "警告"
b = 108
If l < 108 Or l > 480 Then
Exit Sub
End If
End If
'判断语句
If d <> 5# And d <> 6 And d <> 8 And d <> 10 And d <> 12 And d <> 16 And d <> 20 And d <> 24 And d <> 30 And d <> 36 And d <> 42 And d <> 48 Then
MsgBox "螺栓直径可能为5,6,8,10,12,16,20,24,30,36,42,48?", vbExclamation, "警告"
Exit Sub
End If
'根据螺栓直径,长度计算各顶点的坐标
Pt01(0) = x: Pt01(1) = y: Pt01(2) = z
'计算各顶点的坐标
Pt02(0) = x: Pt02(1) = y + 0.5 * d: Pt02(2) = z
Pt03(0) = x: Pt03(1) = y + 1.5 * d: Pt03(2) = z
Pt04(0) = x: Pt04(1) = y + 2 * d: Pt04(2) = z
Pt05(0) = x + 0.7 * d: Pt05(1) = y + 2 * d: Pt05(2) = z
Pt06(0) = x + 0.7 * d: Pt06(1) = y + 1.5 * d: Pt06(2) = z
Pt07(0) = x + 0.7 * d: Pt07(1) = y + 0.5 * d: Pt07(2) = z
Pt08(0) = x + 0.7 * d: Pt08(1) = y: Pt08(2) = z
Pt09(0) = x + 0.7 * d + l - b: Pt09(1) = y + 0.5 * d: Pt09(2) = z
Pt10(0) = x + 0.7 * d + l - b: Pt10(1) = y + 1.425 * d: Pt10(2) = z
Pt11(0) = x + 0.7 * d + l - b: Pt11(1) = y + 0.575 * d: Pt11(2) = z
Pt12(0) = x + 0.7 * d + l - b: Pt12(1) = y + 1.5 * d: Pt12(2) = z
Pt13(0) = x + 0.7 * d + l: Pt13(1) = y + 1.5 * d: Pt13(2) = z
Pt14(0) = x + 0.7 * d + l: Pt14(1) = y + 1.425 * d: Pt14(2) = z
Pt15(0) = x + 0.7 * d + l: Pt15(1) = y + 0.575 * d: Pt15(2) = z
Pt16(0) = x + 0.7 * d + l: Pt16(1) = y + 0.5 * d: Pt16(2) = z
Pt17(0) = x - 5: Pt17(1) = y + 1# * d: Pt17(2) = z
Pt18(0) = x + 0.7 * d + l + 5: Pt18(1) = y + 1# * d: Pt18(2) = z
Pt19(0) = x + 3.5 * d + l + 5: Pt19(1) = y + 1# * d: Pt19(2) = z
Pt20(0) = x + 2# * d + l + 5: Pt20(1) = y + 1# * d: Pt20(2) = z
Pt21(0) = x + 5# * d + l + 5: Pt21(1) = y + 1# * d: Pt21(2) = z
Pt22(0) = x + 3.5 * d + l + 5: Pt22(1) = y - 0.5 * d: Pt22(2) = z
Pt23(0) = x + 3.5 * d + l + 5: Pt23(1) = y + 2.5 * d: Pt23(2) = z
'加载线形
'定义线形
Dim entry As AcadLineType:Dim found As Boolean:Dim ltName(0 To 2) As String
Dim i As Integer
    found = False
    '准备添加的3种线型
    ltName(0) = "BORDER"
    ltName(1) = "CENTER"
    ltName(2) = "DASHDOT"
    For i = 0 To 2
        '搜寻要添加的线型在线型集合中是否已存在
        For Each entry In ThisDrawing.Linetypes
            If StrComp(entry.Name, ltName(i), 1) = 0 Then
                found = True
                Exit For
            End If
        Next
        '如果不存在则将其从线型文件acadiso.lin中加载
        If Not (found) Then
            ThisDrawing.Linetypes.Load ltName(i), "acadiso.lin"
        End If
    Next
'创建图层
Dim objLayer As AcadLayer
'粗实线
Set objLayer = ThisDrawing.Layers.Add("粗实线")
objLayer.color = acWhite
objLayer.Linetype = "Continuous"
objLayer.Lineweight = acLnWt030
ThisDrawing.ActiveLayer = objLayer
Set objLine01 = ThisDrawing.ModelSpace.AddLine(Pt01, Pt04)
Set ObjLine02 = ThisDrawing.ModelSpace.AddLine(Pt04, Pt05)
Set ObjLine03 = ThisDrawing.ModelSpace.AddLine(Pt05, Pt08)
Set ObjLine04 = ThisDrawing.ModelSpace.AddLine(Pt08, Pt01)
Set ObjLine05 = ThisDrawing.ModelSpace.AddLine(Pt02, Pt07)
Set ObjLine06 = ThisDrawing.ModelSpace.AddLine(Pt03, Pt06)
Set ObjLine07 = ThisDrawing.ModelSpace.AddLine(Pt06, Pt13)
Set ObjLine08 = ThisDrawing.ModelSpace.AddLine(Pt13, Pt16)
Set ObjLine09 = ThisDrawing.ModelSpace.AddLine(Pt16, Pt07)
Set ObjLine10 = ThisDrawing.ModelSpace.AddLine(Pt09, Pt12)
'定义动态数组
Dim objPline As AcadLWPolyline:Dim ptArr() As Double
Dim number As Integer:Dim width As Double:Dim angle As Variant
Const PI = 3.1415926
width = 0
angle = 0
number = 6
'顶点的个数为number,需要2*number个元素来表示
ReDim ptArr(2 * number - 1)
'每条边对应的角度
Dim ang As Double
ang = 2 * PI / number
'为点的坐标数组赋值
Dim n As Integer
For n = 0 To 2 * number - 1
If n Mod 2 = 0 Then
   ptArr(n) = Pt19(0) + d * Cos(((n + 1) / 2) * ang)
   ElseIf n Mod 2 <> 0 Then
   ptArr(n) = Pt19(1) + d * Sin((n / 2) * ang)
End If
Next n
'创建多线段,并调整其特征
Set objPline = ThisDrawing.ModelSpace.AddLightWeightPolyline(ptArr)
objPline.Closed = True
objPline.Rotate Pt19, angle
objPline.Linetype = "ByLayer"
objPline.Update
'画圆
Dim objCir As AcadCircle
Set objCir = ThisDrawing.ModelSpace.AddCircle(Pt19, d * Sin(PI / 3))
'细实线
Set objLayer = ThisDrawing.Layers.Add("细实线")
objLayer.Lineweight = acLnWt009
Set ObjLine11 = ThisDrawing.ModelSpace.AddLine(Pt10, Pt14)
ObjLine11.Linetype = "ByLayer"
Set ObjLine12 = ThisDrawing.ModelSpace.AddLine(Pt11, Pt15)
ObjLine12.Linetype = "ByLayer"
'点划线
Set objLayer = ThisDrawing.Layers.Add("点划线")
objLayer.Linetype = "DASHDOT"
'连接对应的点
Set ObjLine13 = ThisDrawing.ModelSpace.AddLine(Pt17, Pt18)
ObjLine13.Linetype = "ByLayer"
Set ObjLine14 = ThisDrawing.ModelSpace.AddLine(Pt20, Pt21)
ObjLine14.Linetype = "ByLayer"
Set ObjLine15 = ThisDrawing.ModelSpace.AddLine(Pt22, Pt23)
ObjLine15.Linetype = "ByLayer"
'定义螺母的中心点
Dim CenPt(2) As Double
'定义螺母左视图中各点坐标
Dim mPt1(2) As Double:Dim mPt2(2) As Double:Dim mPt3(2) As Double
Dim mPt4(2) As Double:Dim mPt5(2) As Double:Dim mPt6(2) As Double
Dim mPt7(2) As Double:Dim mPt8(2) As Double
'定义螺母左视图中心线端点
Dim mPt9(2) As Double:Dim mPt10(2) As Double
'定义螺母主视图中心线端点
Dim mPt11(2) As Double:Dim mPt12(2) As Double:Dim mPt13(2) As Double
Dim mPt14(2) As Double
'定义直线对象
Dim mObjLine(8) As AcadLine
'计算螺母各点的坐标
'定义中心点
CenPt(0) = x + 2# * d + l + 5: CenPt(1) = y - 3# * d: CenPt(2) = z
'螺母线端点
mPt11(0) = x + 3.5 * d + l + 5: mPt11(1) = y - 3# * d: mPt11(2) = z
mPt12(0) = x + 0.5 * d + l + 5: mPt12(1) = y - 3# * d: mPt12(2) = z
mPt13(0) = x + 2# * d + l + 5: mPt13(1) = y - 1.5 * d: mPt13(2) = z
mPt14(0) = x + 2# * d + l + 5: mPt14(1) = y - 4.5 * d: mPt14(2) = z
mPt9(0) = x + 4.5 * d + l + 5: mPt9(1) = y - 3# * d: mPt9(2) = z
mPt10(0) = x + 6.5 * d + l + 5: mPt10(1) = y - 3# * d: mPt10(2) = z
mPt1(0) = x + 5# * d + l + 5: mPt1(1) = y - 2# * d: mPt1(2) = z
mPt2(0) = x + 5# * d + l + 5: mPt2(1) = y - 2.5 * d: mPt2(2) = z
mPt3(0) = x + 5# * d + l + 5: mPt3(1) = y - 3.5 * d: mPt3(2) = z
mPt4(0) = x + 5# * d + l + 5: mPt4(1) = y - 4# * d: mPt1(2) = z
mPt5(0) = x + 5.8 * d + l + 5: mPt5(1) = y - 4# * d: mPt5(2) = z
mPt6(0) = x + 5.8 * d + l + 5: mPt6(1) = y - 3.5 * d: mPt6(2) = z
mPt7(0) = x + 5.8 * d + l + 5: mPt7(1) = y - 2.5 * d: mPt7(2) = z
mPt8(0) = x + 5.8 * d + l + 5: mPt8(1) = y - 2# * d: mPt8(2) = z
Dim objPline1 As AcadLWPolyline:Dim ptArr1() As Double
ReDim ptArr1(2 * number - 1)
angle = 0
'为点的坐标数组赋值
If n Mod 2 = 0 Then
   ptArr1(n) = CenPt(0) + d * Cos(((n + 1) / 2) * ang)
   ptArr1(n) = CenPt(1) + d * Sin((n / 2) * ang)
End If
Next n
Set objPline1 = ThisDrawing.ModelSpace.AddLightWeightPolyline(ptArr1)
objPline1.Closed = True
objPline1.Rotate CenPt, angle
objPline1.Linetype = "ByLayer"
objPline1.Update
Dim objCir1, objCir2 As AcadCircle
'画圆
Set objCir1 = ThisDrawing.ModelSpace.AddCircle(CenPt, d * Sin(PI / 3))
Set objCir2 = ThisDrawing.ModelSpace.AddCircle(CenPt, 0.85 * d / 2#)
Set mObjLine(0) = ThisDrawing.ModelSpace.AddLine(mPt1, mPt4)
mObjLine(0).Linetype = "ByLayer"
Set mObjLine(1) = ThisDrawing.ModelSpace.AddLine(mPt4, mPt5)
mObjLine(1).Linetype = "ByLayer"
Set mObjLine(2) = ThisDrawing.ModelSpace.AddLine(mPt5, mPt8)
mObjLine(2).Linetype = "ByLayer"
Set mObjLine(3) = ThisDrawing.ModelSpace.AddLine(mPt8, mPt1)
mObjLine(3).Linetype = "ByLayer"
Set mObjLine(4) = ThisDrawing.ModelSpace.AddLine(mPt2, mPt7)
mObjLine(4).Linetype = "ByLayer"
Set mObjLine(5) = ThisDrawing.ModelSpace.AddLine(mPt3, mPt6)
mObjLine(5).Linetype = "ByLayer"
'创建圆弧弧度值
Dim arcObj As AcadArc:Dim sAngDegree As Double:Dim eAngDegree As Double
sAngDegree =90#
eAngDegree = 360#
'将角度值转为弧度值
Dim sAngRadian As Double:Dim eAngRadian As Double
sAngRadian = sAngDegree * 3.141592 / 180#
eAngRadian = eAngDegree * 3.141592 / 180#
'在模型空间创建圆弧对象
Set arcObj = ThisDrawing.ModelSpace.AddArc(CenPt, d / 2, sAngRadian, eAngRadian)
arcObj.Linetype = "ByLayer"
Set mObjLine(6) = ThisDrawing.ModelSpace.AddLine(mPt11, mPt12)
mObjLine(6).Linetype = "ByLayer"
Set mObjLine(7) = ThisDrawing.ModelSpace.AddLine(mPt13, mPt14)
mObjLine(7).Linetype = "ByLayer"
Set mObjLine(8) = ThisDrawing.ModelSpace.AddLine(mPt9, mPt10)
mObjLine(8).Linetype = "ByLayer"
'创建垫片
'定义线段
Dim dobjLine(12) As AcadLine:Dim darcObj(1) As AcadCircle
'定义各点并赋值
Dim dPt1(2) As Double:Dim dPt2(2) As Double:Dim dPt3(2) As Double
Dim dPt4(2) As Double:Dim dPt5(2) As Double:Dim dPt6(2) As Double
Dim dPt7(2) As Double:Dim dPt8(2) As Double:Dim dPt9(2) As Double
Dim dPt10(2) As Double:Dim dCent(2) As Double:Dim dCentL(2) As Double
Dim dCentR(2) As Double:Dim dCentT(2) As Double:Dim dCentB(2) As Double
dCent(0) = x: dCent(1) = y - 3# * d: dCent(2) = z
dCentL(0) = x - 1# * d - 13: dCentL(1) = y - 3# * d: dCentL(2) = z
dCentR(0) = x + 1# * d + 13: dCentR(1) = y - 3# * d: dCentR(2) = z
dCentT(0) = x: dCentT(1) = y - 2# * d + 13: dCentT(2) = z
dCentB(0) = x: dCentB(1) = y - 4# * d - 13: dCentB(2) = z
dPt1(0) = x - 1# * d + 1# * l: dPt1(1) = y - 2# * d + 3: dPt1(2) = z
dPt2(0) = x - 1# * d + 1# * l: dPt2(1) = y - 2.5 * d + 2: dPt2(2) = z
dPt3(0) = x - 1# * d + 1# * l: dPt3(1) = y - 3.5 * d - 2: dPt3(2) = z
dPt4(0) = x - 1# * d + 1# * l: dPt4(1) = y - 4 * d - 3: dPt4(2) = z
dPt5(0) = x - 1# * d + 0.15 * d + l: dPt5(1) = y - 4 * d - 3: dPt5(2) = z
dPt6(0) = x - 1# * d + 0.15 * d + l: dPt6(1) = y - 3.5 * d - 2: dPt6(2) = z
dPt7(0) = x - 1# * d + 0.15 * d + l: dPt7(1) = y - 2.5 * d + 2: dPt7(2) = z
dPt8(0) = x - 1# * d + 0.15 * d + l: dPt8(1) = y - 2# * d + 3: dPt8(2) = z
dPt9(0) = x - 1# * d + 1# * l - 5: dPt9(1) = y - 3# * d: dPt9(2) = z
dPt10(0) = x - 1# * d + 0.15 * d + l + 5: dPt10(1) = y - 3# * d: dPt10(2) = z
'连结各点
Set dobjLine(0) = ThisDrawing.ModelSpace.AddLine(dPt1, dPt2)
dobjLine(0).Linetype = "ByLayer"
Set dobjLine(1) = ThisDrawing.ModelSpace.AddLine(dPt2, dPt3)
dobjLine(1).Linetype = "ByLayer"
Set dobjLine(2) = ThisDrawing.ModelSpace.AddLine(dPt3, dPt4)
dobjLine(2).Linetype = "ByLayer"
Set dobjLine(3) = ThisDrawing.ModelSpace.AddLine(dPt4, dPt5)
dobjLine(3).Linetype = "ByLayer"
Set dobjLine(4) = ThisDrawing.ModelSpace.AddLine(dPt5, dPt6)
dobjLine(4).Linetype = "ByLayer"
Set dobjLine(5) = ThisDrawing.ModelSpace.AddLine(dPt6, dPt7)
dobjLine(5).Linetype = "ByLayer"
Set dobjLine(9) = ThisDrawing.ModelSpace.AddLine(dPt7, dPt8)
dobjLine(9).Linetype = "ByLayer"
Set dobjLine(10) = ThisDrawing.ModelSpace.AddLine(dPt8, dPt1)
dobjLine(10).Linetype = "ByLayer"
Set dobjLine(11) = ThisDrawing.ModelSpace.AddLine(dPt2, dPt7)
dobjLine(11).Linetype = "ByLayer"
Set dobjLine(12) = ThisDrawing.ModelSpace.AddLine(dPt3, dPt6)
dobjLine(12).Linetype = "ByLayer"
Set darcObj(0) = ThisDrawing.ModelSpace.AddCircle(dCent, 0.5 * d + 2)
Set darcObj(1) = ThisDrawing.ModelSpace.AddCircle(dCent, d + 3)
Set dobjLine(6) = ThisDrawing.ModelSpace.AddLine(dPt9, dPt10)
dobjLine(6).Linetype = "ByLayer"
Set dobjLine(7) = ThisDrawing.ModelSpace.AddLine(dCentL, dCentR)
dobjLine(7).Linetype = "ByLayer"
Set dobjLine(8) = ThisDrawing.ModelSpace.AddLine(dCentT, dCentB)
dobjLine(8).Linetype = "ByLayer"
Dim hatchObj As AcadHatch:Dim patternName As String:Dim PatternType As Long
Dim assocVar As Boolean
'定义剖面线的模式
patternName = "ANSI31"
PatternType = 0
'设定剖面线与外轮廓线相关联
assocVar = True
'在模型空间创建剖面线对象
Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, assocVar)
Dim outerLoop1(0 To 3) As AcadEntity:Dim outerLoop2(0 To 3) As AcadEntity
'创建外部轮廓线
Set outerLoop1(0) = dobjLine(0) :Set outerLoop1(1) = dobjLine(11)
Set outerLoop1(2) = dobjLine(9) :Set outerLoop1(3) = dobjLine(10)
Set outerLoop2(0) = dobjLine(2) :Set outerLoop2(1) = dobjLine(3)
Set outerLoop2(2) = dobjLine(4) :Set outerLoop2(3) = dobjLine(12)
hatchObj.AppendOuterLoop outerLoop1
hatchObj.AppendOuterLoop outerLoop2
hatchObj.Evaluate
ThisDrawing.Regen True
ZoomAll
Unload Me
End Sub
Private Sub CmdPickstart_Click()
Dim PtPick As Variant
FormMain.Hide
PtPick = ThisDrawing.Utility.GetPoint(, "请在屏幕选起点:")
TextX = PtPick(0): TextY = PtPick(1): TextZ = PtPick(2)
FormMain.Show
End Sub
Private Sub UserForm_Click()
End Sub
Private Sub UserForm_Initialize()
'螺栓参数默认值
TextZhiJ.Text = "": TextChangD.Text = ""
End Sub
Private Sub weizhi_Click()
End Sub
发表于 2006-5-4 11:35:16 | 显示全部楼层
定义剖面线的模式
PatternType = 0
'设定剖面线与外轮廓线相关联
assocVar = True
'在模型空间创建剖面线对象
'创建外部轮廓线
hatchObj.Evaluate
ZoomAll
Unload Me
End Sub
FormMain.Hide
FormMain.Show
End Sub
End Sub
'螺栓参数默认值
End Sub
End Sub
比较实用啊
GMT+8, 2026-11-22 09:06 , Processed in 0.405059 second(s), 12 queries , Gzip On, File On.
