查看: 1078|回复: 1
[编程申请]:做一个左手键的lisp
发表于 2006-5-5 08:18:28 | 显示全部楼层 |阅读模式
发现现在做图真的有点矛盾,左手点键盘,右手就忙不过来了,有的快捷键在左右两边的就点一下键盘,手又抓一下鼠标,哥哥姐姐能来能给我写个左手键的lisp,可以在现有的快捷键和左手键间撤换,他们之间不能矛盾,比如:两种快捷键之转换的快捷键一定要在两个方式中都通用!
A,      *ARC
AD,     *ATTEDIT
AA,     *AREA
AG,     *ALIGN
AS,     *LIST
AR,     *ARRAY
AT,     *MATCHPROP
ATT,    *ATTDEF
AV,     *DSVIEWER
AC,     *AI_MOLC
B,      *BLOCK
BD,     *BOUNDARY
BR,     *BREAK
C,      *CIRCLE
CC,     *CIRCLE
CA,     *CAL
CF,     *CHAMFER
CT,     *CUTCLIP
CR,     *COLOR
D,      *DIMSTYLE
DA,     *DIMANGULAR
DB,     *DIMBASELINE
DC,     *DIMCONTINUE
DD,     *DIMDIAMETER
DF,     *DIMLINEAR
DG,     *DIMALIGNED
DR,     *DIMRADIUS
DS,     *DSETTINGS
DT,     *DIST
DV,     *DVIEW
DZ,     *LEADER
E,      *ERASE
ED,     *DDEDIT
ES,     *ELLIPSE
EG,     *LENGTHEN
EX,     *EXTEND
ER,     *LAYER
ET,     *LAYON
EF, *LAYOFF
EW,     *LAYWALK
EC,     *LAYCUR
EE,     *LINETYPE
F,      *LINE
FF, *OFFSET
FFF,    *FILLET
FA,     *OPEN
FE,     *EXPORT
FQ,     *POLYGON
FG,     *PLINE
FGE,    *PEDIT
FW,     *LINEWEIGHT
FD,     *FIND
FR, *PLOT
FT,     *FILTER
FC,     *COPY
FV,     *MOVE
FX,     *PROPERTIES
G,      *GROUP
Q, *QUIT
QA, *APPLOAD
QE, *MENULOAD
QR, *OPTIONS
R,      *PAN
RW,     *REDRAW
RA,     *RAY
RD,     *REDO
RE,     *REGEN
REE,    *RENAME
REC,    *RECTANG
RT,     *ROTATE
RR,     *RENDER
SA,     *SAVEAS
SV,     *QSAVE
SC,     *SCALE
SD,     *DDSELECT
SS, *BHATCH
ST,     *STYLE
TR,     *TRIM
TB,     *TOOLBAR
TE,     *TOLERANCE
T,      *TEXT
TT,     *MTEXT
V,       *UNDO
VV,     *UNITS
VW,     *VIEW
VR, *_VPORTS
W,      *WBLOCK
WW,     *MIRROR
WE,     *WEDGE
X,      *EXPLODE
XA,     *XATTACH
XB,     *XBIND
XC,     *XCLIP
XX,     *XLINE
XT, *EXIT
Z,      *ZOOM
上面的仅供参考(不知道全不全)
发表于 2006-5-22 15:36:05 | 显示全部楼层
楼上这个很解决吧!!
比如说用lsp去改名acad.pgp
两个:acad.pgp;acad2.pgp
程序思路如下:
acad2.pgp--->acad.tmp
acad.pgp--->acad2.pgp
acad.tmp--->acad.pgp
更新acad.pgp就可以了!
GMT+8, 2026-11-22 10:50 , Processed in 0.499623 second(s), 12 queries , Gzip On, File On.
