查看: 1110|回复: 0
[ARX函数]:如何修改AcDbText实体,并马上显示修改结果?
发表于 2006-5-10 16:38:19 | 显示全部楼层 |阅读模式
各位,今天有时间测试了一下各位提出的方法,结果还是不行!
现把程序粘贴如下:
        //定义变量
        AcDbObjectId transId;
        AcDbObjectIdArray objIdArray;
        /*---------------获取前面选中文件的图形数据库---------------*/
        AcDbDatabase *pDb = new AcDbDatabase(Adesk::kFalse,true);
        Acad::ErrorStatus es = pDb->readDwgFile(filepath,_SH_DENYNO,false);
        if (es!=Acad::eOk)
                acutPrintf("\nThe file %s cannot be opend",filepath);
                return;
        AcDbBlockTable *pBlockTbl;
        pDb->getSymbolTable(pBlockTbl,AcDb::kForRead);
        AcDbBlockTableRecord *pBlockTblRec;
        pBlockTbl->getAt(ACDB_MODEL_SPACE,pBlockTblRec,AcDb::kForWrite);
        pBlockTbl->close();
        //创建遍历器
        AcDbBlockTableRecordIterator *pBTRIterator;
        pBlockTblRec->newIterator(pBTRIterator);
        CString strText;
        for(;!pBTRIterator->done();pBTRIterator->step())
                AcDbEntity *pEnt;
                pBTRIterator->getEntity(pEnt,AcDb::kForWrite);
                if(strcmp(pEnt->isA()->name(),"AcDbText")==0)
                        AcDbText *pText;
                        pText = AcDbText::cast(pEnt);
                        strText = pText->textString();
                        if(strText.Compare(strFindWhat)==0)
                                objIdArray.append(pText->objectId());
                                if(pText->setTextString(strDisplace) != Acad::eOk)
                                        acedAlert("Can't displace text string!");
                                acedAlert(strText);
//                                pText->recordGraphicsModified();
//                                pText->downgradeOpen();
//                                pText->draw();
                        pText->close();
                pEnt->close();
        delete pBTRIterator;
        pBlockTblRec->close();
        if(objIdArray.isEmpty())
                acutPrintf("\n用户所选文件中没有%s",strFindWhat);
                return;
        //保存原数据库、关闭数据库并删除此对象
        pDb->saveAs(filepath);
        delete pDb;
        pDb = NULL;
请各位大侠帮忙,看看程序错在哪里,怎样才能马上显示?
GMT+8, 2026-11-22 08:24 , Processed in 0.450236 second(s), 10 queries , Gzip On, File On.
