查看: 1955|回复: 6
[LISP函数]:计算选定对象的总面积
发表于 2003-5-19 15:32:10 | 显示全部楼层 |阅读模式
;;; AREAM.LSP
;;; Function: Calculates the total area of selected objects
;;; By Jimmy Bergmark
;;; Copyright (C) 1997-2002 JTB World, All Rights Reserved
;;; Website: www.jtbworld.com / http://jtbworld.vze.com
;;; E-mail: info@jtbworld.com / jtbworld@hotmail.com
;;; Tested on AutoCAD 2000
(defun c:aream (/ olderr oldcmdecho errexit undox restore ss1 nr en tot_area)
  (defun errexit (s)
    (restore)
  (defun undox ()
    (command "._undo" "_E")
    (setvar "cmdecho" oldcmdecho)
    (setq *error* olderr)
    (princ)
  (setq olderr  *error*
        restore undox
        *error* errexit
  (setq oldcmdecho (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (command "._UNDO" "_BE")
  (if (setq ss1 (ssget '((-4 . "<OR")
                         (0 . "POLYLINE")
                         (0 . "LWPOLYLINE")
                         (0 . "CIRCLE")
                         (0 . "ELLIPSE")
                         (0 . "SPLINE")
                         (0 . "REGION")
                         (-4 . "OR>")
    (progn
      (setq nr 0)
      (setq tot_area 0.0)
      (setq en (ssname ss1 nr))
      (while en
        (command "._area" "_O" en)
        (setq tot_area (+ tot_area (getvar "area")))
        (setq nr (1+ nr))
      (princ "\nTotal Area = ")
      (princ tot_area)
  (restore)
发表于 2005-2-17 23:43:14 | 显示全部楼层
好,算绿化面积的时候最能用
发表于 2005-2-28 11:36:22 | 显示全部楼层
我不懂如何定义LISP文件,我把你的编码复制到记事本,保存后居然不是LISP文件,到底怎么回事呢?
发表于 2005-3-8 15:04:19 | 显示全部楼层
把后缀,改了就可以了
发表于 2005-3-8 22:33:20 | 显示全部楼层
另存为*.lsp,不要管其他就可以,谢谢楼主!
发表于 2005-3-9 00:27:49 | 显示全部楼层
和晓东的很类似!
和晓东的很类似!不过还是很好用!谢谢
发表于 2005-3-15 11:49:33 | 显示全部楼层
不同的条样曲线组成的图形,发挥不了作用!简单的还可以!
GMT+8, 2026-11-22 10:30 , Processed in 0.318720 second(s), 22 queries , Gzip On, File On.
