查看: 1165|回复: 6
[讨论]:[0519]如何将此倾斜矩形绘制程序简化?
发表于 2006-5-19 18:23:57 | 显示全部楼层 |阅读模式
小弟练习将绘制矩形可以使用倾斜角度方式绘出,
但个人认为程序应该可以简化,
因此放上来请各位高手指点
烦请各位可以提供宝贵的意见~
谢谢~
(defun c:test ()
(setq pt1 (getpoint "\n 长度方向基点:") )
(setq pt2 (getpoint pt1 "\n 长度方向终点:") )
(setq pt3 (getpoint pt2 "\n 宽度方向:") )
(setq ofs (getdist pt2 "\n 宽度距离:") )
(command "_.line" pt1 pt2 "")
(setq en1 (entlast))
(setq ob1 (entget en1))
(command "_.offset" ofs en1 pt3 "" )
(setq en2 (entlast))
(setq ob2 (entget en2))
(command "_.line" (cdr (assoc 10 ob1))  (cdr (assoc 10 ob2) ) "")
(setq en3 (entlast))
(command "_.line" (cdr (assoc 11 ob1))  (cdr (assoc 11 ob2) ) "")
(setq en4 (entlast))
(setq ss (ssadd))
(ssadd en1 ss)
(ssadd en2 ss)
(ssadd en3 ss)
(ssadd en4 ss)
(setq i 0)
  (while (< i (sslength ss))
    (setq ssa-ent (ssname ss i))
    (setq ent-p (cdr (assoc 0 (entget ssa-ent))))
    (if        (not (null ent-p))                ;判断原图元是否已串入多义线
      (if (or (= ent-p "LWPOLYLINE") (= ent-p "POLYLINE"))
                                        ;判断原图元属性
        (command "pedit" ssa-ent "j" ss "" "")
        (command "pedit" ssa-ent "y" "j" ss "" "")
    (setq i (1+ i))
发表于 2006-5-20 07:07:24 | 显示全部楼层
[PHP]
(defun c:test ()
  (setq pt (getpoint "\n选择基点:")
        ang (getangle "\n旋转角度:")
        wid (getdist "\n宽度:")
        hid (getdist "\n高度:"))
  (command "ucs" "w" "ucs" "n" "z" (* (/ ang 3.1415926) 180.0))
  (command "rectang" pt (list (+ (car pt) wid) (+ (cadr pt) hid)))
  (command "ucs" "w")
  (princ)
[/PHP]
发表于 2006-5-20 10:41:20 | 显示全部楼层
改(command  "ucs" "n" "z" (* (/ ang 3.1415926) 180.0))
(command "ucs" "w")
改 (command "ucs" "P")
发表于 2006-5-20 23:20:20 | 显示全部楼层
;;画斜矩形
(defun c:hxjx ()
  (CMDLA0)
   (setvar "cmdecho" 0)
      (setq pa (getpoint "\n第一角点:")
            pb (getpoint "\n第二角点:")
            pc (getpoint "\n第三角点:")
            la (distance pa pb)
            lb (distance pb pc)
            lc (sqrt (+ (* la la) (* lb lb)))
            aa (angle pa pb)                ;计算与x轴的夹角aa
            ab (atan (/ lb la))
            ac (+ aa (/ pi 2))
            pc (Polar  Pa  (+ aa ab)  lc)
            pd (Polar  Pa ac lb)
    (setvar "osmode" 0)
      (command "pline" pa pb pc pd "c")
    (setvar "osmode" 47)
  (CMDLA1)
                 (prompt "<<画斜矩形>>启动命令:hxjx")
                    (princ)
发表于 2006-7-3 15:58:05 | 显示全部楼层
这样可能会舒服一点:
(defun c:jx ()
(CMDLA0)
pb (getcorner pa  "\n第二角点:")
pc (getpoint  pa "\n第三角点:")
la (distance pa pb)
lb (distance pb pc)
ab (atan (/ lb la))
ac (+ aa (/ pi 2))
pd (Polar Pa ac lb)
(setvar "osmode" 0)
(CMDLA1)
(princ)
发表于 2006-7-3 16:23:11 | 显示全部楼层
  1. [FONT=courier new](defun c:test ()
  2.   (cmdla0)
  3.   (setq        ang (UANGLE 1 "" "旋转角度<输入或鼠标直接量取>" ANG nil)
  4.         wid (UDIST 1 "" "宽度<输入或鼠标直接量取>" wid nil)
  5.         hid (UDIST 1 "" "高度<输入或鼠标直接量取>" hid nil)
  6.         os (getvar"osmode")
  7.   )
  8.   (while (setq pt (getpoint "\n选择基点<退出>: "))
  9.     (setvar"osmode"0)
  10.     (command "rectang" pt(list (+ (car pt) wid) (+ (cadr pt) hid)))
  11.     (if        (/= ang 0)
  12.       (command "rotate" "l" "" pt (rad2ang ang))
  13.     )
  14.     (setvar"osmode"os)
  15.   )
  16.   (cmdla1)
  17. )[/FONT]
发表于 2006-7-3 22:22:35 | 显示全部楼层
本人自编了一个,目的是在描地形图居民点时方便,不知是否适合楼主.
;;画斜矩形
(defun c:hxjx ()
            la (distance pa pb)
            lb (distance pb pc)
            ab (atan (/ lb la))
            ac (+ aa (/ pi 2))
            pd (Polar  Pa ac lb)
    (setvar "osmode" 0)
                    (princ)
GMT+8, 2026-11-7 05:48 , Processed in 0.576786 second(s), 41 queries , Gzip On.
