查看: 679|回复: 0
[ARX程序]:求助!!!急急急急!!!!!!!!!!!
发表于 2003-5-21 09:20:47 | 显示全部楼层 |阅读模式
我现在在用ARX做程序!!现在遇到了这样的问题!!在brep例程中给出了如何遍历3dSolid实体的所有面,也给出了如何把一个面划分网格的程序!!可现在我把循环访问实体的所有面,然后在小网格上显示颜色,于是就想把上面两段程序连起来,这就时循环调用面的划分网格程序!!执行中,程序划分了第一个面,在划分第2个面的时候,就不能在划分网格了!!请问怎么解决!!!非常急急急急!!!!!!!!!!!
下面是我给的程序代码:
static void test()
        AcBr::ErrorStatus returnValue=AcBr::eOk;
        Acad::ErrorStatus acadReturnValue = Acad::eOk;
        AcDb3dSolid *pEnt;
        AcGePoint3d pickPnt;
        ads_name ent;
        AcDbObjectId objId;
        AcBrBrep brepEntity;
        AcBrBrepFaceTraverser brepFaceTrav;
        int faceCount;
        AcBrFace brepFace;
        acedEntSel("\n Pick a solid\n", ent, asDblArray(pickPnt));
        acadReturnValue=acdbGetObjectId(objId,ent);
        if(acadReturnValue!= Acad::eOk)
            acutPrintf("\n Error in getting AcDbObjecyId:");
            return ;
        acadReturnValue=acdbOpenObject(pEnt,objId,AcDb::kForRead);
            acutPrintf("\n Error in opening AcDbEntity:");
            return ;
        returnValue=brepEntity.set((const AcDbEntity&)*pEnt);
        if (returnValue != AcBr::eOk)
                acutPrintf("\n Error in AcBrBrep::set:");
                return ;
        returnValue=brepFaceTrav.setBrep(brepEntity);
                acutPrintf("\n Error in AcBrBrepFaceTraverser::setBrep:");
                return ;
        faceCount=0;
        while (!brepFaceTrav.done() && (returnValue == AcBr::eOk))
            returnValue=brepFaceTrav.getFace(brepFace);
                if(returnValue!=AcBr::eOk)
                        acutPrintf("\n Error in AcBrBrepFaceTraverser::getFace:");
                        return ;
                returnValue = faceMesh(brepFace);
                        acutPrintf("\n Error in faceMesh:");
                        return ;
            faceCount++;
                returnValue = brepFaceTrav.next();
                        acutPrintf("\n Error in AcBrBrepFaceTraverser::next:");
                        return ;
        pEnt->close();
        acutPrintf("\n ***brep has %d faces.\n",faceCount);
static AcBr::ErrorStatus
faceMesh(const AcBrFace& faceEntity)
    AcBr::ErrorStatus returnValue = AcBr::eOk;
        // Verify that AcBr was explicitly and not implicitly loaded,
        // by testing ObjectARX functions (which are unavailable unless
        // explicitly loaded)
    if (faceEntity.isA() == NULL)
        acutPrintf("\n faceMesh: AcBrEntity::isA() failed\n");
        return returnValue;
    if (!faceEntity.isKindOf(AcBrFace::desc()))
        acutPrintf("\n faceMesh: AcBrEntity::isKindOf() failed\n");
        return returnValue;
        AcBrEntity* entClass = (AcBrEntity*)&faceEntity;
        AcBrEdge* pEdge = AcBrEdge::cast(entClass);
        if (pEdge != NULL)
                acutPrintf("\n faceMesh: AcBrEntity::cast() failed\n");
        return (AcBr::ErrorStatus)eNotThatKindOfClass;
        AcGe::EntityId entId;
        returnValue = faceEntity.getSurfaceType(entId);
                acutPrintf("\n Error in AcBrFace::getSurfaceType:");
                return returnValue;
        AcGeSurface* surfaceGeometry = NULL;
    AcGeSurface* nativeGeometry = NULL;
        // NOTE: ignore unsupported geometry types for now, since we already know
        // that elliptic cylinders and elliptic cones are rejected by AcGe, but we
        // can still perform useful evaluations on the external bounded surface.
        returnValue = getNativeSurface(faceEntity, surfaceGeometry, nativeGeometry);
        if ((returnValue != AcBr::eOk) && (returnValue != (AcBr::ErrorStatus)Acad::eInvalidInput))
                acutPrintf("\n Error in getNativeSurface:");
                delete surfaceGeometry;
        delete nativeGeometry;
        return returnValue;
        // conditionally set the mesh controls based on surface type
        AcBrMesh2dControl meshCtrl;
        switch (entId)
        case(kPlane):
                acutPrintf("\nSurface Type: Plane\n");
            if ((returnValue = meshCtrl.setMinSubdivisionsInU()) != eOk)
                        return returnValue;
            if ((returnValue = meshCtrl.setMinSubdivisionsInV()) != eOk)
                        return returnValue;
            if ((returnValue = meshCtrl.setMaxSubdivisions()) != eOk)
                        return returnValue;
            if ((returnValue = meshCtrl.setMaxNodeSpacing(kMaxNodeSpacing)) != eOk)
                        return returnValue;
            if ((returnValue = meshCtrl.setAngTol(90.0 * kDeg2Rad)) != eOk)
                        return returnValue;
            if ((returnValue = meshCtrl.setDistTol(kDistTol)) != eOk)
                        return returnValue;
            if ((returnValue = meshCtrl.setMaxAspectRatio(kMaxAspectRatio)) != eOk)
                        return returnValue;
            if ((returnValue = meshCtrl.setElementShape(AcBr::kAllQuadrilaterals)) != eOk)
                        return returnValue;
                break;
        case(kSphere):
                acutPrintf("\nSurface Type: Sphere\n");
            if ((returnValue = meshCtrl.setMinSubdivisionsInU(2L)) != eOk)
                        return returnValue;
            if ((returnValue = meshCtrl.setMinSubdivisionsInV(2L)) != eOk)
                        return returnValue;
                        return returnValue;
                        return returnValue;
            if ((returnValue = meshCtrl.setAngTol()) != eOk)
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                break;
        case(kTorus):
                acutPrintf("\nSurface Type: Torus\n");
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                break;
        case(kCylinder):
                acutPrintf("\nSurface Type: Circular Cylinder\n");
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                break;
        case(kCone):
                acutPrintf("\nSurface Type: Circular Cone\n");
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                break;
        case(kNurbSurface):
                acutPrintf("\nSurface Type: NURB Surface\n");
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
            if ((returnValue = meshCtrl.setAngTol(30.0 * kDeg2Rad)) != eOk)
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                break;
        // NOTE: This surface is not yet supported in AcGe, so we infer the definition
        // data by analysing evaluated data on the external bounded surface.
        case(kEllipCylinder):
                acutPrintf("\nSurface Type: Elliptic Cylinder\n");
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                break;
        case(kEllipCone):
                acutPrintf("\nSurface Type: Elliptic Cone\n");
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                        return returnValue;
                break;
        default:
                acutPrintf("\nSurface Type: Unexpected Non Surface\n");
                return (AcBr::ErrorStatus)Acad::eInvalidInput;
        } // end switch(entId)
        // make the mesh filter from the topology entity and the mesh controls
        AcBrEntity* meshEnt = (AcBrEntity*)&faceEntity;
        AcBrMesh2dFilter meshFilter;
        meshFilter.insert(make_pair(meshEnt, (const AcBrMesh2dControl)meshCtrl));
    // generate the mesh, display any errors and attempt to dump all
        // generated elements (most errors are not fatal so we want to do
        // the best we can with whatever subset of the face was meshed).
        AcBrMesh2d faceMesh;
        if ((returnValue = faceMesh.generate(meshFilter)) != eOk)
                acutPrintf("\n Error in AcBrMesh2d::generate:");
                return returnValue;
    // check to see if the mesh owner is the face we used in the filter
    AcBrEntity* meshOwner = NULL;
    if ((returnValue = faceMesh.getEntityAssociated(meshOwner)) != eOk)
                acutPrintf("\n Error in AcBrMesh2d::getEntityAssociate:");
                return returnValue;
    if (!meshEnt->isEqualTo(meshOwner))
        acutPrintf("\nMesh owner is not the face we asked to mesh!");
    // dump or display the elements (regardless of incomplete mesh)
        returnValue = meshDisplay(faceMesh);
    return returnValue;
meshDisplay(const AcBrMesh2d& mesh)
        // make a global element traverser
        AcBrMesh2dElement2dTraverser meshElemTrav;
        returnValue = meshElemTrav.setMesh(mesh);
                acutPrintf("\n Error in AcBrMesh2dElement2dTraverser::setMesh:");
                return returnValue;
        // display the elements
        while (!meshElemTrav.done() && (returnValue == AcBr::eOk) && !acedUsrBrk())
            // convert the nodes into a 3d point array for AcDbPolyline
        AcGePoint3dArray pts;
                AcBrElement2dNodeTraverser elemNodeTrav;
                returnValue = elemNodeTrav.setElement(meshElemTrav);
                        acutPrintf("\n Error in AcBrElement2dNodeTraverser::setElement:");
                        return returnValue;
                while (!elemNodeTrav.done() && (returnValue == AcBr::eOk))
                        AcBrNode node;
                        returnValue = elemNodeTrav.getNode(node);
                            acutPrintf("\n Error in AcBrElement2dNodeTraverser::getNode:");
                            return returnValue;
                        // add the node geometry data to the lightweight polyline point array
                        returnValue = nodeDisplay(node, pts);
                                acutPrintf("\n Error in nodeDisplay:");
                            return returnValue;
                        returnValue = elemNodeTrav.next();
                            acutPrintf("\n Error in AcBrElement2dNodeTraverser::next:");
                            return returnValue;
                } // end element while
        // create a simple, closed polygon from the element node list
                AcDbFace* pFace;
                if(pts.logicalLength()==4)
                        pFace = new AcDbFace(pts[0], pts[1], pts[2], pts[3], Adesk::kTrue,
                                 Adesk::kTrue, Adesk::kTrue, Adesk::kTrue);
                        if (pFace == NULL)
                                returnValue = (AcBr::ErrorStatus)Acad::eOutOfMemory;
                                acutPrintf("\n Unable to allocate memory for face");
                                return returnValue;
                else if(pts.logicalLength()==3)
                        pFace = new AcDbFace(pts[0], pts[1], pts[2], Adesk::kTrue,
                        if (pFace == NULL)
                                return returnValue;
                else
                        delete pFace;
                        return (AcBr::ErrorStatus)Acad::eOutOfMemory;
                pFace->setColorIndex(2);
                // post the polyline to the database (this should display the element)
        AcDbObjectId objId;
        if (addToDatabase(pFace, objId) != AcBr::eOk)
            acutPrintf("\n addToDatabase failed");
            return returnValue;
        // close the database object
        if (pFace->close() != AcBr::eOk)
            acutPrintf("\n AcDb3dPolyline::close() failed");
            return returnValue;
                returnValue = meshElemTrav.next();
                        acutPrintf("\n Error in AcBrMesh2dElement2dTraverser::next:");
                        return returnValue;
        }  // end mesh while
    return returnValue;
getNativeSurface(const AcBrFace& faceEntity,
                 AcGeSurface*&   surfaceGeometry,
                 AcGeSurface*&   nativeGeometry)
    AcBr::ErrorStatus returnValue = faceEntity.getSurface(surfaceGeometry);
                acutPrintf("\n Error in AcBrFace::getSurface:");
            return returnValue;
        if (surfaceGeometry == NULL)
                acutPrintf("\n getNativeSurface: external bounded surface is undefined\n");
        returnValue = AcBr::eMissingGeometry;
        return returnValue;
        if (surfaceGeometry->type() != kExternalBoundedSurface)
                acutPrintf("\n getNativeSurface: surface is not an external bounded surface\n");
        return returnValue;
        AcGeExternalSurface baseGeometry;
        ((AcGeExternalBoundedSurface*)surfaceGeometry)->getBaseSurface(baseGeometry);
        if (!baseGeometry.isDefined())
                acutPrintf("\n getNativeSurface: external surface is undefined\n");
        return returnValue;
        if (!baseGeometry.isNativeSurface(nativeGeometry) || (nativeGeometry == NULL))
                acutPrintf("\n getNativeSurface: native surface is undefined\n");
        return returnValue;
    return returnValue;
nodeDisplay(const AcBrNode& node, AcGePoint3dArray& pts)
        AcGePoint3d nodePoint;
        returnValue = node.getPoint(nodePoint);
                acutPrintf("\n Error in AcBrNode::getPoint:");
        return returnValue;
    pts.append((const AcGePoint3d&)nodePoint);
        return returnValue;
static Acad::ErrorStatus
addToDatabase(AcDbEntity* pEnt, AcDbObjectId& objId)
    AcDbBlockTable* pBlockTable;
    AcDbBlockTableRecord* pSpaceRecord;
        AcDbDatabase *pCurDwg = acdbHostApplicationServices()->workingDatabase();
    if (pCurDwg==NULL)
        return Acad::eNoDatabase;
    if ((acadReturnValue = pCurDwg->getBlockTable(pBlockTable,
        AcDb::kForRead)) != Acad::eOk)
        acutPrintf("\n acdbCurDwg()->getBlockTable() failed");
        return acadReturnValue;
    if ((acadReturnValue = pBlockTable->getAt(ACDB_MODEL_SPACE,
        pSpaceRecord, AcDb::kForWrite)) != Acad::eOk)
        acutPrintf("\n AcDbBlockTable::getAt() failed");
    // close the block table object
    if ((acadReturnValue = pBlockTable->close()) != Acad::eOk)
        acutPrintf("\n AcDbBlockTable::close() failed");
    // append the entity to the display list
    if ((acadReturnValue = pSpaceRecord->appendAcDbEntity(objId, pEnt))        != Acad::eOk)
        acutPrintf("\n AcDbBlockTableRecord::appendAcDbEntity() failed");
    // close the block table record object
    if ((acadReturnValue = pSpaceRecord->close()) != Acad::eOk)
        acutPrintf("\n AcDbBlockTableRecord::close() failed");
GMT+8, 2026-11-3 17:39 , Processed in 0.558726 second(s), 32 queries , Gzip On.
