查看: 1211|回复: 2
[求助] [求助]:怎样把这个YXlisp程序改写成只保留小数点后2位
发表于 2006-6-7 10:34:47 | 显示全部楼层 |阅读模式
(defun c:yx()
        (setvar "CMDECHO" 0)
        (command "ucs" "w")
        (setq os (getvar "osmode"))
        (setq pt (getpoint "\n请点取欲标注X,Y世界坐标的点(本程序的X,Y互换):"))
        (command "osnap" "non")
        (command "pline"
                pt
        (setq x (strcat "X=" (rtos (cadr pt) (getvar "lunits") (getvar "luprec"))))
        (setq y (strcat "Y=" (rtos (car pt) (getvar "lunits") (getvar "luprec"))))
        (command "osnap" "off")
        (command "ucs" "v")
        (setq p1 (getpoint (trans pt 0 1) "\n请点取标注线起点:"))
        (setq p2 (getpoint p1 "\n请确定标注线终点的方向:"))
        (setq h (getstring "\n请输入高程(回车则取消):"))
        (setq h (strcat "H=" h))
        (setq x1 (car p1))
        (setq y1 (car (cdr p1)))
        (setq x2 (car p2))
        (setq sh (cdr (assoc 40 (tblsearch "style" (getvar "textstyle")))))
        (setq w (cdr (assoc 41 (tblsearch "style" (getvar "textstyle")))))
        (setq ts (if (> sh 0) sh (getvar "TEXTSIZE")))
        (setq l (* (max (strlen y) (strlen x)) ts 0.9 w))
        (setq tyu (+ y1 (* ts 0.5)))
        (setq tyd (- y1 (* ts 1.5)))
        (if (> x1 x2) (setq x2 (- x1 l)) (setq x2 (+ x1 l)))
        (command "Pline"
                "@0,0,0"
                "W"
                0
                0
                p1
                (list x2 y1)
        (if (> x1 x2) (setq a x2) (setq a x1))
        (if (> x1 x2) (setq b x1) (setq b x2))
        (if (> sh 0)
                (progn
                        (command "text"
                                (list a tyd)
                                0
                                y
                        (command "text"
                                (list a tyu)
                                0
                                x
                (progn
                        (command "text"
                                (list a tyd)
                                ts
                                0
                                y
                        (command "text"
                                (list a tyu)
                                ts
                                0
                                x
        (if (/= "H=" h)
                (progn
                        (if (> x2 x1)
                                (setq ph (list (+ x2 (/ (* ts w) 2)) (- y1 (/ ts 2))))
                                (setq ph (list (- x2 (* (strlen h) ts w)) (- y1 (/ ts 2))))
                        (if (> sh 0)
                                (command "text"
                                        ph
                                        0
                                        h
                                (command "text"
                                        ph
                                        ts
                                        0
                                        h
        (setvar "osmode" os)
        (command "ucs" "w")
发表于 2006-6-7 10:57:50 | 显示全部楼层
(setq x (strcat "X=" (rtos (cadr pt) (getvar "lunits")  2))))
(setq y (strcat "Y=" (rtos (car pt) (getvar "lunits")  2))))
 楼主| 发表于 2006-6-7 14:26:54 | 显示全部楼层
谢谢啦
真是十分感谢!我自己试着改了半天都没改对,看来我对这个lisp还没有入门啊!!唉~!还是要不断努力学习西啊!~~~
GMT+8, 2026-11-22 09:14 , Processed in 0.417537 second(s), 14 queries , Gzip On, File On.
