查看: 1245|回复: 0
[转贴]:lambda-expressions
发表于 2006-6-14 01:34:27 | 显示全部楼层 |阅读模式
  1. (defun fplot (expr steps xpi ypi / xn yn zn tlist plist _plot)
  2.   (defun _plot (l / i j)
  3.     (setq i 0)
  4.     (command "_3dmesh" (length l) (length (car l)))
  5.     (repeat (length l)
  6.       (setq j 0)
  7.       (repeat (length (car l))
  8.         (command (nth j (nth i l)))
  9.         (setq j (1+ j))
  10.       )
  11.       (setq i (1+ i))
  12.     )
  13.   )                                       ; **********************
  14.   (setvar "blipmode" 0)
  15.   (setvar "cmdecho" 0)
  16.   (setq plist nil)
  17.   (setq xn 0.0
  18.         yn 0.0
  19.   )
  20.   (repeat (* xpi steps)
  21.     (setq tlist nil)
  22.     (setq yn 0.0)
  23.     (repeat (* ypi steps)
  24.       (setq zn ((eval expr) xn
  25.              yn
  26.             )
  27.       )
  28.       (setq tlist (append
  29.                     tlist
  30.                     (list (list xn yn zn))
  31.                   )
  32.       )
  33.       (setq yn (+ yn (/ pi steps)))
  34.     )
  35.     (setq plist (append
  36.                   plist
  37.                   (list tlist)
  38.                 )
  39.     )
  40.     (setq xn (+ xn (/ pi steps)))
  41.   )
  42.   (_plot plist)
  43. )
E.g
  1. (fplot '(lambda(x y / )(*(cos x)(cos y))) 10 10 10)
复制代码
登录/注册后可看大图
登录/注册后可看大图
  1. (fplot
  2. '(lambda(x y / )
  3.     (max -0.5(min 0.5(*(cos x)(cos y))))
  4.   )
  5. )
复制代码
登录/注册后可看大图
  1. (fplot
  2. '(lambda(x y / )
  3.     (/(*(+(cos x)x)(+(cos y)y))50.0)
  4.   )
  5. )
复制代码
登录/注册后可看大图
登录/注册后可看大图
  1. (fplot '(lambda(x y / )(cos(* x y))) 20 3 3)
复制代码
登录/注册后可看大图
GMT+8, 2026-11-22 09:19 , Processed in 0.332042 second(s), 10 queries , Gzip On, File On.
