查看: 1571|回复: 3
[求助] [求助]:简单的lisp,看谁能帮我看出问题来?
发表于 2006-6-25 21:29:41 | 显示全部楼层 |阅读模式
;This program generates a chamfer by entering
;the chamfer angle and the chamfer distance
(defun c:chamf(/ d a)
  (setvar"cmdecho"0)
  (graphscr)
  (setq d (getdist "\n Enter chamfer distance:"))
  (setq a (getangle "\n Enter chamfer angle:"))
  (setvar"chamfer" d)
  (setvar"chamferb"(* d(/(sin a)(cos a))))
  (command"chamfer")
  (setvar"cmdecho"1)
  (princ)
发表于 2006-6-25 23:16:47 | 显示全部楼层
没有“chamfer”这个系统变量,更改为“chamfera”
  1. (defun c:chamf (/ d a)
  2.   (setvar "cmdecho" 0)
  3.   (graphscr)
  4.   (setq d (getdist "\n Enter chamfer distance:"))
  5.   (setq a (getangle "\n Enter chamfer angle:"))
  6.   (setvar "chamfera" d)
  7.   (setvar "chamferb" (* d (/ (sin a) (cos a))))
  8.   (command "chamfer")
  9.   (setvar "cmdecho" 1)
  10.   (princ)
  11. )
 楼主| 发表于 2006-6-26 01:10:02 | 显示全部楼层
谢谢您的帮忙,
发表于 2006-6-26 10:24:48 | 显示全部楼层
当a=90度时会有计算错误,程序中应考虑!
GMT+8, 2026-11-22 08:35 , Processed in 0.210779 second(s), 16 queries , Gzip On, File On.
