查看: 1231|回复: 3
[求助] [求助]:大家看看这个LISP加载以后怎么用??
发表于 2006-8-12 13:33:08 | 显示全部楼层 |阅读模式
大家看看这个LISP加载以后怎么用??
;================   hqxxy ========================================================
;给制曲线线元函数
;入口参数线元要素xyb为:
;xyb=(线元起点里程  线元起点X坐标  线元起点Y坐标  线元起点切线方位角(以弧度为单位)
; 线元长度    线元起点曲率半径  线元止点曲率半径   线元偏向标志)
(defun C:hqxxy(xyb / s0 x0 y0 f0 ls r0 rn q pt0  ptn sn xyn x1 x2 y1 y2 mj ptt pp s i n)
  (setq cm (getvar "cmdecho") os (getvar "osmode"))
  (setvar "cmdecho" 0)(setvar "osmode" 0)
  (setq s0 (nth 0 xyb)  x0 (nth 1 xyb)  y0 (nth 2 xyb)  f0 (nth 3 xyb)
ls (nth 4 xyb)  r0 (nth 5 xyb)  rn (nth 6 xyb)  q  (nth 7 xyb)
pt0 (list y0 x0)
sn (+ s0 ls)
xyn (qxzs xyb (list sn 0))
ptn (list (cadr xyn) (car xyn))
x1 x0  y1 y0
x2  (car xyn) y2 (cadr xyn)
  (if (< x2 x1) (setq x1 x2 x2 x0))
  (if (< y2 y1) (setq y1 y2 y2 y0))
  (command "undo" "be")
  (command "zoom" "w" (list (- y1 200) (- x1 200) 0) (list (+ y2 200) (+ x2 200) 0))
  (cond ((and (= r0 rn) (= r0 1e45)) (command "line" pt0 ptn ""))
((and (= r0 rn) (< r0 1e45))
     (setq ptt (polar pt0 (+ f0 (* q 0.5 pi)) r0)
    mj  (sjxmj pt0 ptn ptt)
     (if (and (> q 0) (< mj 0)) (setq pp pt0 pt0 ptn ptn pp))
     (if (and (< q 0) (< mj 0)) (setq pp pt0 pt0 ptn ptn pp))
     (command "_arc"  pt0 "e" ptn  "r" r0)
(t  (command "pline")
     (setq n  (+ 2 (fix (/ ls 0.5))) i 0)
            (repeat n
               (setq s (+ s0 (* i 0.5)))
               (if (> s sn) (setq s sn))
               (setq xyn (qxzs xyb (list s 0)))
               (command (list (cadr xyn) (car xyn)))
               (setq i (1+ i))
     (command "")
  (command "undo" "e")
  (setvar "cmdecho" cm)(setvar "osmode" os)(princ)
已领礼包: 208个
发表于 2006-8-12 13:53:32 | 显示全部楼层
命令hqxxy
发表于 2006-8-15 13:16:37 | 显示全部楼层
所有的lsp 命令格式都是dufun c:xxx
后面的那個xxx 就是執行命令.
发表于 2006-8-20 10:14:20 | 显示全部楼层
刚才试了下 ,运行出现错误, 提示 参数太少。
GMT+8, 2026-11-7 06:50 , Processed in 0.496765 second(s), 37 queries , Gzip On.
