查看: 1186|回复: 3
[编程申请]:有没有将水平文字和垂直文字分开的图层设置程序
发表于 2006-8-31 16:55:22 | 显示全部楼层 |阅读模式
有没有将水平文字和垂直文字分开的图层设置程序,这样可以将水平文字和垂直文字设置到两个层中,一是方便修改,而是当图纸文字太密的时候可以分开出图。
已领礼包: 12487个
发表于 2006-9-1 08:31:57 | 显示全部楼层
  1. (DEFUN C:TEXTHV ()
  2. (SETVAR "CMDECHO" 0)
  3. (COMMAND ".UNDO" "BE")
  4. (SETQ SS nil SS1 nil)
  5. (IF (SETQ SS (SSGET "X" '((0 . "*TEXT") (50 . 0.0))))
  6.   (COMMAND "-LAYER" "N" "TEXTH" "" "CHPROP" SS "" "LA" "TEXTH" "")
  7. )
  8. (IF (SETQ SS1 (SSGET "X" '((0 . "*TEXT")))) (PROGN
  9.   (COMMAND "-LAYER" "N" "TEXTV" "")
  10.   (IF SS
  11.    (COMMAND "CHPROP" SS1 "R" SS "" "LA" "TEXTV" "")
  12.    (COMMAND "CHPROP" SS1 "" "LA" "TEXTV" "")
  13.   )
  14. ))
  15. (COMMAND ".UNDO" "E")
  16. (SETVAR "CMDECHO" 1)
  17. (PRINC)
  18. )
 楼主| 发表于 2006-9-1 09:18:45 | 显示全部楼层 |阅读模式
感谢,且这么快答复。
要是能加上窗选就更好了。
已领礼包: 12487个
发表于 2006-9-2 00:01:39 | 显示全部楼层
  5. (IF (SETQ SS (SSGET '((0 . "*TEXT") (50 . 0.0))))
  7. )
  8. (IF (SETQ SS1 (SSGET '((0 . "*TEXT")))) (PROGN
  10.   (IF SS
  13.   )
  14. ))
  17. (PRINC)
  18. )
GMT+8, 2026-11-4 18:29 , Processed in 0.461718 second(s), 40 queries , Gzip On.
