查看: 1638|回复: 6
[求助]:2006中的一个显示问题~~!
发表于 2006-9-4 14:52:29 | 显示全部楼层 |阅读模式
2006中将光标移到对象上,对象就要变亮~,这本来是方便操作者的好事
但在对象密集的图上 这样就会使人眼花了~ 怎样才能取消这个啊 恢复成2004 2002那种状态啊
谢谢~~~
发表于 2006-9-4 15:32:12 | 显示全部楼层
嗯,我也觉得象2002那种点选了后再区别开来就行了,2006的那个框框也点多余。
 楼主| 发表于 2006-9-5 08:51:05 | 显示全部楼层
期待高人解答~~~
发表于 2006-9-5 10:27:40 | 显示全部楼层
6.[必看]:改变几个参数使2006用起来像2005一样   9pt 10pt 11pt 12pt 13pt 15pt
系统参数可以在命令行直接输入
也可以在ET工具中的SYSTEM VARIABLE EDITOR中选
第一个:VTENABLE 参数0~7 ,默认的是3 ,改为0, ZOOM时就没有平滑缩放。原文:Controls when smooth view transitions are used. Smooth view transitions can be on or off for panning and zooming, for changes of view angle, or for scripts. The valid range is 0 to 7.
第二个:SELECTIONAREA 参数0~1,默认的是1,改为0,选择的时候选区内就没有透明色 原文:Controls the display of effects for selection areas. Selection areas are created by the Window, Crossing, WPolygon, and CPolygon options of SELECT.
第三个:SELECTIONPREVIEW 参数0~3 ,默认的是3 改为0 ,选择物体时就不会显高亮(建议用2,在命令状态下,选择物体时显高亮,这样能看清选择的物体)原文:Controls the display of selection previewing. Objects are highlighted when the pickbox cursor rolls over them. This selection previewing indicates that the object would be selected if you clicked. The setting is stored as a bitcode using the sum of the following values:
接着发两个系统参数
VTFPS 参数1~30 默认7 控制平滑缩放的速度,原文:Sets the minimum speed of a smooth view transition, in frames per second. When a smooth view transition cannot maintain this speed, an instant transition is used. The valid range is 1.0 to 30.0.
SELECTIONAREAOPACITY 参数0~100 默认25 控制选择区域透明色的透明度 原文:Controls the transparency of the selection area during window and crossing selection. The valid range is 0 to 100. The lower the setting, the more transparent the area. A value of 100 makes the area opaque. The SELECTIONAREA system variable must be on.
 楼主| 发表于 2006-9-5 10:44:16 | 显示全部楼层
谢谢啊~~真是高人啊~~~
发表于 2006-9-5 11:20:21 | 显示全部楼层
工具——选项,里面好象可以直接改。
发表于 2006-9-5 15:12:32 | 显示全部楼层
工具——选项——选择,“视觉效果设置”可以改的
GMT+8, 2026-11-23 17:48 , Processed in 0.507637 second(s), 22 queries , Gzip On, File On.
