查看: 1371|回复: 2
[求助] [求助]:dimlfac变量问题
发表于 2006-9-30 16:24:25 | 显示全部楼层 |阅读模式
(defun C:03timesdim(/ bl)
        (setvar "cmdecho" 0)
        (SETQ BL (/ 1 3))
        (command "dimlfac" bl)
        (command "dimlinear" "_end" pause "_end" pause pause)
        (command "dimlfac" "1")
        (prin1)
为何        (SETQ BL (/ 1 3))得到的bl不能赋值给dimlfac,只能改为
;;;            (SETQ BL (/ 1 3))
        SETQ BL 0.3333333)
        (prin1)
已领礼包: 9343个
发表于 2006-9-30 17:56:51 | 显示全部楼层
Command: (SETQ BL (/ 1 3))
0
Command: (SETQ BL (/ 1 3.0))
0.333333
 楼主| 发表于 2006-9-30 18:55:16 | 显示全部楼层
受教了,把实数型和整数型给忘了,
GMT+8, 2026-11-5 23:17 , Processed in 0.439148 second(s), 35 queries , Gzip On.
