查看: 1118|回复: 2
[LISP程序]:点排序LSP,帮忙看一下
发表于 2006-10-29 12:13:38 | 显示全部楼层 |阅读模式
(defun bx() ;;
  (setq kk 0 ss-mm '() ss-m (list (nth 0 ss-z1)))
  (repeat (length ss-z1)
  (if (=
      (car (nth (1+ kk) ss-z1))
      (car (nth  kk ss-z1))
      (setq ss-m (cons (nth (1+ kk) ss-z1) ss-m))
      (setq ss-m (reverse ss-m)
            ss-mm (cons ss-m ss-mm)
            ss-m  (list (nth (1+ kk) ss-z1))
      );;if
    (setq kk (1+ kk))
    );repeat
ss-z1
((6097.45 3018.36 0.0) (6097.45 1073.64 0.0) (8426.71 3018.36 0.0) (8426.71
1073.64 0.0))
需要得到结果ss-mm
(((8426.71 1073.64 0.0) (6097.45 1073.64 0.0)) ((8426.71 3018.36 0.0)
(6097.45 3018.36 0.0)))
实际得到
(((8426.71 1073.64 0.0)) ((6097.45 1073.64 0.0)) ((8426.71 3018.36 0.0))
((6097.45 3018.36 0.0)))
帮忙看一下问题出在哪儿?谢谢
发表于 2006-10-29 13:44:34 | 显示全部楼层
试试修改为(未测试):
(defun bx() ;;
(setq kk 0 ss-mm '() ss-m (nth 0 ss-z1))  ;;delete list
  (if (=
             ss-m (nth (1+ kk) ss-z1)    ;;delete list
   );;if
(setq kk (1+ kk))
);repeat
 楼主| 发表于 2006-10-29 20:08:22 | 显示全部楼层
谢谢回答,;
找到问题了,ss-z1没有按照原来排列,
将CAR 改成CADR即可,
GMT+8, 2026-11-7 08:53 , Processed in 0.416461 second(s), 36 queries , Gzip On.
