查看: 5451|回复: 5
[LISP函数]:块参照的变换矩阵
发表于 2009-2-26 02:11:02 | 显示全部楼层 |阅读模式
块参照的变换矩阵,可能已经在本论坛上讨论过了,但今天我给大家介绍一个很好的程序。来自于国外的gile.
这个程序能把块内的一点的坐标MCS转换成 WCS或者UCS
或者进行逆转换.在很多场合中都可能用到这样的转换矩阵。
现在共享出来。其中还有几个很简明的矩阵函数,譬如,矩阵和矢量相乘,矢量的点积,矩阵的转置,矩阵的乘法。等等。
这个转换函数流程清晰简明,值得一看。
[php]
;; TransNested (gile)
;; Translates a point coordinates from WCS or UCS to RCS -coordinates system of a
;; reference (xref or block) whatever its nested level-
;; Arguments
;; pt : the point to translate
;; rlst : the parents entities list from the deepest nested to the one inserted in
;;        current space -same as (last (nentsel)) or (last (nentselp))
;; from to : as with trans function: 0 for WCS, 1 for current UCS, 2 for RCS
(defun TransNested (pt rlst from to / mat dep)
  (setq mat '((1 0 0) (0 1 0) (0 0 1)))
  (and (= 1 from) (setq pt (trans pt 1 0)))
  (and (= 2 to) (setq rlst (reverse rlst)))
  (and (or (= 2 from) (= 2 to))
       (while rlst
        (setq geom (if        (= 2 to)
                      (RevRefGeom (car rlst))
                      (RefGeom (car rlst))
               rlst (cdr rlst)
               mat  (mxm (car geom) mat)
               pt   (mapcar '+ (mxv (car geom) pt) (cadr geom))
  (if (= 1 to)
    (trans pt 0 1)
    pt
;; RefGeom (gile)
;; Returns a list which first item is a 3x3 transformation matrix (rotation,
;; scales, normal) and second item the object insertion point in its parent
;; (xref, bloc or space)
;; Argument : an ename
(defun RefGeom (ename / elst ang norm)
  (setq        elst (entget ename)
        ang  (cdr (assoc 50 elst))
        norm (cdr (assoc 210 elst))
  (list
    (setq mat
           (mxm
             (mapcar (function (lambda (v) (trans v 0 norm T)))
                     '((1.0 0.0 0.0) (0.0 1.0 0.0) (0.0 0.0 1.0))
             (mxm
               (list (list (cos ang) (- (sin ang)) 0.0)
                     (list (sin ang) (cos ang) 0.0)
                     '(0.0 0.0 1.0)
               (list (list (cdr (assoc 41 elst)) 0.0 0.0)
                     (list 0.0 (cdr (assoc 42 elst)) 0.0)
                     (list 0.0 0.0 (cdr (assoc 43 elst)))
    (trans
      (mapcar
        (cdr (assoc 10 elst))
        (mxv mat
             (cdr (assoc 10 (tblsearch "BLOCK" (cdr (assoc 2 elst)))))
      norm
      0
;; RevRefGeom (gile)
;; RefGeom inverse function
(defun RevRefGeom (ename / entData ang norm mat)
  (setq        entData        (entget ename)
        ang        (- (cdr (assoc 50 entData)))
        norm        (cdr (assoc 210 entData))
  (list
    (setq mat
           (mxm
             (list (list (/ 1 (cdr (assoc 41 entData))) 0.0 0.0)
                   (list 0.0 (/ 1 (cdr (assoc 42 entData))) 0.0)
                   (list 0.0 0.0 (/ 1 (cdr (assoc 43 entData))))
             (mxm
                     '(0.0 0.0 1.0)
               (mapcar (function (lambda (v) (trans v norm 0 T)))
    (mapcar '-
            (cdr (assoc 10 (tblsearch "BLOCK" (cdr (assoc 2 entData)))))
            (mxv mat (trans (cdr (assoc 10 entData)) norm 0))
;;; VXV Returns the dot product of 2 vectors
(defun vxv (v1 v2)
  (apply '+ (mapcar '* v1 v2))
;; TRP Transpose a matrix -Doug Wilson-
(defun trp (m)
  (apply 'mapcar (cons 'list m))
;; MXV Apply a transformation matrix to a vector -Vladimir Nesterovsky-
(defun mxv (m v)
  (mapcar '(lambda (r) (vxv r v)) m)
;; MXM Multiply two matrices -Vladimir Nesterovsky-
(defun mxm (m q)
  (mapcar '(lambda (r) (mxv (trp q) r)) m)
;;; Get-TMatrix (gile)
;;; Returns a transformation matrix (4X4) as this returned by nentselp
;;; Argument : the parents entities list from the deepest nested to the one inserted in
(defun get-tmatrix (lst / mat pt geom)
    (setq geom (refgeom (car lst))
          mat  (car geom)
          pt   (cadr geom)
          lst  (cdr lst)
  (while lst
          lst  (cdr lst)
  (append
    (mapcar '(lambda (v x) (append v (list x))) mat pt)
    (list '(0.0 0.0 0.0 1.0))
[/php]
本帖被以下淘专辑推荐:
发表于 2009-2-26 08:35:44 | 显示全部楼层
谢谢楼主分享。
It's great!Now it's perfect!
I learned a lot from this topic.
Now I am going to write a routine  about how to get the boundingBox  of  a insert.
Because just use "vla-GetBoundingBox" simply,it will get a wrong result,sometimes badly.
我现在也遇到了类似的问题。
于是也想到了转换矩阵。
正在学习。。。
还没得到我想要的结果。
--------------借宝地,求助
得到多文字的最小矩形包围盒,如图:
发表于 2009-2-26 16:32:59 | 显示全部楼层
http://www.theswamp.org/index.php?topic=26591.0
发表于 2014-1-3 05:41:01 | 显示全部楼层
果然是大师风范啊
发表于 2014-7-16 20:58:08 | 显示全部楼层
谢谢分享
发表于 2021-2-27 07:24:30 | 显示全部楼层
求块内的坐标太需要了
GMT+8, 2026-11-22 08:21 , Processed in 0.520301 second(s), 21 queries , Gzip On, File On.
