查看: 1893|回复: 0
[LISP程序]:高手帮忙啊 遇到难题了
发表于 2009-6-24 17:48:16 | 显示全部楼层 |阅读模式
我想根据一个生成表格的lsp程序来做一个自动生成坐标方格网的程序
现在遇到一个解决不了得问题
方格网的行数和列数 不能根据计算得到 只能通过输入
哪位高手能帮我指出问题所在啊 帮忙
(vl-load-com)
(defun C:bg(/ rows colu rows1 rows2 ly lx i ii propt colu1 co coo
                dx dy dxx dyy str with ptp1 ptp2 ptp3 ptp4 os)
   (setvar "CMDECHO" 0)
   (setq lay (getvar "clayer"))
   (setq os (getvar "OSMODE"))
   (setvar "OSMODE" 0)
   (command "color" "bylayer")
   (command "layer" "m" "bg" "c" "y" "bg" "")
   (setq zxj (getpoint "\n左下角点: "))
   (setq ysj (getpoint "\n右上角点:"))
   (setq zx (cadr zxj))
   (setq zy (car  zxj))
   (setq yx (cadr ysj))
   (setq yy (car ysj))
   (setq xys (rem zx 100))
   (setq yys (rem zy 100))
   (setq nxx ( - zx xys))
   (setq nxy ( - zy yys))
   (setq sxys (rem yx 100))
   (setq syys (rem yy 100))
   (setq wsx ( - yx sxys))
   (setq wsy ( - yy syys))
   (setq pt1 (list nxx nxy))
   (setq yszj (list wsx wsy))
   (initget 7)
   (setq rows 12)  就是这里设置列数 不能通过上面两个坐标差值计算得到
   (initget 7)
   (setq colu 10) 就是这里设置行数 不能通过上面两个坐标差值计算得到
否则会出错啊
   ;nitget 7)
   (setq rows1 100)
   (initget 7)
   (setq rows2 100)
   (setq ly (+ rows1 (* rows2 (1- rows))))
   (setq lx 0)
   (setq i 1)
     (repeat colu
        ;(initget 7)
        (setq ii (itoa i))
        ;(setq propt (strcat 100))
        (setq colu1 100)
        (setq lx (+ lx colu1))
           (if (= 1 i) (setq co (list colu1))
              (progn
                 (setq coo (list colu1))
                 (setq co (append co  coo))
        (setq i (1+ i))
      (setq ptp1 pt1)
      (setq dy (cadr pt1))
      (setq dx (car pt1))
      (setq dxx (+ dx lx))
      (setq pt2 (list dxx dy))
      (command "line" pt1 pt2 "")
      (setq dy (+ dy rows1))
      (setq pt1 (list dx dy))
   (repeat (1- rows)
       (setq dy (+ dy rows2))
       (setq dyy (- dy ly))
       (setq pt2 (list dx dyy))
   (setq i 0)
   (repeat colu
       (setq c (nth i co))
       (setq dx (+ dx c))
       (setq i (1+ i))
   (initget "Yes No")
   (setq str (getkword "\n表格边框是否加粗: 不加粗:No / <加粗:Yes> "))
   (if (or (= str nil) (= (strcase str) "YES"))
      (progn
         (initget 6)
         (setq with (getreal "\n表格边框线宽<0.6>: "))
         (if (= with nil) (setq with 0.6))
         (setq dy (cadr ptp1))
         (setq dx (car ptp1))
         (setq ptp2 (list dxx dy))
         (setq dyy (+ dy ly))
         (setq ptp3 (list dxx dyy))
         (setq ptp4 (list dx dyy))
         (command "PLINE" ptp1 "w" with with ptp2 ptp3 ptp4 "c")
   (setvar "OSMODE" os)
   (command "layer" "s" lay "")
   (princ)(princ)
GMT+8, 2026-11-22 07:47 , Processed in 0.198742 second(s), 10 queries , Gzip On, File On.
