查看: 1689|回复: 4
[求助]:求助ObjectARX的打印问题
发表于 2006-10-30 00:34:06 | 显示全部楼层 |阅读模式
我想做一个批量打印的程序,但不知如何把一个设置好的页面设置送到打印机.
查doc得到如下提示:
The main classes involved in creating and manipulating layouts are the following:
AcDbLayout
AcDbPlotSettings
AcDbPlotSettingsValidator
AcDbLayoutManager
AcApLayoutManager
AcDbLayoutManagerReactor
AcDbLayout, AcDbPlotSettings, and AcDbPlotSettingsValidator are used to create and set attributes on layout objects. AcDbLayoutManager, AcApLayoutManager, and AcDbLayoutManagerReactor are used to manipulate layout objects and to perform other layout-related tasks. The following sections provide an overview of some of these classes. For more information, see the ObjectARX Reference.
如果把页面设置设计好了,用哪个类的函数把页面设置付诸实践?
等同于在打印对话框中按"确定"按扭,谢谢.
发表于 2006-11-1 13:34:59 | 显示全部楼层
我想实现一个命令,可以替换当前文件的打印样式,还没头绪,哪位大虾指点一下?
发表于 2006-11-2 08:33:53 | 显示全部楼层
AcDbPlotSettingsValidator::setCurrentStyleSheet Function
 楼主| 发表于 2006-11-4 23:49:04 | 显示全部楼层
如果要用ARX做要用到com,后来想想,还是用VBA实现好了,方便,plotToDevice.
发表于 2006-11-5 09:48:25 | 显示全部楼层
参考 ObjectARX 2006\samples\editor\AsdkPlotAPI
GMT+8, 2026-11-4 19:47 , Processed in 0.932465 second(s), 40 queries , Gzip On.
