查看: 1606|回复: 2
[LISP程序]:请版主帮忙看看,此线形反向程序该怎么处理?
发表于 2006-11-7 13:09:32 | 显示全部楼层 |阅读模式
**线形反向***
(defun c:fx()
    (setq ss(ssget) mun 0)
(repeat (sslength ss)
    (setq entl-y (ssname ss mun))
    (command "pedit" entl-y "d" "")
    (setq entl(entget entl-y))
    (if (= "POLYLINE" (cdr(assoc 0 entl))) (command "pedit" entl-y
"lt" "on" "x"))
    (if (= 10 (car (nth 13 entl))) (setq nn 13))
    (if (= 10 (car (nth 12 entl))) (setq nn 12))
    (setq lt-name(cdr(assoc 6 entl)) la-name (cdr (assoc 8 entl)))
    (setq W_list '())
    (setq elem (cdr (nth nn entl)))
    (setq w_list (append w_list (list elem)))
   (while (not (null elem))
  (setq nn(+ nn 4))
    (if (= (car (nth nn entl)) 10)
    (setq w_list (append w_list (list elem))) ;构建实体坐标表
    (setq w_list (reverse w_list))
    (s  t1 (car W_list))
    (command "pline" pt1)
   (while w_list
    (setq w_list(cdr w_list))
    (setq pt (car w_list))
    (command pt)
    (command "")
    (command "chprop" (entlast) "" "lt" lt-name "la" la-name "")
    (command "pedit" (entlast) "lt" "on" "s" "")
    (command "erase" entl-y "")
    (setq mun (+ mun 1))
由于是网上下的程序,此段 (s  t1 (car W_list)), 被别人修改
可能还有其它问题,希望得到各位大虾的指点,谢谢!
发表于 2006-11-8 16:29:14 | 显示全部楼层
(setq pt1 (car W_list))
晓东里面有 何必从别的地方下载呢
发表于 2006-11-13 18:10:06 | 显示全部楼层
这个加载后的命令是什么啊  谢谢了
GMT+8, 2026-11-22 09:56 , Processed in 0.349870 second(s), 14 queries , Gzip On, File On.
