查看: 1326|回复: 7
[求助] [求助]:加粗线段的记忆功能为何无法使用?
发表于 2006-11-21 10:46:28 | 显示全部楼层 |阅读模式
在网上下载了一个加粗线段的 LISP ,作者称有输入数值记忆功能,但我使用时却没有,是何原因?
  1.   [FONT=courier new]
  2.     ;;;  该程序可修改线,弧,圆及多义线的宽度
  3. (defun C:xk (/ p l n e q w a m b  layer0 color0 linetype0 layer1 color1 linetype1 rad-out rad-in)
  4.   (setq oldblp (getvar "blipmode")
  5.         oldech (getvar "cmdecho")
  6.         olderr *error*
  7.         linetype1 (getvar "celtype")
  8.         layer1 (getvar "clayer")
  9.         color1 (getvar "cecolor")
  10.   )
  11.   (setvar "blipmode" 0)
  12.   (setvar "cmdecho" 0)
  13.   (defun *error* (msg)
  14.     (princ "\n")
  15.     (princ msg)
  16.     (setvar "blipmode" oldblp)
  17.     (setvar "cmdecho" oldech)
  18.     (setq *error* olderr)
  19.     (princ)
  20.   )
  21.   (prompt "\n请选择要改变宽度的线,弧,圆及多义线.")
  22.   (setq p (ssget))
  23.   (if (= w nil) (setq w 50))
  24. (setq width (getreal (strcat "\n请输入宽度<" (rtos W) ">: ")))
  25.   (if (= width nil) (setq width w))
  26.   (setq l 0 m 0 n (sslength p))
  27.   (while (< l n)
  28.     (setq q (ssname p l))
  29.     (setq ent (entget q))
  30.     (setq b (cdr (assoc 0 ent)))
  31.     (if (member b '("LINE" "ARC"))
  32.       (progn
  33.         (command "PEDIT" q "y" "w" width "x")
  34.         (setq m (+ 1 m))
  35.       )
  36.     )
  37.     (if (= "LWPOLYLINE" b)
  38.       (progn
  39.         (command "PEDIT" q "w" width "x")
  40.         (setq m (+ 1 m))
  41.       )
  42.     )
  43.     (if (= "CIRCLE" b)
  44.       (progn
  45.         (if (assoc 6 ent) (setq linetype0 (cdr (assoc 6 ent))) (setq linetype0 "bylayer"))
  46.         (setq layer0 (cdr (assoc 8 ent)))
  47.         (if (assoc 62 ent) (setq color0 (cdr (assoc 62 ent))) (setq color0 "bylayer"))
  48.         (setq center0 (cdr (assoc 10 ent)))
  49.         (setq radius0 (cdr (assoc 40 ent)))
  50.         (setq diameter0 (* 2 radius0))
  51.         (entdel q)
  52.         (command "color" color0)
  53.         (command "layer" "s" layer0 "")
  54.         (command "linetype" "s" linetype0 "")
  55.         (if (> w diameter0)
  56.           (progn
  57.             (princ "\n\t 因线宽大于圆的直径,故将该圆填充")
  58.             (princ)
  59.             (setq rad-out (* 2 radius0)
  60.                   rad-in 0
  61.             )
  62.           )
  63.         )
  64.         (if (<= w diameter0)
  65.           (progn
  66.             (setq rad-out (+ (* 2 radius0) width)
  67.                   rad-in (- (* 2 radius0) width)
  68.             )
  69.           )
  70.         )
  71.         (command "donut" rad-in rad-out center0 "")
  72.         (setq m (+ 1 m))
  73.       )
  74.     )
  75.     (setq l (+ 1 l))
  76.   )
  77.   (if (= 0 m)
  78.     (progn
  79.      (princ "\n\t  没有任何线,弧,圆及多义线被选中")
  80.       (princ)
  81.     )
  82.   )
  83.   (setvar "blipmode" oldblp)
  84.   (setvar "cmdecho" oldech)
  85.   (setq *error* olderr)
  86.   (command "color" color1)
  87.   (command "layer" "s" layer1 "")
  88.   (command "linetype" "s" linetype1 "")
  89.   (princ)
  90. )
  91. (princ)
  92.   [/FONT]
发表于 2006-11-21 13:01:35 | 显示全部楼层
将w设为全局变量就可以了。
 楼主| 发表于 2006-11-23 10:45:36 | 显示全部楼层
最初由 qjcpj 发布
[B]将w设为全局变量就可以了。 [/B]
全局变量如何设置呀?我不会 LISP ,那位大虾帮忙改一下,谢谢了!
已领礼包: 12496个
发表于 2006-11-23 13:48:13 | 显示全部楼层
删去(defun C:xk 后面括弧中的w就可以了。
 楼主| 发表于 2006-11-23 19:41:19 | 显示全部楼层
最初由 zxq0220 发布
[B]删去(defun C:xk 后面括弧中的w就可以了。 [/B]
试了一下,删了 W ,记忆功能还是不起作用呀!
发表于 2006-11-23 22:57:54 | 显示全部楼层
试试签名栏下的“改线宽”程序
已领礼包: 208个
发表于 2006-11-24 23:15:49 | 显示全部楼层
修改一下.
[php]
(defun C:xk (/ p l n e q  a m b  layer0 color0 linetype0 layer1 color1 linetype1 rad-out rad-in)
        olderr *error*
    (princ "\n")
    (princ msg)
    (princ)
  (setq p (ssget))
(if p
(progn
  (if (= width nil) (setq width w)(setq w width ))
  (while (< l n)
      (progn
        (setq m (+ 1 m))
      (progn
        (setq m (+ 1 m))
    (if (= "CIRCLE" b)
      (progn
        (entdel q)
        (if (> w diameter0)
          (progn
            (princ)
                  rad-in 0
          (progn
        (setq m (+ 1 m))
    (setq l (+ 1 l))
  (if (= 0 m)
    (progn
      (princ)
  (princ)
[/php]
发表于 2006-11-25 00:25:02 | 显示全部楼层
“记忆”功能最好使用注册表函数,模块使用完毕时将参数写入注册表,当下次运行程序时读入参数。
GMT+8, 2026-11-7 08:54 , Processed in 0.495367 second(s), 46 queries , Gzip On.
