查看: 1111|回复: 0
[LISP程序]:自动统计不同直径圆数量 ssc
发表于 2006-11-25 23:51:59 | 显示全部楼层 |阅读模式
自动统计不同直径圆数量 ssc   9pt 10pt 11pt 12pt 13pt 15pt
(defun c:ssc ()
(setq Dia (getreal "\n>>直径: ")
Rad (/ Dia 2)
(setq ssRad (ssget "all" (list '(0 . "circle") (cons 40 Rad))))
(setq num1 (sslength ssRad))
(alert (strcat "直径" (rtos dia 2 4) "的数量=" (rtos num1 2 4)))
GMT+8, 2026-11-3 01:45 , Processed in 0.411471 second(s), 32 queries , Gzip On.
