查看: 1464|回复: 1
[VBA程序]:[求助]:问个VBA编程小问题(在线等)
发表于 2006-12-4 11:34:57 | 显示全部楼层 |阅读模式
我刚入门EXCEL VBA编程,现在碰到个题目想请教大家:
1.求一组数,它除3余2,除5余3,除7余2,求满足上面要求的所有数[1,100]
2.求所有两位数,该数要满足:这个数的平方数的各个位数之和是原数的一半。如18*18=324, 3+2+4=9,9=18/2
3.然后再把这些数从小到大冒泡排列,要求在一个模块中编程
这是我编的3个单独的程序:
1.
Sub main()
Dim i As Integer
For i = 1 To 100
    If i Mod 3 = 2 And i Mod 5 = 3 And i Mod 7 = 2 Then
    Debug.Print i
    End If
Next
End Sub
2.
Private Sub Form_Click()
     Dim i As Integer
     Dim j As Integer
     Dim b(1 To 4) As Integer
     Dim s As Integer
     Dim k As Integer
     For i = 10 To 99
        j = i * i
        b(1) = j \ 1000 Mod 10
        b(2) = j \ 100 Mod 10
        b(3) = j \ 10 Mod 10
        b(4) = j Mod 10
        s = 0
        For k = 1 To 4
            s = s + b(k)
            Next k
            If s * 2 = i Then
                Debug.Print i
            End If
        Next
    End Sub
3.
Option Explicit
Sub main()
Dim i As Integer
Dim j As Integer
Dim temp As Integer
Dim flag As Boolean
Dim a(1 To 7) As Integer
a(1) = 8
a(2) = 5
a(3) = 11
a(4) = 9
a(5) = 2
a(6) = 7
a(7) = 6
For i = 1 To 7
    flag = False
    For j = i + 1 To 7
        If a(j) < a(i) Then
             temp = a(i)
            a(i) = a(j)
            a(j) = temp
            flag = True
         End If
       Next
         If flag = False Then
          Exit For
         End If
Next
For i = 1 To 7
  Debug.Print "a(" & i & ")=" & a(i)
Next
End Sub
以上是3个分开的程序,要求在同一个模块中执行(如题),望高人指点,小弟感激不尽
发表于 2006-12-11 18:08:44 | 显示全部楼层
比较高深呢
现在还不会
GMT+8, 2026-11-22 07:58 , Processed in 0.307747 second(s), 12 queries , Gzip On, File On.
