查看: 1361|回复: 3
[LISP程序]:向各位高手请教
发表于 2006-12-8 20:09:43 | 显示全部楼层 |阅读模式
;;一个最简单的基准标注程序,可是不能用,请问是怎么回事?
(defun c:jj ()
(graphscr)
(setq oce (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq dim_c (getvar "dimscale")) ;获得系统变量dimscale的值,
(setq p 15)
(setq r1 (* 5 dim_c));将圆半径按dimscale相应放大。
( setq
p1 (getpoint "\n 输入一点:")
p2 (getpoint p1 "\n 输入另一点:")
ang1 (angle p2 p1)
p4 (polar p1 (-ang1 (/ pi 2)) p)
p5 (polar p1 (+ang1 (/ pi 2)) p)
p3 (polar p2 ang1 (* r1 1))
text_h (* 4.5 dim_c) ;将字高相应放大。
t1 (getstring "\n序号:")
) ; 输入两点,设置半径和字高。
(command ".line" p1 p3 "");draw line
(command ".circle" p2 r1)
(command ".text" "m" p2 text_h 0 t1 )
(command ".line" p1 p4 "");draw line
(command ".line" p1 p5 "");draw line
( setvar "cmdecho" oce)
(princ)
已领礼包: 9348个
发表于 2006-12-8 22:42:33 | 显示全部楼层
p4 (polar p1 (- ang1 (/ pi 2)) p)
p5 (polar p1 (+ ang1 (/ pi 2)) p)
 楼主| 发表于 2006-12-8 22:56:13 | 显示全部楼层
没改呀
发表于 2006-12-8 23:21:05 | 显示全部楼层
你没注意到“+”“-”后面的“空格”?
GMT+8, 2026-11-7 09:47 , Processed in 0.433035 second(s), 38 queries , Gzip On.
