查看: 1136|回复: 2
[LISP函数]:请问下面一段程序有什么问题
发表于 2006-12-29 18:19:40 | 显示全部楼层 |阅读模式
请问下面一段程序有什么问题
(defun c:pf ()
(setvar "osmode" 0);关闭对象捕捉
(setvar "cmdecho" 0)
(setq n (getint "\n 请输入个数")
(setq i 0)
(while (< i n)
(setq p1 (getpoint "\n请选择起点:"))
(initget "A B C")
(setq f (getkword "n\ 请输入剖面符号:"))
(command "text" "M" p1 5 0 f)
(setq i (1 + i))
(setvar "osmode" 1)
(princ)
发表于 2006-12-29 19:32:35 | 显示全部楼层
有两个地方少了括号,循环里面的(setq n (getint "\n 请输入个数")没有用
(defun c:pf()
(setq n (getint "\n 请输入个数"))
(setq i 0)
(while (< i n)
(initget "A B C")
(setq i (1+ i))
(setvar "osmode" 1)
(princ)
 楼主| 发表于 2006-12-29 21:21:36 | 显示全部楼层
谢谢二楼楼主,问题已解决
GMT+8, 2026-11-7 11:18 , Processed in 0.860054 second(s), 35 queries , Gzip On.
