查看: 810|回复: 0
[推荐]:使用图纸设置文件(Drawing Setup Files )
发表于 2003-6-8 13:35:00 | 显示全部楼层 |阅读模式
图纸设置文件和 config.pro 文件类似,它可以控制图纸的很多属性,就象 config.pro 文件控制当前 Pro/E session 的很多属性一样。图纸设置文件和 config.pro 文件的主要不同是:config.pro 文件控制当前的整个 Pro/E session,而每一张图纸都可以有自己的图纸设置文件,两张不同的图纸的图纸设置文件可能完全不同。下面介绍如何修改图纸设置文件以及如何使用一个图纸设置文件作为你新建图纸后的缺省的参数设置。
步骤
要修改图纸设置选项,从DRAWING 菜单选择 Advanced, Set Up,  Draw Setup ,然后从 DTL SETUP 菜单选择 Modify Val 。
系统在编辑器里打开了图纸设置文件,缺省的选项如下所示(注意这是一个英制的配置文件):
! These options control text not subject to other options
drawing_text_height            0.156250
text_thickness                 0.000000
text_width_factor              0.800000
! These options control views and their annotations
broken_view_offset             1.000000
def_view_text_height           0.000000
def_view_text_thickness        0.000000
detail_circle_line_style       SOLIDFONT
detail_view_circle             ON
half_view_line                 SOLID
projection_type                THIRD_ANGLE
show_total_unfold_seam         YES
view_note                      STD_ANSI
view_scale_denominator         0
view_scale_format              DECIMAL
! These options control cross sections and their arrows
crossec_arrow_length           0.187500
crossec_arrow_style            TAIL_ONLINE
crossec_arrow_width            0.062500
crossec_text_place             AFTER_HEAD
cutting_line                   STD_ANSI
cutting_line_adapt             NO
cutting_line_segment           0.000000
draw_cosms_in_area_xsec        NO
remove_cosms_from_xsecs        TOTAL
! These options control solids shown in views
datum_point_size               0.312500
datum_point_shape              CROSS
hlr_for_pipe_solid_cl          NO
hlr_for_threads                NO
location_radius                DEFAULT(2.)
mesh_surface_lines             ON
thread_standard                STD_ANSI
hidden_tangent_edges           DEFAULT
! These options control dimensions
allow_3d_dimensions            NO
angdim_text_orientation        HORIZONTAL
associative_dimensioning       NO
blank_zero_tolerance           NO
chamfer_45deg_leader_style     STD_ASME_ANSI
clip_dimensions                YES
default_dim_elbows             YES
dim_leader_length              0.500000
dim_text_gap                   0.500000
draft_scale                    1.000000
draw_ang_units                 ANG_DEG
dual_digits_diff               -1
dual_dimension_brackets        YES
dual_dimensioning              NO
dual_secondary_units           MM
iso_ordinate_delta             NO
lead_trail_zeros               STD_DEFAULT
ord_dim_standard               STD_ANSI
orddim_text_orientation        PARALLEL
parallel_dim_placement         ABOVE
shrinkage_value_display        PERCENT_SHRINK
tol_display                    NO
tol_text_height_factor         STANDARD
tol_text_width_factor          STANDARD
witness_line_delta             0.125000
witness_line_offset            0.062500
! These options control text and line fonts
default_font                   font
aux_font                       1 filled
! These options control leaders
draw_arrow_length              0.187500
draw_arrow_style               CLOSED
draw_arrow_width               0.062500
draw_attach_sym_height         DEFAULT
draw_attach_sym_width          DEFAULT
draw_dot_diameter              DEFAULT
leader_elbow_length            0.250000
! These options control axes
axis_interior_clipping         NO
axis_line_offset               0.100000
circle_axis_offset             0.100000
radial_pattern_axis_circle     NO
! These options control geometric tolerancing information
gtol_datums                    STD_ANSI
gtol_dim_placement             ON_BOTTOM
new_iso_set_datums             NO
! These options control tables, repeat regions, and BOM b
alloons
dash_supp_dims_in_region       YES
def_bom_balloon_leader_sym     ARROWHEAD
model_digits_in_region         NO
show_cbl_term_in_region        YES
! These options control layers
draw_layer_overrides_model     YES
ignore_model_layer_status      YES
! These options control model grids
model_grid_balloon_size        0.200000
model_grid_neg_prefix          -
model_grid_num_dig_display     0
! Miscellaneous options
decimal_marker                 COMMA_FOR_METRIC_DUAL
drawing_units                  INCH
line_style_standard            STD_ANSI
max_balloon_radius             0.000000
min_balloon_radius             0.000000
node_radius                    DEFAULT
sym_flip_rotated_text          NO
sym_rotate_note_center         NO
weld_symbol_standard           STD_ANSI
yes_no_parameter_display       TRUE_FALSE
Figure 2
所有选项的含义参阅 Drawing Users Guide,这里就不详细介绍了。
有两个选项: aux_line_font 和 line_style_length选项不被包含在缺省的设置文件里,这两个选项可以被添加到任何一个图纸设置文件里,包括系统缺省的图纸配置文件。此外,aux_font 选项可以被重复任意次,以在图纸里使用更多的备用字体。
要为每一张新图纸建立一个用户自定义的缺省的图纸设置文件,可按以下步骤操作:
建立一张新图。
从DRAWING 菜单选择 Advanced, Set Up, Draw Setup 。
选择 Create。
输入新图纸设置文件的名称。
系统随后在编辑器里打开缺省的图纸设置文件。
按用户要求编辑各个选项。
推出编辑器。
从 DTL SETUP 菜单选择 Save 。
输入所要保存的文件的名称。
这将把图纸设置文件保存到当前的工作目录里,扩展名为“.dtl”。
使用 UNIX 界面或 DOS 窗口,将文件移动到一个合适的目录(例如用户自己的目录)。
在缺省的 config.pro 文件里,添加上“drawing_setup_file”选项,输入图纸设置文件选项的路径作为这个选项的值。(例如: /usr/home/user1/setup.dtl)。
以上在第3步选择 create 建立新文件之前,可先选择 Retrieve 从Pro/E 的安装目录下的 text 子目录里找到 iso.dtl 文件并打开它,然后在选择Create 命令建立新文件,这样就可以在一个公制文件的基础上进行编辑,更加方便。
以上操作将使所有新建立的图纸都自动使用你所建立的图纸设置文件。一旦图纸建立以后,改变这个图纸设置文件对图纸就不再产生影响。要修改某张图纸的图纸设置选项,你可以编辑图纸设置文件或选择Advanced, Setup, Draw Setup, Retrieve 加载一个新的dtl 文件。在config.pro文件里添加“pro_dtl_setup_dir”选项可设置系统搜索dtl 文件时的缺省路径。
GMT+8, 2026-11-22 10:43 , Processed in 0.598193 second(s), 10 queries , Gzip On, File On.
