查看: 852|回复: 0
[求助] [求助]:创建楼梯图层
发表于 2007-3-8 11:37:57 | 显示全部楼层 |阅读模式
(defun C:yPltD (/ pt1 pt2 pt3 pt4 l p0 n p1 p2 P3 P4 P5 P6 P7 P8 p9 p10 p11 K K1 K2 K3)
  (setq pt1 (getpoint "\n右下角点:"))
  (setq pt2 (getpoint pt1 "\n左下角点:"))
  (setq pt4 (polar pt1 (/ pi 2.0) 1100))
  (setq pt3 (polar pt2 (/ pi 2.0) 1100))
  (setvar "osmode" 0)
  (command "line" pt1 pt2 pt3 pt4 "c")
  (setq k (angle pt1 pt2))
  (setq L (distance pt1 pt2))
  (setq P1 (polar pt2 (/ pi 2.0) 100))
  (setq k2 (- k pi))
  (setq k3 (+ k (* 0.5 pi)))
  (setq P2 (polar p1 k2 (+ L 100)))
  (setq P3 (polar p2 K3 200))
  (setq P4 (polar p3 k (+ L 200)))
  (setq P5 (polar p4 (/ pi 2.0) 1300))
  (setq P6 (polar p5 k2 (+ L 200)))
  (setq P7 (polar p6 K3 200))
  (setq P8 (polar p7 K (+ l 100)))
  (command "line" p1 p2 P3 P4 P5 P6 P7 P8 "")
  (setq P9 (polar p2 (/ pi 2.0) 450))
  (setq P10 (polar P9 k 450))
  (setq P11 (polar p10 k 450))
  (command "Pline" P9 "W" "0" "" p11 "")
  (command "Pline" p10 "W" "70" "0" p11 "")
  (setq N (/ L 200))
  (setq I 1)
  (setq P0 P1)
  (while (<= i N)
  (setq P1 (polar p0 (/ pi 2.0) 900))
  (command "line" p0 p1 "")
  (setq p0 (polar p0 k2 200))
  (setq I (+ i 1))
  (setvar "osmode" 32)
  (setq *error* olderr)
  (princ)
这是本人写的画楼梯洞程序,想请高手改进一下,在程序中增加一段创建楼梯图层的语句,程序运行时,自动创建一楼梯图层,画出的图形放在该图层中,完成后返回0层
GMT+8, 2026-11-7 11:37 , Processed in 0.437796 second(s), 32 queries , Gzip On.
