查看: 967|回复: 2
[求助] [求助]:写的文字出错
发表于 2007-3-10 10:16:08 | 显示全部楼层 |阅读模式
(defun C:zxh (/ ap lp ku  p1  p2 p3 )
   ;;保存系统变量设置
    (setq old_OS  (getvar "OSMODE")
      old_CMD (getvar "CMDECHO")
    (setvar "CMDECHO" 0)
    (command "-osnap" "INT")
   (setq ap (getpoint "第一点:"))
   (setq lp (getpoint ap "第二点:"))
(setvar "OSMODE" 0)
   (setq ku (angle ap lp))
   (setq p1 (polar lp ku 500));;圆心
   (setq p2 (polar p1 (* 1.2 pi) 420));;文字起点
   (setq p3 (polar p1 (* 1.8 pi) 420));;文字终点
   (command "line" ap lp "")
   (command "circle" p1 500 "")
   (command "text" "j" "f" p2 p3 500)
    ;;恢复系统变量设置
    (setvar "CMDECHO" old_CMD)
    (setvar "OSMODE" old_OS)
   (princ)
本人写的一个画轴线的小程序,图能画出,但我想要写的文字出错,
这句(command "text" "j" "f" p2 p3 500)不能执行.请高手指正
已领礼包: 9348个
发表于 2007-3-10 10:34:38 | 显示全部楼层
(command "circle" p1 500)
 楼主| 发表于 2007-3-10 11:10:50 | 显示全部楼层
问题解决,谢谢
GMT+8, 2026-11-7 11:37 , Processed in 0.540871 second(s), 35 queries , Gzip On.
