查看: 59179|回复: 262
[分享]:【晴晴学堂】------AUCAD自定义的面纱1
发表于 2003-6-10 15:24:45 | 显示全部楼层 |阅读模式
今天要讲的内容是自定义AUTOCAD命令快捷键和菜单快捷键哦:
1:自定义命令快捷键
如果你没有第三方的自定义命令快捷键的软件的话(其实也用不着的),那么AUTOCAD-SUPORT--ACAD.PGP就是你理想的选择了,你可以随意更改AUTOCAD里默认的快捷键,当然在改的同时要对每个快捷键都非常熟悉,免得改过了以后和已有的发生冲突的哦。
3A,        *3DARRAY
3DO,       *3DORBIT
3F,        *3DFACE
3P,        *3DPOLY
A,         *ARC
ADC,       *ADCENTER
AA,        *AREA
AL,        *ALIGN
AP,        *APPLOAD
AR,        *ARRAY
-AR,       *-ARRAY
ATT,       *ATTDEF
-ATT,      *-ATTDEF
ATE,       *ATTEDIT
-ATE,      *-ATTEDIT
ATTE,      *-ATTEDIT
B,         *BLOCK
-B,        *-BLOCK
BH,        *BHATCH
BO,        *BOUNDARY
-BO,       *-BOUNDARY
BR,        *BREAK
C,         *CIRCLE
CH,        *PROPERTIES
-CH,       *CHANGE
CHA,       *CHAMFER
COL,       *COLOR
COLOUR,    *COLOR
CO,        *COPY
D,         *DIMSTYLE
DAL,       *DIMALIGNED
DAN,       *DIMANGULAR
DBA,       *DIMBASELINE
DBC,       *DBCONNECT
DCE,       *DIMCENTER
DCO,       *DIMCONTINUE
DDA,       *DIMDISASSOCIATE
DDI,       *DIMDIAMETER
DED,       *DIMEDIT
DI,        *DIST
DIV,       *DIVIDE
DLI,       *DIMLINEAR
DO,        *DONUT
DOR,       *DIMORDINATE
DOV,       *DIMOVERRIDE
DR,        *DRAWORDER
DRA,       *DIMRADIUS
DRE,       *DIMREASSOCIATE
DS,        *DSETTINGS
DST,       *DIMSTYLE
DT,        *DTEXT
DV,        *DVIEW
E,         *ERASE
ED,        *DDEDIT
EL,        *ELLIPSE
EX,        *EXTEND
EXIT,      *QUIT
EXP,       *EXPORT
EXT,       *EXTRUDE
F,         *FILLET
FI,        *FILTER
G,         *GROUP
-G,        *-GROUP
GR,        *DDGRIPS
H,         *BHATCH
-H,        *HATCH
HE,        *HATCHEDIT
HI,        *HIDE
I,         *INSERT
-I,        *-INSERT
IAD,       *IMAGEADJUST
IAT,       *IMAGEATTACH
ICL,       *IMAGECLIP
IM,        *IMAGE
-IM,       *-IMAGE
IMP,       *IMPORT
IN,        *INTERSECT
INF,       *INTERFERE
IO,        *INSERTOBJ
L,         *LINE
LA,        *LAYER
-LA,       *-LAYER
LE,        *QLEADER
LEN,       *LENGTHEN
LI,        *LIST
LINEWEIGHT, *LWEIGHT
LO,        *-LAYOUT
LS,        *LIST
LT,        *LINETYPE
-LT,       *-LINETYPE
LTYPE,     *LINETYPE
-LTYPE,    *-LINETYPE
LTS,       *LTSCALE
LW,        *LWEIGHT
M,         *MOVE
MA,        *MATCHPROP
ME,        *MEASURE
MI,        *MIRROR
ML,        *MLINE
MO,        *PROPERTIES
MS,        *MSPACE
MT,        *MTEXT
MV,        *MVIEW
O,         *OFFSET
OP,        *OPTIONS
ORBIT,     *3DORBIT
OS,        *OSNAP
-OS,       *-OSNAP
P,         *PAN
-P,        *-PAN
PA,        *PASTESPEC
PARTIALOPEN, *-PARTIALOPEN
PE,        *PEDIT
PL,        *PLINE
PO,        *POINT
POL,       *POLYGON
PR,        *OPTIONS
PRCLOSE,   *PROPERTIESCLOSE
PROPS,     *PROPERTIES
PRE,       *PREVIEW
PRINT,     *PLOT
PS,        *PSPACE
PTW,       *PUBLISHTOWEB
PU,        *PURGE
-PU,       *-PURGE
R,         *REDRAW
RA,        *REDRAWALL
RE,        *REGEN
REA,       *REGENALL
REC,       *RECTANGLE
REG,       *REGION
REN,       *RENAME
-REN,      *-RENAME
REV,       *REVOLVE
RM,        *DDRMODES
RO,        *ROTATE
RPR,       *RPREF
RR,        *RENDER
S,         *STRETCH
SC,        *SCALE
SCR,       *SCRIPT
SE,        *DSETTINGS
SEC,       *SECTION
SET,       *SETVAR
SHA,       *SHADE
SL,        *SLICE
SN,        *SNAP
SO,        *SOLID
SP,        *SPELL
SPL,       *SPLINE
SPE,       *SPLINEDIT
ST,        *STYLE
SU,        *SUBTRACT
T,         *MTEXT
-T,        *-MTEXT
TA,        *TABLET
TH,        *THICKNESS
TI,        *TILEMODE
TO,        *TOOLBAR
TOL,       *TOLERANCE
TOR,       *TORUS
TR,        *TRIM
UC,        *DDUCS
UCP,       *DDUCSP
UN,        *UNITS
-UN,       *-UNITS
UNI,       *UNION
V,         *VIEW
-V,        *-VIEW
VP,        *DDVPOINT
-VP,       *VPOINT
W,         *WBLOCK
-W,        *-WBLOCK
WE,        *WEDGE
X,         *EXPLODE
XA,        *XATTACH
XB,        *XBIND
-XB,       *-XBIND
XC,        *XCLIP
XL,        *XLINE
XR,        *XREF
-XR,       *-XREF
Z,         *ZOOM
; The following are alternative aliases and aliases as supplied
;  in AutoCAD Release 13.
AV,        *DSVIEWER
CP,        *COPY
DIMALI,    *DIMALIGNED
DIMANG,    *DIMANGULAR
DIMBASE,   *DIMBASELINE
DIMCONT,   *DIMCONTINUE
DIMDIA,    *DIMDIAMETER
DIMED,     *DIMEDIT
DIMTED,    *DIMTEDIT
DIMLIN,    *DIMLINEAR
DIMORD,    *DIMORDINATE
DIMRAD,    *DIMRADIUS
DIMSTY,    *DIMSTYLE
DIMOVER,   *DIMOVERRIDE
LEAD,      *LEADER
TM,        *TILEMODE
; Aliases for Hyperlink/URL Release 14 compatibility
SAVEURL, *SAVE
OPENURL,   *OPEN
INSERTURL, *INSERT
; Aliases for commands discontinued in AutoCAD 2000:
AAD,        *DBCONNECT
AEX,        *DBCONNECT
ALI,        *DBCONNECT
ASQ,        *DBCONNECT
ARO,        *DBCONNECT
ASE,        *DBCONNECT
DDATTDEF,   *ATTDEF
DDATTEXT,   *ATTEXT
DDCHPROP,   *PROPERTIES
DDCOLOR,    *COLOR
DDLMODES,   *LAYER
DDLTYPE,    *LINETYPE
DDMODIFY,   *PROPERTIES
DDOSNAP,    *OSNAP
DDUCS,      *UCS
每个命令都对应相应的快捷键,现在就可以大显身手了,呵呵
一定要记住哦,先备份一份,然后再随意涂抹就可以放心大胆咯
 楼主| 发表于 2003-6-10 15:59:48 | 显示全部楼层
Re: [分享]:【晴晴学堂】------AUCAD自定义的面纱1
2.定义AUTOCAD的菜单命令
是不是有同学对AUTOCAD的菜单不太满意呢,比如有好些菜单里面没有的命令如:ai_MESH 等等,或者是想加如快捷键(2002版本以后工具里面已经有此功能),或者想把自己写的LISP加入菜单激活,或者想把一些特别长的系统变量加入到菜单中进行控制的。。。,那么MNU就是非常好的东西唠,MUN住在:AUTOCAD\SUPORT\ACAD.MUN
打开以后首先认识
***POP0  是当我们按下SHIFT出来的右键捕捉菜单了,你可以随意进行更改,只要自己喜欢,哼
***POP1  就是菜单的第一组了,也就是位于菜单中最左面的第一组
***POP2  当然就是第二组了,嘻嘻
通过这个你可以在菜单中加入
***POP11.............等等属于自己的菜单了:)
用**XXX加入自己菜单的注释例如:**FILE
真正的定义菜单就开始了
ID_MnFile    就是定义出现在CAD菜单上的文件名
比如    ID_MnFile         [文件(&F)]
(&F)就是ALT键激活菜单的字母比如你想用键盘快速打开文件菜单的话,直接用ALT+F即可打开菜单了
后面的就是菜单里面的命令了,例如
ID_New       [新建(&N)...\tCtrl+N]^C^C_new
^C^C_后面的就是要加入的CAD命令全名ID_就是命令的解释了
[--]  就是菜单里面的横断线了
如果你想要在菜单里面加入子菜单的话,就要这样了:
例如:
ID_MnDrawing [->图形实用程序(&U)]
ID_Audit       [核查(&A)]^C^C_audit
ID_Recover     [修复(&R)...]^C^C_recover
ID_BupdateA    [更新块图标(&U)]^C^C_blockicon
ID_Purge       [<-清理(&P)...]^C^C_purge
[->....]下面和包括[<-.......]的所有上面的菜单都是子菜单的内容了
在菜单里面还可以定义快捷键的哦
看看MUN下面的这个
ID_SelAll    [CONTROL+"A"]
ID_Copyclip  [TOOLBAR+CONTROL+"C"]
ID_New       [TOOLBAR+CONTROL+"N"]
ID_Open      [TOOLBAR+CONTROL+"O"]
ID_Print     [TOOLBAR+CONTROL+"P"]
ID_Save      [TOOLBAR+CONTROL+"S"]
ID_Pasteclip [TOOLBAR+CONTROL+"V"]
ID_Cutclip   [TOOLBAR+CONTROL+"X"]
ID_Redo      [CONTROL+"Y"]
ID_U         [CONTROL+"Z"]
ID_Ai_propch [TOOLBAR+CONTROL+"1"]
ID_Content   [TOOLBAR+CONTROL+"2"]
ID_dbConnect [CONTROL+"6"]
ID_VBARun    [ALT+"F8"]
ID_VBAIDE    [ALT+"F11"]
对应POP的ID,可以在下面定义键盘快捷键
不过这里面定义的快捷键可是和菜单是生死鸳鸯的,如果POP里面没有定义的话,下面的快捷键也是不管用的哦,所以,要想在菜单里定义快捷键的话就必须定义在POP里面的哦
:),好了累坏了,下课休息一下
回复 支持 1 反对 0
发表于 2003-6-11 19:44:12 | 显示全部楼层
虽然很基本,但是对初学者很有用。
发表于 2003-6-11 21:40:56 | 显示全部楼层
我没有记错,不就是在mln里的dd嘛!不用抄在这里吧?
发表于 2003-7-11 07:11:21 | 显示全部楼层
怎么不用呀?我觉得很有用呀,不抄到这里,我们去哪里找啊?这多方便啊。
发表于 2003-7-11 12:28:23 | 显示全部楼层
对我们初学者来说确实有用啊
发表于 2003-7-13 08:51:50 | 显示全部楼层
不好用,麻烦
发表于 2003-7-17 14:53:06 | 显示全部楼层
ACAD.MUN
有这个文件嘛?我怎么没找到??
发表于 2003-7-18 00:07:43 | 显示全部楼层
谢谢指导,终于恍然大悟
发表于 2003-7-22 15:29:04 | 显示全部楼层
菜单和命令之间怎样联系的我不明白,能否讲一讲,谢谢!!!!!!!!!!!!!!
发表于 2003-7-22 18:41:40 | 显示全部楼层
是这样啊
发表于 2003-7-22 20:48:51 | 显示全部楼层
我想我应该试一下了,说不定真的有用
发表于 2003-7-23 08:38:14 | 显示全部楼层
有的时候我们正在操作CAD的时候突然想起了某一个快捷命令的好的定义键,就想将它改了,但是要找到acad.pgp那个文件还是比较麻烦,但是如果你在acad.pgp文件中加上一句话,就可以化繁为简。只要在CAD的命令行中输入pgp就可以打开acad.pgp文件。如果你的CAD的路径不同,你可以更改,2000,2002,2004都可以这样做。
发表于 2003-7-23 08:43:33 | 显示全部楼层
但是更改acad.pgp文件保存后,不能直接应用你刚定义的快捷命令,这个时候你可以在命令行中输入一个命令来初始化acad.pgp命令:reinit。
完成之后你新定义的快捷命令就可以直接使用,而不用重新启动CAD。
发表于 2003-7-23 09:02:12 | 显示全部楼层
另外,你还可以通过acad.pgp文件的定制来启动一些常用的程序,直接在命令行下面输入划红线的命令就可以了。
你可以根据你的需要定制一些自己常用的命令。
GMT+8, 2026-11-22 08:05 , Processed in 0.281603 second(s), 39 queries , Gzip On, File On.
