查看: 1171|回复: 3
[求助] [求助]:为何不是全部完成后返回0层
发表于 2007-3-22 21:37:02 | 显示全部楼层 |阅读模式
(defun C:str (/ pt1 pt2 l n p0 p1)
(command "-layer" "m" "栏杆"
                  "C" "1" """")
   (if (setq pt1 (getpoint "\n左下角点:"))
   (while (setq pt2 (getpoint pt1 "\n右下角点:"))
     (setq L (distance pt1 pt2))
;;保存系统变量设置
(setq old_osmode (getvar "osmode"))
(setq old_CMDECHO (getvar "CMDECHO"))
            (setvar "osmode" 0)
            (setvar "CMDECHO" 0)
   (command "line" pt1 pt2 "")
   (command "donut"  "0" "80" pt1 "")
   (command "donut"  "0" "80" pt2 "")
   (setq N (/ L 1200))
   (setq I 1)
   (setq k (angle pt1 pt2))
   (setq P0 Pt1)
   (while (<= i N)
   (setq P1 (polar p0 k 1200))
(progn
   (command "donut"  "0" "80" p1 "")
   (setq P0 (polar p0 k 1200))
   (setq I (+ i 1))
   (setq *error* olderr)
(command "")
(setq pt1 pt2)
;;恢复系统变量设置
(setvar "osmode" old_osmode)
(setvar "CMDECHO" old_CMDECHO)
(setvar "clayer" "0")
      (princ)
程序从第二线开始就回到0层了,而不是全部完成后返回0层,
我的本意是程序全部执行完后返回0层
已领礼包: 9348个
发表于 2007-3-22 21:54:43 | 显示全部楼层
试试这样
  ;;保存系统变量设置
  (setvar "osmode" 0)
  (command "-layer" "m" "栏杆" "C" "1" "" "")
      (setq N (/ L 1200))
      (setq I 1)
      (setq P0 Pt1)
      (while (<= i N)
        (progn
          (setq I (+ i 1))
          (command "")
          (setq pt1 pt2)
  ;;恢复系统变量设置
  (princ)
 楼主| 发表于 2007-3-23 08:02:37 | 显示全部楼层
谢谢,问题解决
调试程序很费时间,上面的问题我画了几小时没找到问题所在,你们是如何调试程序的,用VLISP编辑器还是其它?
已领礼包: 2个
发表于 2007-3-24 18:32:28 | 显示全部楼层
代码不是写出来的,而是调出来的。
最好能养成一个好的写作习惯,比如换行、缩进、注释等。
编辑器只是个工具,不要祈求它能检查出所有的错误。
要试着读代码,并让其在自己头脑中运行,直到能顺畅,则小成矣!
GMT+8, 2026-11-7 12:28 , Processed in 0.418512 second(s), 38 queries , Gzip On.
