查看: 2920|回复: 10
[推荐]:revit9.1出sp2了!
发表于 2007-4-11 17:26:57 | 显示全部楼层 |阅读模式
rrvit9.1出sp2了,大家可以到下面地址下载。
http://usa.autodesk.com/adsk/ser ... &linkID=9240618
现在已经支持vista
主要更新内容:
Primary Issues Resolved by the Service Pack
Problems Reported with the Customer Error Reporting Utility
As a result detailed information from customers who used the Customer Error Reporting Utility, a number of problems were identified and fixed. Updates have been made in the following feature areas.
    * 3D DWF
    * Background color
    * Blocks
    * Calculator
    * Command line
    * Copy and Paste
    * Design Center
    * External references
    * Fields
    * Fonts
    * Grip tools
    * Hatching
    * Materials
    * Modify
    * Multiline text (MText)
    * Navigation
    * Object snaps
    * PDF Export
    * Plot and Publish
    * Properties palette
    * Raster image
    * Recover
    * Render
    * Startup, Save, Open and Close
    * Toolbars
    * User Coordinate System (UCS)
    * Views
    * Visual styles
    * Workspaces
General Updates
Other changes included in this service pack include the following updates.
3D Navigation
    * Intellimouse scrolling with ZOOMWHEEL set to 1 now works as expected when in Orbit modes.
    * 3DORBIT performance has been improved.
Customize User Interface
    * '\' character is consistently recognized when used in macros.
Dimensioning
    * Diameter symbol is correctly displayed when Unit format is set to Windows Desktop.
    * Dimension text is no longer rotated for dimensions copied and pasted between drawings with different UCSs.
External References
    * Constant reload of relative external references has been resolved.
    * IMAGEATTACH of CMYK images no longer result in Invalid Image warnings.
    * DWF files produced with Revit Structure 2 or 3 can now be attached to AutoCAD drawings.
Fields
    * X, Y, or Z coordinates that have been excluded from fields no longer display in the field
Hatch
    * Migrated drawings containing custom hatch patterns now work correctly.
    * Text is now consistently recognized inside the boundaries of a solid hatch when "Create separate hatches" option is selected in the Hatch and Gradient dialog box.
    * Improvements have been made to hatches to make boundary detection more accurate
Internet
    * Opening drawing from an Internet site by means of i-Drop or File > Open now operates as expected.
    * iDrop now works with Internet Explorer 7.
Materials and Lighting
    * Materials applied to flat, or nearly flat, shells now display correctly.
    * Shadows are now always cast in the correct direction
Modify
    * The following operations now perform correctly in files saved in AutoCAD 2000 and Release 14 file formats from AutoCAD 2007:
          o Copy and Paste
          o Cut and Paste
          o Block and Insert
          o Wblock and Insert
          o Drag and Drop operations
    * STRETCH command used on polylines with opposing normals works as expected.
Multiline Text and Text
    * %%D and %%P MText characters from Korean and Chinese SHX bigfonts display correctly.
    * Lines of text containing spaces that use a bigfont text style display correctly.
    * Multiline text containing stacked fractions problems corrected when TSPACETYPE is set to 2.
    * Text width corrected when using MTEXT with the \T option.
    * During a spell checking process, the replacement of extended characters with '?' has been resolved.
    * Several issues fixed that allow Japanese MTEXT objects created in 2006-based drawings to display correctly when opened in AutoCAD 2007.
    * SHX font flow, in bi-directional operating systems, now go in the right direction.
    * MText or Text editor now displays after the text object is moved to a frozen layer
      Two key strokes are needed to enter any non-Unicode special symbols defined in Bigfont SHX files. In addition, two keystrokes are now required to remove these symbols.
Networks
    * Network License Manager updated so restricted users can successfully start the network version of AutoCAD on certain localized operating systems.
Performance
    * A number of improvements made to use memory more efficiently.
    * Significant improvements made in the speed of opening certain types of drawings created in MAP and Civil 3D products.
    * Sheet Set Manager field evaluation has been improved to allow for significantly faster opening and publishing of the drawings.
Plotting and Publishing
    * Raster images now plot correctly if they are part of the block inserted in the table cell.
    * Bitonal transparent raster images no longer loose transparency when plotted.
    * Line weight of certain objects is correctly interpreted when plotting to PDF files.
    * FIELDEVAL setting now maintained after publishing drawings.
    * CAL file types no longer plot at 300 DPI regardless of the specified resolution.
    * Geometry plotted to PDF is now centered correctly when Center Plot is chosen in the Plot dialog box
    * Special non-ASCII characters are now correctly interpreted in the Plot Styles (STB and CTB files).
          NOTE: If you created a plot style file in an AutoCAD 2007 product with non-ASCII characters in the style name or description, then you will have to rename those characters and resave the plot style file.
Security
    * Drawing properties are now encrypted during password protection of drawings when you select that option. If you are exchanging drawings with customers using the 'Encrypt drawing properties' feature, they must also install at least service pack 1.
Solid Modeling
    * Improvements made to allow editing of very large solid models.
    * Corrupted or zero-byte drawings no longer created when insufficient disk space conditions are detected.
具体内容详见地址http://images.autodesk.com/adsk/ ... ista_sp_readme.html
发表于 2007-4-11 22:48:15 | 显示全部楼层
...能否翻译一下?
发表于 2007-4-12 09:34:13 | 显示全部楼层
sp1有吗?能直接装sp2?
发表于 2007-4-12 10:14:56 | 显示全部楼层
好象是Autocad的补丁,不是revit的补丁吧.
发表于 2007-4-12 19:13:39 | 显示全部楼层
我怎么装不上啊?
发表于 2007-4-13 00:45:01 | 显示全部楼层
這個SP2是給ARS9.1裡面的CAD2007作補丁用的
SP2含括SP1的功能,所以如果沒裝SP1也可以直接裝SP2(但是如果
如果您的系統目前使用沒問題,不一定要安裝這些補丁...
至於翻譯...似乎沒有什麼特別的
主要是可以在vista上使用cad2007
改正之前copy/paste的問題
改正多行文字在中文、韓文的顯示問題
增強記憶體使用效能
可以編輯非常大的實體模型....
发表于 2007-4-17 23:34:36 | 显示全部楼层
vista下我的cad2007也可以用的!没有要什么补丁!!
发表于 2007-4-22 02:24:49 | 显示全部楼层
这是针对ACAD的补丁.
发表于 2007-4-25 09:27:03 | 显示全部楼层
7楼的解释比较详细,看来装不装无所谓
发表于 2007-5-6 12:38:13 | 显示全部楼层
sp2和2008有什么区别啊!
发表于 2008-5-31 10:22:55 | 显示全部楼层
没什么区别
GMT+8, 2026-11-3 07:47 , Processed in 0.514779 second(s), 52 queries , Gzip On.
