查看: 1775|回复: 1
[已解决] [已解决]:(mapcar 'set_tile key_list val_list)值为nil?
发表于 2007-8-24 11:11:37 | 显示全部楼层 |阅读模式
最近学DCL,遇到疑问。
(setq key_list '("kedit1" "kedit2" "kedit3" "ktg1" "ktg2"))
(setq val_list '("ABC" "123" "AutoCAD" "0" "1"))
返回值为
(nil nil nil nil nil)
是这样的吗?
发表于 2007-8-24 17:35:01 | 显示全部楼层
Sets the value of a dialog box tile
(set_tile key value)
Arguments
key
A string that specifies the tile.
value
A string that names the new value to assign (initially set by the value attribute).
Return Values
The value the tile was set to.
GMT+8, 2026-11-22 08:21 , Processed in 0.205810 second(s), 12 queries , Gzip On, File On.
