查看: 908|回复: 0
[编程申请]:[编程申请]:术不分网界,谁能帮完成此程式,工作需要,甚是感谢!!
发表于 2007-8-29 10:13:28 | 显示全部楼层 |阅读模式
:[编程申请]:学术不分网界,谁能帮完成此程式,工作需要,甚是感谢!!   9pt 10pt 11pt 12pt 13pt 15pt
:[编程申请]:学术不分网界,谁能帮完成此程式,工作需要,甚是感谢!! http://www.mjtd.com/BBS/dispbbs.asp...ID=62458&page=1
dwg文件已传了请各位老师帮帮忙是否能解决此问题,本人的意思是执行命令自动选择0层与G层的孔后,
在命令行直接输入要加大的每种圆孔的针径完毕后就自动产生出,(序号、符号、孔径、针径、数量、总和).
参考例:::::::::::::::::以前找到的范例::::::::::::::::::
(defun C:tjb
        (/ HOLDOSMODE HOLDZIN HOLDECHO HOLE_LIST #FF R1_LIST)
  (defun WRITE_LINE (/ LL)
    (setq #FF (polar #FF (/ pi 2.0) (* #H 1.5)))
    (command "_.line"
      (polar #FF pi (* #H 4.5))
      (polar #FF 0 (* #H 19))
    (command "_.ARRAY"
      (entlast)
      "R"
      (+ (length R1_LIST) 2)
      (* -2 #H)
    (command "_.line"
      (cdr (assoc 10 (entget (entlast))))
    (setq LL (entlast))
    (command "_.COPY" LL "" #FF (polar #FF 0 (* #H 4.3)))
    (command "_.COPY" LL "" #FF (polar #FF 0 (* #H 9.5)))
    (command "_.COPY" LL "" #FF (polar #FF 0 (* #H 13.5)))
    (command "_.COPY" LL "" #FF (polar #FF 0 (* #H 18.5)))
    (command "_.COPY" LL "" #FF (polar #FF 0 (* #H 23.5)))
  (defun WRITE_TABLE (H_LIST / DATA #F zj)
    (if (= #H NIL)
      (setq #H 5)
    (setq zj 0)
    (while (= #F NIL)
      (initget 1 "P ")
      (setq #F (getpoint "\\n表格左上角/字体高度<P>: "))
      (if (= #F "P")
(progn
   (setq
     #H (getreal (strcat "\\n字体高度<" (rtos #H 2 0) ">: "))
   (setq #F NIL)
    (setq #FF #F)
    (command "_.text" "j" "C" #F #H "" "符号  序号")
    (command "_.text"
      "j"
      "C"
      (polar #F 0 (* #H 7))
      #H
      "孔径"
    (command "_.text"
      "j"
      "C"
      (polar #F 0 (* #H 12))
      #H
      "冲针"
    (command "_.text"
      "j"
      "C"
      (polar #F 0 (* #H 17))
      #H
      "数量"
    (setq #F (polar #F (/ pi -2.0) (* #H 2)))
    (setq N 1)
    (while (/= (setq DATA (car H_LIST)) NIL)
      (command "_.text"
        "j"
        "c"
        #H
        (strcat "Φ" (rtos (* (car DATA) 2.0) 2 2))
      (command "_.text"
        "j"
        "C"
        #H
      (command "_.text"
        "j"
        "C"
        #H
        (rtos (cadr DATA))
      (command "_.text"
        "j"
        "C"
        (polar #F 0 (* #H 2.5))
        #H
        (rtos N)
      (command "_.circle"
        (polar #F 0 (* #H -3))
        (car DATA)
      (setq zj (+ zj (cadr DATA)))
      (setq H_LIST (cdr H_LIST))
      (setq N (1+ N))
    (setq #F (polar #F (/ pi -40.0) (* #H 2)))
    (command "_.text"
      "j"
      "C"
      (polar #F 0 (* #H 13.5))
      #H
      (strcat "总数=" (rtos zj))
  (defun MAKE_LIST (/ SS N R_LIST TMP)
    (if (setq SS (ssget "X" '((0 . "CIRCLE"))))
      (progn
(setq N 0)
(repeat (sslength SS)
   (if (not (member
       (setq TMP (cdr (assoc 40 (entget (ssname SS N)))))
       R_LIST
     (setq R_LIST (append R_LIST (list TMP)))
   (setq N (1+ N))
    (setq N 0)
    (repeat (length R_LIST)
      (setq
TMP (ssget "X"
     (list (cons 0 "CIRCLE") (cons 40 (nth N R_LIST)))
      (setq
R1_LIST (append R1_LIST
   (list (list (nth N R_LIST) (sslength TMP)))
      (setq N (1+ N))
  (setq HOLDECHO (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (command "_.UNDO" "_GROUP")
  (setq HOLDOSMODE (getvar "OSMODE"))
  (setq HOLDZIN (getvar "DIMZIN"))
  (setvar "DIMZIN" 8)
  (setvar "OSMODE" 0)
  (MAKE_LIST)
  (WRITE_TABLE
    (vl-sort R1_LIST
      (function (lambda (E1 E2)
    (< (car E1) (car E2))
  (WRITE_LINE)
  (setvar "OSMODE" HOLDOSMODE)
  (setvar "DIMZIN" HOLDZIN)
  (command "_.UNDO" "_END")
  (setvar "CMDECHO" HOLDECHO)
  (princ)
;制作孔径符用
;请参考这个,你说的同心圆也过滤,但究竟是取大圆还是取小圆呢?没说清楚我也没做。
;这;个只是对直径相同的圆进行编号,没有考虑同心圆的情况,请自己再完善吧...
(Defun c:test6 (/ ss i lstCir en code txt lst)
  (VL-LOAD-COM)
  ;; Get the selection set .
  (princ "\nPlease select circle objects:")
  (setq ss (vl-catch-all-apply 'ssget (list '((0 . "circle")))))
  (if (or (vl-catch-all-error-p ss) (null ss))
    (vl-exit-with-value 0)
  ;; init the i=0, lstCir= nil .
  (setq i 0
lstCir '()
  ;; repeat to get the circle data to the list lstCir .
  (repeat (sslength ss)
    (setq en (ssname ss i)
   i  (1+ i)
    (if (assoc (cdr (assoc 40 (entget en))) lstCir)
      (setq lstCir (subst (append (assoc (cdr (assoc 40 (entget en))) lstCir) (list en))
     lstCir
      (setq lstCir (cons (list (cdr (assoc 40 (entget en))) en) lstCir))
  ;; start to the "A" .
  (setq code 64)
  (foreach Cirs lstCir
    (setq txt (chr (setq code (1+ code))))
    (foreach cir (cdr Cirs)
      (setq lst (list '(0 . "text") (cons 1 txt) (assoc 10 (entget cir)) '(40 . 2)))
      (entmake lst)
GMT+8, 2026-11-4 05:57 , Processed in 0.463230 second(s), 33 queries , Gzip On.
