查看: 918|回复: 3
[讨论]:问一个弱弱的问题
发表于 2007-9-3 19:49:46 | 显示全部楼层 |阅读模式
;;;修改自EACHY版主的程序.
;;;XP以下操作系统须下载安装WMI补丁.
(defun ProcessorID (/ ids wmiobj serv lox sn flie ss)
(setvar "cmdecho" 0)
  (if (setq wmiobj (vlax-create-object "wbemScripting.SwbemLocator"))
    (progn
      (or
        (not(vl-catch-all-error-p(setq serv(vl-catch-all-apply 'vlax-invoke (list wmiobj 'ConnectServer "." "" "" "" "" "" 128 nil)))));;FOR XP系统.
        (setq serv(vlax-invoke wmiobj 'ConnectServer "." "" "" "" "" "")) ;;;XP以下操作系统.
      (setq lox    (vlax-invoke
          serv
          'ExecQuery
          "Select * from Win32_Processor"
      (setq ids nil)
      (vlax-for    item lox
    (if (not
          (member (setq sn (vlax-get item 'ProcessorID )) ids)
      (setq ids (cons sn ids))
      (mapcar 'vlax-release-object (list lox serv wmiobj))
(reverse ids)
这个程序返回的ids,是什么参数类型(好像不是字符串),我怎么才能把它写到一个文件里去.....
已领礼包: 2个
发表于 2007-9-3 19:53:50 | 显示全部楼层
看上面代码,ids 的类型是表。
要写到文件中的话,与其它类型是一样的。
例如:    (print  ids  file1)
发表于 2007-9-3 21:24:34 | 显示全部楼层
[php]
(defun ProcessorID0 ()
  (setq        str
         "Set objSWbemObject = GetObject(\"winmgmts:Win32_Processor.DeviceID='cpu0'\")
         ret = objSWbemObject.ProcessorId
         msgbox \"首枚CPU序列号:\" & ret" )
  (setq *wsc (vlax-create-object "ScriptControl"))
  (vlax-put *wsc 'language "vbs")
  (vlax-invoke *wsc 'ExecuteStatement str)
  (vlax-invoke *wsc 'eval "ret")
[/php]
 楼主| 发表于 2007-9-3 23:28:16 | 显示全部楼层
谢了,我说怎么用write-line 写不进去的....晕
再问下子,我把那个表 转成字符串怎么转...麻烦了
GMT+8, 2026-11-7 12:13 , Processed in 0.429373 second(s), 38 queries , Gzip On.
