查看: 1035|回复: 5
[求助] [求助]:[求助]:[求助]:有没有地形图载剪工具~~~~
发表于 2007-10-26 19:36:12 | 显示全部楼层 |阅读模式
有没有地形图载剪工具~~~~比如要快速地切出图中的某一块~~~
发表于 2007-10-29 18:46:14 | 显示全部楼层
;;;功能:剪除框外物体
(defun C:nn(/ PT1 PT2 OS_OLD S1 ANG D PT3 PT4)
    ;;关闭命令回显
    (command "undo" "g")
    (setvar "CMDECHO" 0)
    (princ "\n剪除框外物体")
    (setq PT1 (getpoint "\n第一角点: "))
        (if (setq PT2 (getcorner PT1 " >>>第二角点: "))
            (progn
                ;;关闭对象捕捉
                (setq OS_OLD (getvar "OSMODE"))
                (setvar "OSMODE" 0)
                ;;绘制临时边界
                (command "_rectang" PT1 PT2)
                (setq S1 (entlast))
                ;;计算边界内的四个角点
                (setq ANG (angle PT1 PT2)
                      D          (distance PT1 PT2)
                      D          (* D 1e-2)
                      PT1 (polar PT1 (+ ANG pi) D)
                      PT2 (polar PT2 ANG D)
                      PT3 (list (car PT1) (cadr PT2))
                      PT4 (list (car PT2) (cadr PT1))
                ;;强力剪切
                (command "_.trim" S1 "")
                (repeat        5
                    (command "f" PT1 PT3 PT2 PT4 PT1 "")
                (command "")
                (command "_.erase" "all" "r" "w" PT1 PT2 "")
                ;;删去临时边界
                (command "_.erase" S1 "")
                ;;恢复对象捕捉设置
                (setvar "OSMODE" OS_OLD)
    (command "undo" "e")
    (princ)
) ;_结束 defun
发表于 2007-10-31 09:15:09 | 显示全部楼层
animal212  :
麻烦2楼可不可以把删除框内物体的源码传上来
谢谢哈
辛苦了
发表于 2007-10-31 18:42:58 | 显示全部楼层
这个我不会啊,哈哈,这段程序我是抄别人的。
发表于 2007-10-31 21:55:02 | 显示全部楼层
animal212 很实在,建议加分哈!
 楼主| 发表于 2007-10-31 23:15:26 | 显示全部楼层
好东西~~~找了很久了~~~~谢谢~~
GMT+8, 2026-11-7 11:19 , Processed in 0.459525 second(s), 42 queries , Gzip On.
