查看: 834|回复: 0
[分享]: 畫拆線箭頭
已领礼包: 2个
发表于 2007-11-24 16:19:13 | 显示全部楼层 |阅读模式
  1.   [FONT=courier new]
  2. (defun c:test (/ arrow lst pt pt1)
  3.   (p-s '("osmode" 512
  4.         "plinewid" 0
  5.         "cmdecho" 0
  6.        ) t
  7.   )
  8.   (setq arrow (vl-registry-read "HKEY_CURRENT_USER\\Software\\Autodesk\\THCAD"
  9.                                 "arrow"
  10.               )
  11.   )
  12.   (if arrow
  13.     (setq arrow (ureal 7 "" "\n\t请输入箭头长度" (read arrow)))
  14.     (setq arrow (ureal 7 "" "\n\t请输入箭头长度<--->" arrow))
  15.   )
  16.   (vl-registry-write "HKEY_CURRENT_USER\\Software\\Autodesk\\THCAD" "arrow"
  17.                      (rtos arrow)
  18.   )
  19.   (command "pline")
  20.   (while (setq pt (getpoint (if pt
  21.                               pt
  22.                               (list 0 0 0)
  23.                             ) "\n\t請指定(折線)頂(端)點<回車退出>:"
  24.                   )
  25.          )
  26.     (setq lst (cons pt lst))
  27.     (command pt)
  28.   )
  29.   (command "")
  30.   (setq pt1 (polar (car lst) (angle (cadr lst) (car lst)) arrow))
  31.   (command "pline" (car lst) "w" (/ arrow 2.8) 0 pt1 "")
  32.   (p-e)
  33. )
  34.   [/FONT]
GMT+8, 2026-11-7 10:52 , Processed in 0.437259 second(s), 31 queries , Gzip On.
