查看: 870|回复: 0
[LISP程序]:请教高手!!SOS!
发表于 2003-6-17 08:36:19 | 显示全部楼层 |阅读模式
尊敬的版主:
  我是一个菜鸟,初用LISP在R14下编写程序,现遇到一个问题,是这样的,MAPFRIEND下的文字注记,在CAD中用list命令查看信息后信息如下:
Command: list
1 found
                  BLOCK REFERENCE  Layer: 9809
                            Space: Model space
                   Color: BYLAYER    Linetype: CONTINUOUS
                   Handle = EDA2
                  *U
                at point, X=499489.4032  Y=3654475.0748  Z=   0.0000
                 X scale factor    1.0000
                 Y scale factor    1.0000
          rotation angle      0
                 Z scale factor    1.0000
                  ATTRIBUTE  Layer: 9809
                            Space: Model space
                   Handle = EDA3
             Style = ANNOTEXT
             Font file = romand.shx
             start point, X=499489.4032  Y=3654475.0748  Z=   0.0000
            height    1.0000
             value 姜红|cshihd|cromand|7.19|0.08|0|0|0|3.00|3.00|0.00|1.00
               tag HZ:
          rotation angle      0
             width scale factor    1.0000
         obliquing angle      0
             flags invisible  constant
        generation normal
                  END SEQUENCE  Layer: 9809
                            Space: Model space
                   Handle = EDA4
而我的文字注记用list命令查看后信息如下:
Command: list
1 found
                  TEXT      Layer: 2009
                            Space: Model space
                   Color: 7 (white)    Linetype: CONTINUOUS
                   Handle = 100A
             Style = BIGFONT
             Font file = txt.shx hztxt.shx
          mid/left point, X=504323.8310  Y=3647489.8200  Z=   0.0000
            height    2.5000
              text 混
          rotation angle      0
         obliquing angle      0
        generation normal
我用LISP怎样写才能变成与他一样的东西!再有,我怎样才能将我的文字注记变成“块”,并且像他一样将TEXT的信息也加上去!!
不胜感激,我要在LISP下实现!!!!!!
GMT+8, 2026-11-3 02:14 , Processed in 0.495283 second(s), 32 queries , Gzip On.
