查看: 1369|回复: 1
[LISP函数]:保留列表的第m~n项
发表于 2007-12-27 11:29:29 | 显示全部楼层 |阅读模式
http://www.xdcad.net/forum/showthread.php?s=&threadid=642680
  1.   [FONT=courier new]
  2. (defun th-del-lst>mn< (m n lst / j)    ; 保留列表的第m~n项
  3.   (setq j -1)
  4.   (th-remove-if-not '(lambda (x)
  5.                        (and
  6.                          (setq j (1+ j))
  7.                          (<= m j)
  8.                          (>= n j)
  9.                        )
  10.                      ) lst
  11.   )
  12. )
  13. ;;; 命令: (setq lst (list 1 2 3 4 5 6 7 8 9 8 7 6 5 4 3 2 1))
  14. ;;; (1 2 3 4 5 6 7 8 9 8 7 6 5 4 3 2 1)
  15. ;;; 命令: (th-del-lst>mn< 3 6 lst)
  16. ;;; (4 5 6 7)
  17.   [/FONT]
发表于 2008-1-1 07:08:05 | 显示全部楼层
  1. (defun fr-del-lst>mn< (m n lst / j l)
  2.   (setq j 0 tf t)
  3.   (while (and tf lst)
  4.     (if        (and (>= j m)
  5.              (<= j n)
  6.         )
  7.       (setq l (cons (car lst) l))
  8.     )
  9.     (setq lst (cdr lst)
  10.           j   (1+ j)
  11.     )
  12.     (if (> j n) (setq tf nil))
  13.   )
  14.   (reverse l)
  15. )
GMT+8, 2026-11-22 10:32 , Processed in 0.382828 second(s), 12 queries , Gzip On, File On.
