查看: 1204|回复: 2
[编程申请]:急求统计几个实体长度总长的程序
发表于 2008-1-6 19:35:33 | 显示全部楼层 |阅读模式
急求统计几个实体长度总长的程序
发表于 2008-1-7 17:13:12 | 显示全部楼层
(defun c:test(/ curve tlen ss n sumlen)
  (vl-load-com)
  (setq sumlen 0)
  (setq ss (ssget '((0 . "CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE,ARC"))))
  (setq n 0)
  (repeat (sslength ss)
    (setq curve (vlax-ename->vla-object (ssname ss n)))
    (setq tlen (vlax-curve-getdistatparam curve
                                          (vlax-curve-getendparam curve)
    (setq sumlen (+ sumlen tlen))
    (setq n (1+ n))
  (alert (strcat "\n总长度: " (rtos sumlen 2 3) (princ "m")))
  (princ)
发表于 2008-1-22 10:53:10 | 显示全部楼层
这样也行????????????
GMT+8, 2026-11-23 16:06 , Processed in 0.309636 second(s), 14 queries , Gzip On, File On.
