查看: 893|回复: 0
[求助] [求助]:请帮忙修改一下程序,万分感谢
发表于 2008-3-30 17:06:04 | 显示全部楼层 |阅读模式
一个任意点延长的程序,希望能进行优化。
(defun C:kxyc (/ PT1 S0 S1 S2)
    (setvar "CMDECHO" 0)
    (if    (setq PT1 (getpoint "\n指定点位: "))
    (progn
        (command "_.xline" "h" "non" PT1 "")
        (setq S0 (entlast))
        (command "_.xline" "v" "non" PT1 "")
        (setq S1 (entlast))
        (command "_.EXTEND" S0 S1 "")
        (while (setq S2 (entsel "\n点取对象: "))
        (command S2)
        (command "")
        (command "_erase" S0 S1 "")
    (setvar "CMDECHO" 1)
    (princ)
) ;_结束 defun
优化的目标:1、能实现框选功能;2、中途ESC退出时辅助边界能消除。
谢谢了!
GMT+8, 2026-11-7 09:46 , Processed in 0.395473 second(s), 32 queries , Gzip On.
