查看: 1138|回复: 7
[求助] [求助]:图形在屏幕中缩得较小时,break命令不能能执行?
发表于 2008-4-3 13:16:58 | 显示全部楼层 |阅读模式
(defun C:WLL (/ L1 L2 PT1 PT2 PT3 PT4 PT5 PT6 KU)
    (if        (setq L1 (getpoint "\nPick point:"))
        (progn
            (setq OLD_CMDECHO (getvar "CMDECHO"))
            (setvar "CMDECHO" 0)
            (setq CL (getvar "clayer"))
            (setvar "EDGEMODE" 1)
            (command "-layer" "m" "WALL" "C" "31" "" "")
            ;;PLINEWID 存储多段线的缺省宽度
            (setvar "PLINEWID" 60)
            (while (setq L2 (getpoint L1 "\nPick point:"))
                (setq KU (angle L1 L2))
                (setq PT1 (polar L1 (+ KU (* 0.5 pi)) 120))
                (setq PT2 (polar L1 (+ KU (* 1.5 pi)) 120))
                (setq PT3 (polar L2 (+ KU (* 0.5 pi)) 120))
                (setq PT4 (polar L2 (+ KU (* 1.5 pi)) 120))
                (setq PT5 (polar L1 (+ KU (* 0.5 pi)) 300))
                (setq PT6 (polar L2 (+ KU (* 0.5 pi)) 300))
                ;;绘制
                (command "_.Pline" "non" PT1 "non" PT3 "")
                (command "_.Pline" "non" PT2 "non" PT4 "")
                ;;打断
                (command "break" "non" PT5 "f" "non" PT1 "non" PT2)
                (command "break" "non" PT6 "f" "non" PT3 "non" PT4)
            (setvar "clayer" CL)
            (setvar "CMDECHO" OLD_CMDECHO)
    (princ)
当图形充满屏幕时,上面的break命令能执行,当图形在屏幕中缩得较小时,上面的break命令不能能执行。为何?
发表于 2008-4-3 17:14:24 | 显示全部楼层
break命令不能能执行,是因为程序中你没有去除捕捉点设置!还有其他很多情况因为捕捉点没有去除,会得到意想不到的结果!
 楼主| 发表于 2008-4-3 19:14:38 | 显示全部楼层
我也想到了捕捉的问题,在画图时我特别关闭F3,但还是不行,另:程序中用了"NON",应该是取消了捕捉。
已领礼包: 12438个
发表于 2008-4-4 10:37:51 | 显示全部楼层
这样试试:
[php]
(progn
(setq PT5 (polar L1 KU 300))
(setq PT6 (polar L2 (+ KU pi) 300))
;;绘制
(command "_.Pline" "non" PT1 "non" PT3 "") (setq s1 (entlast))
(command "_.Pline" "non" PT2 "non" PT4 "") (setq s2 (entlast))
;;打断
(command ".trim" s1 s2 "" "f" "non" pt5 "non" pt6 "" "")
(setq l1 l2)
(princ)
[/php]
 楼主| 发表于 2008-4-4 12:54:51 | 显示全部楼层
楼上的朋友,谢谢,
程序测试了,还是切不断
发表于 2008-4-4 14:51:36 | 显示全部楼层
szx025 ,能否详细说说你这段程序最终要得到一个什么样的结果?我在我的机器上测试了一下,好像是正常的啊?
 楼主| 发表于 2008-4-4 18:30:57 | 显示全部楼层
这是我画墙线的程序,当墙线T型交叉时,让程序切断墙线中的线段
已领礼包: 488个
发表于 2008-4-5 14:17:37 | 显示全部楼层
(command "break" (list ename point1) point2)
or
(command "break" (list ename point1) "f"point1 point2)
GMT+8, 2026-10-19 00:55 , Processed in 0.745865 second(s), 46 queries , Gzip On.
