查看: 2457|回复: 10
[弹指神通]:能者不难,望赐教
发表于 2008-4-5 22:30:04 | 显示全部楼层 |阅读模式
以下是一个可读取任意线的顶点坐标,并已文本输出的程序,希望大家帮忙改改,让它一行一根线数据而不是一行一个点的数据,我所提取的多义线只有2~4点.写出数据要保证4个点.数据形式如下:
(线)1,x1,y1z1,x2,y2,z2,x3,y3,z3,x4,y4,z4----(点与点间以逗号隔开)
(线)2,x1,y1,z1,x2,y2,z2,x3,y3,z3,x4,y4,z4
(线)3,x1,y1,z1,x2,y2,z2,x3,y3,z3,9999,9999,9999--(点数不够以9999补满)
;[PHP]
;;;;;;;;;;;;;;;根据等高线标高取出数据
(DEFUN C:outh
       (/ SST H fi N I J K p NAME DXF TYPE_LINE XY_COUNT F x y PT1 D N1)
  (setq        fi '((-4 . "<OR")                ; Filter for ssget.
             (0 . "POLYLINE")
             (0 . "LWPOLYLINE")
             (0 . "SHAPE")
             (0 . "INSERT")
             (-4 . "OR>")
(setq F (getfiled "写出文件"   "" "txt" 1))
(SETQ F (OPEN F "w"))
  (PROMPT " \n选取等高线:")
  (SETQ SST (SSGET fi))
  (SETQ N (SSLENGTH SST))
  (SETQ J 0)
  (setq k 0)
  (setq p (getint " \n指定起始点号<1>:"))
  (IF (= NIL P)
    (setq p 1)
  (REPEAT N
    (SETQ NAME (SSNAME SST J))
    (SETQ J (1+ J))
    (SETQ DXF (ENTGET NAME))
    (SETQ TYPE_LINE (CDR (ASSOC 0 DXF)))
    (COND (
           (= TYPE_LINE "POLYLINE")
           (SETQ XY_COUNT (POLYLINE DXF NAME))
           (setq i (length xy_count))
           (setq k 0)
           (repeat i
             (setq y (nth k xy_count))
             (setq h (nth 2 y))
             (setq x (nth 1 y))
             (setq y (nth 0 y))
             (setq y (strcat (itoa P)
                             (rtos Y 2 3)
                             (rtos X 2 3)
                             (rtos h 2 3)
             (write-line y f)
             (setq p (1+ p))
             (setq k (1+ k))
             (setq D D)
             (setq N1 N1)
          ((= TYPE_LINE "LWPOLYLINE")
           (SETQ H (CDR (ASSOC 38 DXF)))
           (SETQ XY_COUNT (LWPOLYLINE DXF))
           (setq k 0)
           (repeat i
             (setq x (nth 1 y))
             (setq y (nth 0 y))
                             (rtos X 2 3)
                             (rtos Y 2 3)
                             (rtos h 2 3)
             (write-line y f)
             (setq p (1+ p))
             (setq k (1+ k))
             (setq D D)
             (setq N1 N1)
          ((OR (= TYPE_LINE "SHAPE") (= TYPE_LINE "INSERT"))
           (SETQ PT1 (CDR (ASSOC 10 DXF)))
           (SETQ X (NTH 1 PT1))
           (SETQ Y (NTH 0 PT1))
           (SETQ H (NTH 2 PT1))
                           (rtos Y 2 3)
                           (rtos X 2 3)
                           (rtos h 2 3)
           (write-line y f)
           (setq p (1+ p))
           (setq D D)
           (setq N1 N1)
  (close f)
(defun POLYLINE        (DXF E1 / XY E2 count_xy pd)
  (setq count_xy nil)
  (SETQ DXF (MEMBER (ASSOC 330 DXF) DXF))
  (SETQ E2 (ENTNEXT E1))
  (SETQ DXF (ENTGET E2))
  (setq e1 (cdr (assoc 0 dxf)))
  (while (= e1 "VERTEX")
    (setq e1 (cdr (assoc 10 dxf)))
    (setq pd (cdr (assoc 70 dxf)))
    (if (/= pd 16)
        (setq count_xy (cons e1 count_xy))
    (setq e1 e2)
  (setq COUNT_XY (reverse count_xy))
(defun LWPOLYLINE (DXF / XY COUNT_XY)
  (SETQ XY (ASSOC 10 DXF))
  (SETQ COUNT_XY ())
  (WHILE XY
    (SETQ DXF (MEMBER XY DXF))
    (SETQ XY (CDR (ASSOC 10 DXF)))
    (SETQ DXF (CDR DXF))
    (SETQ COUNT_XY (CONS XY COUNT_XY))
  (setq COUNT_XY (reverse COUNT_XY))
(defun ap-3d->2d (p1 / a b c)
  (setq a (nth 0 p1))
  (setq b (nth 1 p1))
  (setq p1 (list a b))
(DEFUN PDINDX (SST    P1     /            DIST   INDX          B         JD        N
               J      K             DIST_SST           MAX_P1 MAX_P2 NAME        INDX
               JD_NEAR             MESG
  (SETQ J 0)
  (SETQ P1 (AP-3D->2D P1))
  (REPEAT N
    (SETQ B (SSNAMEX SST J))
    (SETQ JD (AP-3D->2D (NTH 0 (CDR (NTH 3 (NTH 0 B))))))
    (SETQ NAME (NTH 1 (NTH 0 B)))
    (SETQ DIST (distance p1 jd))
    (SETQ DIST_SST (CONS DIST DIST_SST))
    (SETQ NAME_SST (CONS NAME NAME_SST))
    (SETQ J (1+ J))
  (SETQ J 0)
  (WHILE (/= J (- N 1))
    (SETQ K 0)
    (WHILE (/= K (- N 1))
      (SETQ MAX_P1 (NTH K DIST_SST))
      (SETQ MAX_P2 (NTH (+ K 1) DIST_SST))
      (IF (> MAX_P1 MAX_P2)
        (PROGN
          (SETQ B (CDR (MEMBER MAX_P2 DIST_SST)))
          (SETQ B (CONS MAX_P1 B))
          (SETQ B (CONS MAX_P2 B))
          (SETQ JD (- K 1))
          (REPEAT K
            (SETQ MAX_P1 (NTH JD DIST_SST))
            (SETQ JD (- JD 1))
          (SETQ DIST_SST B)
          (SETQ MAX_P1 (NTH K NAME_SST))
          (SETQ MAX_P2 (NTH (+ K 1) NAME_SST))
          (SETQ B (CDR (MEMBER MAX_P2 NAME_SST)))
          (SETQ JD (- K 1))
          (REPEAT K
            (SETQ MAX_P1 (NTH JD NAME_SST))
            (SETQ JD (- JD 1))
          (SETQ NAME_SST B)
      (SETQ K (1+ K))
    (SETQ J (1+ J))
  (SETQ NAME_SST NAME_SST)
;[PHP]
已领礼包: 2个
发表于 2008-4-8 14:55:02 | 显示全部楼层
  1. ;;;根据等高线标高取出数据
  2. (defun C:OUTH (/ SS F P I EN ENT LX STR STR_H)
  3.     (if        (and (princ " \n选取等高线:")
  4.              (setq
  5.                  SS (ssget '((0 . "POLYLINE,LWPOLYLINE,SHAPE,INSERT")))
  6.              )
  7.              (setq F (getfiled "写出文件"   "" "txt" 1))
  8.              (setq F (open F "w"))
  9.         )
  10.         (progn
  11.             (if        (setq P (getint " \n指定起始点号<1>:"))
  12.                 (setq P P)
  13.                 (setq P 1)
  14.             )
  15.             ;;逐个处理
  16.             (setq I 0)
  17.             (repeat (sslength SS)
  18.                 (setq EN  (ssname SS I)
  19.                       ENT (entget EN)
  20.                       LX  (cdr (assoc 0 ENT))
  21.                 )
  22.                 ;;
  23.                 (setq STR (itoa (+ P I)))
  24.                 (if (= LX "LWPOLYLINE")
  25.                     (setq STR_H (rtos (cdr (assoc 38 ENT)) 2 3))
  26.                     (foreach N ENT
  27.                         (if (= (car N) 10)
  28.                             (setq STR (strcat STR
  29.                                               ","
  30.                                               (rtos (cadr N) 2 3)
  31.                                               ","
  32.                                               (rtos (caddr N) 2 3)
  33.                                               ","
  34.                                               STR_H
  35.                                       )
  36.                             )
  37.                         )
  38.                     )
  39.                     (foreach N ENT
  40.                         (if (= (car N) 10)
  41.                             (setq STR (strcat STR
  42.                                               ","
  43.                                               (rtos (cadr N) 2 3)
  44.                                               ","
  45.                                               (rtos (caddr N) 2 3)
  46.                                               ","
  47.                                               (rtos (cadddr N) 2 3)
  48.                                       )
  49.                             )
  50.                         )
  51.                     )
  52.                 )
  53.                 ;;写入内容
  54.                 (write-line STR F)
  55.                 (setq I (1+ I))
  56.             )
  57.             ;;
  58.             (princ (strcat "\n>>>写入完成! " (itoa I) " 个对象。"))
  59.             (close F)
  60.         )
  61.     )
  62.     (princ)
  63. )
 楼主| 发表于 2008-4-8 17:33:24 | 显示全部楼层
感谢"zm184"的回复,
可是您的程序加载时出错了呀
提示:错误: 参数太多: (IF (= LX "LWPOLYLINE") (SETQ STR_H (RTOS (CDR (ASSOC 38 ENT)) 2 3)) (FOREACH N ENT (IF (= (CAR N) 10) (SETQ STR (STRCAT STR "," (RTOS (CADR N) 2 3) "," (RTOS (CADDR N) 2 3) "," STR_H)))) (FOREACH N ENT (IF (= (CAR N) 10) (SETQ STR (STRCAT STR "," (RTOS (CADR N) 2 3) "," (RTOS (CADDR N) 2 3) "," (RTOS (CADDDR N) 2 3))))))
希望帮忙找找原因,谢谢
已领礼包: 2个
发表于 2008-4-8 21:11:49 | 显示全部楼层
已改正
  1. ;;;根据等高线标高取出数据
  4.              (setq
  6.              )
  9.         )
  10.         (progn
  12.                 (setq P P)
  13.                 (setq P 1)
  14.             )
  15.             ;;逐个处理
  16.             (setq I 0)
  19.                       ENT (entget EN)
  21.                 )
  22.                 ;;
  24.                 (if (and (= LX "LWPOLYLINE")
  26.                     )
  27.                     (foreach N ENT
  28.                         (if (= (car N) 10)
  29.                             (setq STR (strcat STR
  30.                                               ","
  31.                                               (rtos (cadr N) 2 3)
  32.                                               ","
  33.                                               (rtos (caddr N) 2 3)
  34.                                               ","
  35.                                               STR_H
  36.                                       )
  37.                             )
  38.                         )
  39.                     )
  40.                     (foreach N ENT
  41.                         (if (= (car N) 10)
  42.                             (setq STR (strcat STR
  43.                                               ","
  44.                                               (rtos (cadr N) 2 3)
  45.                                               ","
  46.                                               (rtos (caddr N) 2 3)
  47.                                               ","
  48.                                               (rtos (cadddr N) 2 3)
  49.                                       )
  50.                             )
  51.                         )
  52.                     )
  53.                 )
  54.                 ;;写入内容
  55.                 (write-line STR F)
  56.                 (setq I (1+ I))
  57.             )
  58.             ;;
  59.             (princ (strcat "\n>>>写入完成! " (itoa I) " 个对象。"))
  60.             (close F)
  61.         )
  62.     )
  63.     (princ)
  64. )
 楼主| 发表于 2008-4-9 16:25:50 | 显示全部楼层
ZM184你好,你的程序使用后提取出来的信息怎么会是以下形式的呢?
1,0,0,0
2,0,0,0
3,0,0,0
4,0,0,0
5,0,0,0
6,0,0,0
发表于 2008-4-10 22:07:07 | 显示全部楼层
你用的是pline线而不是zm184的lwpline线。
发表于 2008-4-10 22:55:41 | 显示全部楼层
太复杂了啊
 楼主| 发表于 2008-4-11 18:44:27 | 显示全部楼层
大家可否帮忙改改让他实现"POLYLINE"啊,谢谢
发表于 2008-4-12 00:40:00 | 显示全部楼层
  1. (DEFUN C:ttt (/ E FI I LST P PT SS STR)
  2.   (setq fi '((0 . "*POLYLINE")))        ; Filter for ssget.
  3.   (setq Fn (getfiled "写出文件" "" "txt" 1))
  4.   (SETQ F (OPEN Fn "w"))
  5.   (PROMPT " \n选取等高线:")
  6.   (SETQ SS (SSGET fi))
  7.   (SETQ i -1)
  8.   (IF (not (setq p (getint " \n指定起始点号<1>:")))
  9.     (setq p 1)
  10.   )
  11.   (while (setq i (1+ i)
  12.                e (ssname ss i)
  13.          )
  14.     (setq str (strcat "(线)" (itoa p))
  15.           p   (1+ p)
  16.           ii -1
  17.     )
  18.     (repeat 4
  19.     (if        (setq ii (1+ ii)
  20.               pt (vlax-curve-getpointatparam e ii))
  21.       (setq str        (strcat        str","(rtos (car pt) 2 3)","(rtos (cadr pt) 2 3)","(rtos (caddr pt) 2 3)))
  22.       (setq str (strcat str "," "9999,9999,9999"))
  23.     )
  24.    )
  25.     (setq lst (cons str lst))
  26.   )
  27.   (mapcar '(lambda(x)(write-line x f)) (reverse lst))
  28.   (close f)
  29.   (princ)
  30. )
 楼主| 发表于 2008-4-12 08:41:50 | 显示全部楼层
非常感谢大家的回复,经测试"雨箭风刀"的程序完全符合要求,谢谢大家.
小弟还有个要求,如果反过来呢,我要用一个程序读取:数据形式如下:
(线)1,14325,-1624,2475,14325,-1851,2475,14930,-2200,2475,14930,-4665,2475
(线)2,14930,-4668,2475,14930,-5053,2475,15900,-5053,2550,15900,-5413,2550
(线)3,15900,-6245,2550,15900,-7066,2550,9999,9999,9999,9999,9999,9999--(9999不画)
(线)4,14325,1621,2475,14325,-1621,2475,9999,9999,9999,9999,9999,9999
(线)5,14930,4668,2475,14930,2200,2475,14325,1851,2475,14325,1624,2475
(线)6,15900,5413,2550,15900,5053,2550,14930,5053,2475,14930,4668,2475
(线)7,15900,7066,2550,15900,6245,2550,9999,9999,9999,9999,9999,9999
让其生成POLYLINE线,要怎么实现呢???(所有9999,9999,9999不画)
发表于 2008-5-15 23:14:01 | 显示全部楼层
楼主的要求还真不少,自己琢磨下就很容易根据数据生成线
GMT+8, 2026-11-2 16:54 , Processed in 1.039836 second(s), 52 queries , Gzip On.
