查看: 1472|回复: 3
[编程申请]:将文字旋转角度d(45≤d<135)的文字放到新建的颜色为5的图层“角度一”中
发表于 2008-4-10 09:42:00 | 显示全部楼层 |阅读模式
lsp编程申请:将文字旋转角度d(45≤d<135)的文字放到新建的颜色为5的图层“角度一”中,其余角度的文字放到新建的颜色为6的图层“角度二”中。
已领礼包: 12484个
发表于 2008-4-10 22:57:08 | 显示全部楼层
[php]
(DEFUN C:TT ()
(SETVAR "CMDECHO" 0)
(if (setq ss (ssget '((0 . "*TEXT")))) (progn
  (setq i -1 s1 (ssadd) s2 (ssadd))
  (repeat (sslength ss)
   (setq en (ssname ss (setq i (1+ i)))
         ent (entget en)
         an (cdr (assoc 50 ent)))
   (if (< (/ pi 4) an (* pi 0.75))
    (setq s1 (ssadd en s1))
    (setq s2 (ssadd en s2))
  (if (> (sslength s1) 0) (progn
   (command ".layer" "M" "角度一" "C" 5 "角度一" "")
   (command "CHPROP" s1 "" "LA" "角度一" "")
  (if (> (sslength s2) 0) (progn
   (command ".layer" "M" "角度二" "C" 6 "角度二" "")
   (command "CHPROP" s2 "" "LA" "角度二" "")
(SETVAR "CMDECHO" 1)
(PRINC)
[/php]
 楼主| 发表于 2008-4-11 12:58:36 | 显示全部楼层
CAD2004测试可用,谢谢zxq0220大侠。
发表于 2008-4-13 19:15:39 | 显示全部楼层
如未解决的话,可以联系ljttjl@tom.com
GMT+8, 2026-11-3 20:09 , Processed in 0.457559 second(s), 38 queries , Gzip On.
